no-preinstall: Architecture-specific header files
    Sebastian Huber
    Tue Jan 23 09:17:35 UTC 2018
On 22/01/18 22:03, Chris Johns wrote:
> On 19/1/18 6:21 pm, Sebastian Huber wrote:
>> Hello,
>> the architecture-specific header files are currently in:
>> cpukit/score/cpu/@RTEMS_CPU@
>> For example:
>> cpukit/score/cpu/sparc/rtems/score/cpu.h
>> The new include directory for architecture-specific header files after the
>> preinstall removal is:
>> cpukit/score/cpu/@RTEMS_CPU@/include
>> For example:
>> cpukit/score/cpu/sparc/include/rtems/score/cpu.h
>> There are two problems with this.
>> 1. It introduces yet another sub-directory and makes the path longer.
>> 2. It moves header files which are in this place since 1999. Using
>> cpukit/score/cpu/@RTEMS_CPU@ as the include directory would avoid this.
> Thank you for raising this. It is bit inconsistent.
>> This should be the last time we move header files around. It is very easy to
>> move include directories in the no-preinstall branch.
>> Other options for architecture-specific header files are:
> If this has source files and maybe private headers we should not add use this path.
There are no private header files, e.g.
find cpukit/score/cpu/ -name '*.h' | grep -v include
finds nothing in the no-preinstall branch.
There are source files in cpukit/score/cpu/@RTEMS_CPU at .
>> cpukit/@RTEMS_CPU@/include
>> cpukit/arch/@RTEMS_CPU@/include
>> cpukit/cpu/@RTEMS_CPU@/include
>> cpukit/include/@RTEMS_CPU@
> I think this is a good place but I am concerned about 2 -I paths, one a sub path
> of another. Is that a problem?
You can find some header files via two paths, e.g.
#include <powerpc/rtems/score/cpu.h>
#include <rtems/score/cpu.h>
I am not sure if this is a bug or a feature.
>> include/@RTEMS_CPU@
>> The general include files are now in:
>> cpukit/include
>> Another option would be:
>> include
>> What do you think?
> I am not sure.
We can postpone the cpukit/score/cpu header file move. It is not
necessary for the preinstall removal.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
