[PATCH 2/2] x86_64/console: Add NS16550 polled console driver
Amaan Cheval amaan.cheval at gmail.com
Mon Jul 9 11:12:57 UTC 2018
This addition allows us to successfully run the sample hello.exe test.
Updates #2898.
 bsps/x86_64/amd64/console/console.c                | 123 +++++----------------
 c/src/lib/libbsp/x86_64/amd64/Makefile.am          |   2 +
 .../score/cpu/x86_64/include/rtems/score/cpuimpl.h |  14 +++
 .../score/cpu/x86_64/include/rtems/score/x86_64.h  |   3 +
 4 files changed, 49 insertions(+), 93 deletions(-)
diff --git a/bsps/x86_64/amd64/console/console.c b/bsps/x86_64/amd64/console/console.c
index b272b679d7..5408c57fe7 100644
--- a/bsps/x86_64/amd64/console/console.c
+++ b/bsps/x86_64/amd64/console/console.c
@@ -24,112 +24,49 @@
  * SUCH DAMAGE.
-#include <bsp.h>
+#include <libchip/ns16550.h>
 #include <rtems/bspIo.h>
-#include <rtems/libio.h>
-/*  console_initialize
- *  This routine initializes the console IO driver.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  Return values:
+#include <bsp.h>
+#include <bsp/console-termios.h>
+#include <rtems/score/cpuimpl.h>
-rtems_device_driver console_initialize(
-  rtems_device_major_number  major,
-  rtems_device_minor_number  minor,
-  void                      *arg
+static uint8_t amd64_uart_get_register(uintptr_t addr, uint8_t i)
-  (void) major;
-  (void) minor;
-  (void) arg;
-  return RTEMS_SUCCESSFUL;
+  return inport_byte(addr + i);
- *  Open entry point
-rtems_device_driver console_open(
-  void                    * arg
+static void amd64_uart_set_register(uintptr_t addr, uint8_t i, uint8_t val)
-  (void) major;
-  (void) minor;
-  (void) arg;
+  outport_byte(addr + i, val);
- *  Close entry point
-rtems_device_driver console_close(
-  void                    * arg
-  (void) major;
-  (void) minor;
-  (void) arg;
+static ns16550_context amd64_uart_context = {
+  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("UART"),
+  .get_reg = amd64_uart_get_register,
+  .set_reg = amd64_uart_set_register,
+  .port = (uintptr_t) COM1_BASE_IO,
+  .initial_baud = COM1_CLOCK_RATE
- * read bytes from the serial port. We only have stdin.
+ * XXX: We should use the interrupt based handler once interrupts are supported
+const console_device console_device_table[] = {
+    .device_file = "/dev/console",
+    .probe = console_device_probe_default,
+    .handler = &ns16550_handler_polled,
+    .context = &amd64_uart_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
-rtems_device_driver console_read(
-  void                    * arg
+static void output_char(char c)
-  (void) major;
-  (void) minor;
-  (void) arg;
+  rtems_termios_device_context *ctx = console_device_table[0].context;
- * write bytes to the serial port. Stdout and stderr are the same.
-rtems_device_driver console_write(
-  void                    * arg
-  (void) major;
-  (void) minor;
-  (void) arg;
-  return 0;
- *  IO Control entry point
-rtems_device_driver console_control(
-  void                    * arg
-  (void) major;
-  (void) minor;
-  (void) arg;
+  ns16550_polled_putchar(ctx, c);
-BSP_output_char_function_type     BSP_output_char = NULL;
-BSP_polling_getchar_function_type BSP_poll_char   = NULL;
+BSP_output_char_function_type BSP_output_char   = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/x86_64/amd64/Makefile.am b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
index f05b40f3f9..aa40f6224f 100644
--- a/c/src/lib/libbsp/x86_64/amd64/Makefile.am
+++ b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
@@ -29,6 +29,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
 # clock
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/clock/clock-simidle.c
 # console
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios-init.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/console/console.c
 # timer
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
index bac092c320..67fe712a32 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
@@ -28,6 +28,20 @@
 extern "C" {
 #endif
+static inline uint8_t inport_byte(uint16_t port)
+  uint8_t ret;
+  __asm__ volatile ( "inb %1, %0"
+                     : "=a" (ret)
+                     : "Nd" (port) );
+  return ret;
+static inline void outport_byte(uint16_t port, uint8_t val)
+  __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
index 237d95de98..853e45ab5d 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
@@ -34,6 +34,9 @@ extern "C" {
 #define CPU_NAME "x86-64"
 #define CPU_MODEL_NAME "XXX: x86-64 generic"
+#define COM1_BASE_IO 0x3F8
+#define COM1_CLOCK_RATE (115200 * 16)
 #ifdef __cplusplus
 #endif
2.15.0
