[PATCH 07/45] libfdt: Add a subnodes iterator macro
Wed Jul 18 07:35:16 UTC 2018
The fdt_for_each_subnode() iterator macro provided by this patch can be
used to iterate over a device tree node's subnodes. At each iteration a
loop variable will be set to the next subnode.
Signed-off-by: Thierry Reding <treding at nvidia.com>
Signed-off-by: Maxime Ripard <maxime.ripard at free-electrons.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/include/libfdt.h | 28 ++++++++++++++++++++++++++++
 1 file changed, 28 insertions(+)
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 36222fd4a6..911e548163 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -168,6 +168,34 @@ int fdt_first_subnode(const void *fdt, int offset);
 int fdt_next_subnode(const void *fdt, int offset);
+ * fdt_for_each_subnode - iterate over all subnodes of a parent
+ * @node:	child node (int, lvalue)
+ * @fdt:	FDT blob (const void *)
+ * @parent:	parent node (int)
+ * This is actually a wrapper around a for loop and would be used like so:
+ *	fdt_for_each_subnode(node, fdt, parent) {
+ *		Use node
+ *	if ((node < 0) && (node != -FDT_ERR_NOT_FOUND)) {
+ *		Error handling
+ * Note that this is implemented as a macro and @node is used as
+ * iterator in the loop. The parent variable be constant or even a
+ * literal.
+#define fdt_for_each_subnode(node, fdt, parent)		\
+	for (node = fdt_first_subnode(fdt, parent);	\
+	     node >= 0;					\
+	     node = fdt_next_subnode(fdt, node))
 /* General functions                                                  */
2.13.7
