[PATCH 23/45] libfdt: Add fdt_setprop_empty()
Wed Jul 18 07:35:32 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
Device trees can contain empty (zero length) properties, which are often
used as boolean flags.  These can already be created using fdt_setprop()
passing a length of zero and a pointer which is ignored.  It is safe to
pass NULL, but that may not be obvious from the interface.  To make it
clearer, add an fdt_setprop_empty() helper macro.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/include/libfdt.h | 30 ++++++++++++++++++++++++++++++
 1 file changed, 30 insertions(+)
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index c69e918899..ac42e04595 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -1527,6 +1527,36 @@ static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name,
 #define fdt_setprop_string(fdt, nodeoffset, name, str) \
 	fdt_setprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
+ * fdt_setprop_empty - set a property to an empty value
+ * @fdt: pointer to the device tree blob
+ * @nodeoffset: offset of the node whose property to change
+ * @name: name of the property to change
+ * fdt_setprop_empty() sets the value of the named property in the
+ * given node to an empty (zero length) value, or creates a new empty
+ * property if it does not already exist.
+ * This function may insert or delete data from the blob, and will
+ * therefore change the offsets of some existing nodes.
+ * returns:
+ *	0, on success
+ *	-FDT_ERR_NOSPACE, there is insufficient free space in the blob to
+ *		contain the new property value
+ *	-FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag
+ *	-FDT_ERR_BADLAYOUT,
+ *	-FDT_ERR_BADMAGIC,
+ *	-FDT_ERR_BADVERSION,
+ *	-FDT_ERR_BADSTATE,
+ *	-FDT_ERR_BADSTRUCTURE,
+ *	-FDT_ERR_TRUNCATED, standard meanings
+#define fdt_setprop_empty(fdt, nodeoffset, name) \
+	fdt_setprop((fdt), (nodeoffset), (name), NULL, 0)
  * fdt_appendprop - append to or create a property
2.13.7
