no-preinstall: Architecture-specific header files
    Chris Johns
    chrisj at rtems.org
    Tue Jan 23 21:15:59 UTC 2018
On 24/01/2018 01:53, Gedare Bloom wrote:
> On Tue, Jan 23, 2018 at 4:17 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 22/01/18 22:03, Chris Johns wrote:
>>> On 19/1/18 6:21 pm, Sebastian Huber wrote:
>>>> Hello,
>>>> the architecture-specific header files are currently in:
>>>> cpukit/score/cpu/@RTEMS_CPU@
>>>> For example:
>>>> cpukit/score/cpu/sparc/rtems/score/cpu.h
>>>> The new include directory for architecture-specific header files after
>>>> the
>>>> preinstall removal is:
>>>> cpukit/score/cpu/@RTEMS_CPU@/include
>>>> For example:
>>>> cpukit/score/cpu/sparc/include/rtems/score/cpu.h
>>>> There are two problems with this.
>>>> 1. It introduces yet another sub-directory and makes the path longer.
>>>> 2. It moves header files which are in this place since 1999. Using
>>>> cpukit/score/cpu/@RTEMS_CPU@ as the include directory would avoid this.
>>> Thank you for raising this. It is bit inconsistent.
>>>> This should be the last time we move header files around. It is very easy
>>>> to
>>>> move include directories in the no-preinstall branch.
>>>> Other options for architecture-specific header files are:
>>> If this has source files and maybe private headers we should not add use
>>> this path.
>> There are no private header files, e.g.
>> find cpukit/score/cpu/ -name '*.h' | grep -v include
>> finds nothing in the no-preinstall branch.
>> There are source files in cpukit/score/cpu/@RTEMS_CPU at .
>>>> cpukit/@RTEMS_CPU@/include
>>>> cpukit/arch/@RTEMS_CPU@/include
>>>> cpukit/cpu/@RTEMS_CPU@/include
>>>> cpukit/include/@RTEMS_CPU@
>>> I think this is a good place but I am concerned about 2 -I paths, one a
>>> sub path
>>> of another. Is that a problem?
>> You can find some header files via two paths, e.g.
>> #include <powerpc/rtems/score/cpu.h>
>> #include <rtems/score/cpu.h>
>> I am not sure if this is a bug or a feature.
> If we move them, I prefer this cpukit/include/@RTEMS_CPU@ because it
> is easier to find header files while browsing the cpukit source tree,
> there is only one place to look in the include subtree. I'm also ok
> with cpukit/include/arch/@RTEMS_CPU@ to further organize them, which
> was not an option you listed.
Either works for me.
