[GSOC - Tracing] Status Update
Sun Jul 1 01:42:18 UTC 2018
On 29 Jun 2018, at 5:44 pm, Vidushi Vashishth <reachvidu at gmail.com> wrote:
>>> >Could you please create a self-contained repository which contains
>>> >* a README
>>> >* a simple RTEMS application which runs on a simulator BSP
>>> >* the stuff that makes it possible to view the trace output (it is not a problem if it doesn't work, but all pieces should be included)
>>> >The repository should not be a clone of some larger project. It may contain external references as submodules.
>>> Okay. Got it. I will update you when its done.
>> Ok, do you have a time estimate for this? Which parts are missing?
> Viewing the trace output is buggy right now. I will have to combine the rest. I will push the required things in the repository by end of today and notify you.
Did this happen?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180701/5df9b23b/attachment.html>
