[PATCH v3] coverage : Add support to run coverage in supported bsp without extra options
Tue Jul 10 15:17:42 UTC 2018
I don't see any problem with it, but I prefer to let Chris decide on merging...
On Tue, Jul 10, 2018 at 8:11 AM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> ping :)
> On 6 July 2018 at 02:08, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Hello Chris,
>> If you find some time, please review this patch.
>> It's a small patch but it's important since it affects how the command
>> will look like.
>> please review if this patch is alright or we need to have a different
>> approach.
>> Thanks
>> On 3 July 2018 at 20:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> Close #3440
>>>  tester/rt/test.py                            | 21 ++++++++++++++-------
>>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini |  1 +
>>>  2 files changed, 15 insertions(+), 7 deletions(-)
>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>> index 9214ad6..5d25d82 100644
>>> --- a/tester/rt/test.py
>>> +++ b/tester/rt/test.py
>>> @@ -232,7 +232,7 @@ def run(command_path = None):
>>>                      '--filter':         'Glob that executables must
>>> match to run (default: ' +
>>>                                default_exefilter + ')',
>>>                      '--stacktrace':     'Dump a stack trace on a user
>>> termination (^C)',
>>> -                    '--coverage':       'Perform coverage analysis of
>>> test executables.'}
>>> +                    '--coverage-sets':  'Perform coverage analysis for
>>> specific sets.'}
>>>          mailer.append_options(optargs)
>>>          opts = options.load(sys.argv,
>>>                              optargs = optargs,
>>> @@ -283,14 +283,21 @@ def run(command_path = None):
>>>              raise error.general('RTEMS BSP not provided or an invalid
>>> option')
>>>          bsp = config.load(bsp[1], opts)
>>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>> -        coverage_enabled = opts.find_arg('--coverage')
>>> +        coverage_sets = opts.find_arg('--coverage-sets')
>>> +        try:
>>> +            coverage_enabled = opts.defaults.get('coverage')
>>> +        except:
>>> +            coverage_enabled = False
>>>          if coverage_enabled:
>>>              cov_trace = 'cov' in debug_trace.split(',')
>>> -            if len(coverage_enabled) == 2:
>>> -                coverage_runner = coverage.coverage_run(opts.defaults,
>>> -                                                        executables,
>>> -                                                        symbol_set =
>>> coverage_enabled[1],
>>> -                                                        trace =
>>> cov_trace)
>>> +            if coverage_sets:
>>> +                if len(coverage_sets) != 2:
>>> +                    raise error.general('No sets provided in
>>> --coverage-sets')
>>> +                else:
>>> +                    coverage_runner =
>>> +                                                            executables,
>>> +                                                            symbol_set =
>>> coverage_sets[1],
>>> +                                                            trace =
>>> cov_trace)
>>>              else:
>>>                                                          executables,
>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> index 2f89117..6462448 100644
>>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> @@ -38,3 +38,4 @@ target            = sparc-rtems5
>>>  tester            = %{_rtscripts}/qemu.cfg
>>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>> +coverage          = True
>>> 2.14.4
