[PATCH 05/45] Correct line lengths in libfdt.h
Wed Jul 18 07:35:14 UTC 2018
There are a few lines that are over 80 columns. Fix these.
Signed-off-by: Simon Glass <sjg at chromium.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/include/libfdt.h | 35 +++++++++++++++++++++++------------
 1 file changed, 23 insertions(+), 12 deletions(-)
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 25311cbfe7..2c7b4e876c 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -318,8 +318,9 @@ int fdt_subnode_offset_namelen(const void *fdt, int parentoffset,
  * returns:
  *	structure block offset of the requested subnode (>=0), on success
  *	-FDT_ERR_NOTFOUND, if the requested subnode does not exist
- *	-FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE tag
- *      -FDT_ERR_BADMAGIC,
+ *	-FDT_ERR_BADOFFSET, if parentoffset did not point to an FDT_BEGIN_NODE
+ *		tag
+ *	-FDT_ERR_BADMAGIC,
  *	-FDT_ERR_BADVERSION,
  *	-FDT_ERR_BADSTATE,
  *	-FDT_ERR_BADSTRUCTURE,
@@ -351,7 +352,8 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen);
  * address).
  * returns:
- *	structure block offset of the node with the requested path (>=0), on success
+ *	structure block offset of the node with the requested path (>=0), on
+ *		success
  *	-FDT_ERR_BADPATH, given path does not begin with '/' or is invalid
  *	-FDT_ERR_NOTFOUND, if the requested node does not exist
@@ -375,10 +377,12 @@ int fdt_path_offset(const void *fdt, const char *path);
  * returns:
  *	pointer to the node's name, on success
- *		If lenp is non-NULL, *lenp contains the length of that name (>=0)
+ *		If lenp is non-NULL, *lenp contains the length of that name
+ *			(>=0)
  *	NULL, on error
  *		if lenp is non-NULL *lenp contains an error code (<0):
- *		-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag
+ *		-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE
+ *			tag
  *		-FDT_ERR_BADSTATE, standard meanings
@@ -490,7 +494,8 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt,
  *	NULL, on error
  *		if lenp is non-NULL, *lenp contains an error code (<0):
  *		-FDT_ERR_NOTFOUND, node does not have named property
+ *			tag
@@ -575,7 +580,8 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset,
  *	NULL, on error
+ *			tag
@@ -680,7 +686,8 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen);
  *	structure block offset of the node at node offset's ancestor
  *		of depth supernodedepth (>=0), on success
  *	-FDT_ERR_BADOFFSET, nodeoffset does not refer to a BEGIN_NODE tag
- *	-FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of nodeoffset
+ *	-FDT_ERR_NOTFOUND, supernodedepth was greater than the depth of
+ *		nodeoffset
@@ -959,7 +966,8 @@ const char *fdt_stringlist_get(const void *fdt, int nodeoffset,
  * returns:
  *	0 <= n < FDT_MAX_NCELLS, on success
  *      2, if the node has no #address-cells property
- *      -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid #address-cells property
+ *      -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid
+ *		#address-cells property
@@ -979,7 +987,8 @@ int fdt_address_cells(const void *fdt, int nodeoffset);
  * returns:
- *      -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid #size-cells property
+ *		#size-cells property
@@ -1603,9 +1612,11 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset,
  * change the offsets of some existing nodes.
  * returns:
- *	structure block offset of the created nodeequested subnode (>=0), on success
+ *	structure block offset of the created nodeequested subnode (>=0), on
+ *		success
+ *		tag
  *	-FDT_ERR_EXISTS, if the node at parentoffset already has a subnode of
  *		the given name
  *	-FDT_ERR_NOSPACE, if there is insufficient free space in the
2.13.7
