[PATCH 32/45] Add limited read-only support for older (V2 and V3) device tree to libfdt.
Wed Jul 18 07:35:41 UTC 2018
This can be useful in particular in the kernel when booting on systems
with FDT-emitting firmware that is out of date. Releases of kexec-tools
on ppc64 prior to the end of 2014 are notable examples of such.
Signed-off-by: Nathan Whitehorn <nwhitehorn at freebsd.org>
[dwg: Some whitespace cleanups]
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt.c    |   3 ++
 cpukit/dtc/libfdt/fdt_ro.c | 100 ++++++++++++++++++++++++++++++++++++++-------
 cpukit/include/libfdt.h    |   5 ++-
 3 files changed, 92 insertions(+), 16 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index fd13236736..7855a17877 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -123,6 +123,9 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
 		/* skip-name offset, length and value */
 		offset += sizeof(struct fdt_property) - FDT_TAGSIZE
 			+ fdt32_to_cpu(*lenp);
+		if (fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 &&
+		    ((offset - fdt32_to_cpu(*lenp)) % 8) != 0)
+			offset += 4;
 		break;
 	case FDT_END:
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index ce17814b2b..dfb3236da3 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -58,9 +58,10 @@
 static int fdt_nodename_eq_(const void *fdt, int offset,
 			    const char *s, int len)
-	const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1);
+	int olen;
+	const char *p = fdt_get_name(fdt, offset, &olen);
-	if (!p)
+	if (!p || olen < len)
 		/* short match */
 		return 0;
@@ -233,16 +234,34 @@ int fdt_path_offset(const void *fdt, const char *path)
 const char *fdt_get_name(const void *fdt, int nodeoffset, int *len)
 	const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset);
+	const char *nameptr;
 	int err;
 	if (((err = fdt_check_header(fdt)) != 0)
 	    || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))
 			goto fail;
+	nameptr = nh->name;
+	if (fdt_version(fdt) < 0x10) {
+		 * For old FDT versions, match the naming conventions of V16:
+		 * give only the leaf name (after all /). The actual tree
+		 * contents are loosely checked.
+		const char *leaf;
+		leaf = strrchr(nameptr, '/');
+		if (leaf == NULL) {
+			err = -FDT_ERR_BADSTRUCTURE;
+			goto fail;
+		nameptr = leaf+1;
 	if (len)
-		*len = strlen(nh->name);
+		*len = strlen(nameptr);
-	return nh->name;
+	return nameptr;
  fail:
 	if (len)
@@ -268,9 +287,9 @@ int fdt_next_property_offset(const void *fdt, int offset)
 	return nextprop_(fdt, offset);
-const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
-						      int offset,
-						      int *lenp)
+static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt,
+						              int offset,
+						              int *lenp)
 	int err;
 	const struct fdt_property *prop;
@@ -289,23 +308,44 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
 	return prop;
-const struct fdt_property *fdt_get_property_namelen(const void *fdt,
-						    int offset,
-						    const char *name,
-						    int namelen, int *lenp)
+const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
+						      int offset,
+						      int *lenp)
+	/* Prior to version 16, properties may need realignment
+	 * and this API does not work. fdt_getprop_*() will, however. */
+		if (lenp)
+			*lenp = -FDT_ERR_BADVERSION;
+		return NULL;
+	return fdt_get_property_by_offset_(fdt, offset, lenp);
+static const struct fdt_property *fdt_get_property_namelen_(const void *fdt,
+						            int offset,
+						            const char *name,
+						            int namelen,
+							    int *lenp,
+							    int *poffset)
 	for (offset = fdt_first_property_offset(fdt, offset);
 	     (offset >= 0);
 	     (offset = fdt_next_property_offset(fdt, offset))) {
-		if (!(prop = fdt_get_property_by_offset(fdt, offset, lenp))) {
+		if (!(prop = fdt_get_property_by_offset_(fdt, offset, lenp))) {
 			offset = -FDT_ERR_INTERNAL;
 			break;
 		if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff),
-				   name, namelen))
+				   name, namelen)) {
+			if (poffset)
+				*poffset = offset;
 			return prop;
 	if (lenp)
@@ -313,6 +353,25 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt,
 	return NULL;
+const struct fdt_property *fdt_get_property_namelen(const void *fdt,
+						    int offset,
+						    const char *name,
+						    int namelen, int *lenp)
+		if (lenp)
+		return NULL;
+	return fdt_get_property_namelen_(fdt, offset, name, namelen, lenp,
+					 NULL);
 const struct fdt_property *fdt_get_property(const void *fdt,
 					    int nodeoffset,
 					    const char *name, int *lenp)
@@ -324,12 +383,18 @@ const struct fdt_property *fdt_get_property(const void *fdt,
 const void *fdt_getprop_namelen(const void *fdt, int nodeoffset,
 				const char *name, int namelen, int *lenp)
+	int poffset;
-	prop = fdt_get_property_namelen(fdt, nodeoffset, name, namelen, lenp);
+	prop = fdt_get_property_namelen_(fdt, nodeoffset, name, namelen, lenp,
+					 &poffset);
 	if (!prop)
 		return NULL;
+	/* Handle realignment */
+	if (fdt_version(fdt) < 0x10 && (poffset + sizeof(*prop)) % 8 &&
+	    fdt32_to_cpu(prop->len) >= 8)
+		return prop->data + 4;
 	return prop->data;
@@ -338,11 +403,16 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset,
-	prop = fdt_get_property_by_offset(fdt, offset, lenp);
+	prop = fdt_get_property_by_offset_(fdt, offset, lenp);
 	if (!prop)
 		return NULL;
 	if (namep)
 		*namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
+	if (fdt_version(fdt) < 0x10 && (offset + sizeof(*prop)) % 8 &&
 	return prop->data;
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index baa882cfa1..c8c00fa865 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -54,7 +54,7 @@
 #include <libfdt_env.h>
 #include <fdt.h>
-#define FDT_FIRST_SUPPORTED_VERSION	0x10
+#define FDT_FIRST_SUPPORTED_VERSION	0x02
 #define FDT_LAST_SUPPORTED_VERSION	0x11
 /* Error codes: informative error codes */
@@ -527,6 +527,9 @@ int fdt_next_property_offset(const void *fdt, int offset);
  * offset.  If lenp is non-NULL, the length of the property value is
  * also returned, in the integer pointed to by lenp.
+ * Note that this code only works on device tree versions >= 16. fdt_getprop()
+ * works on all versions.
  * returns:
  *	pointer to the structure representing the property
  *		if lenp is non-NULL, *lenp contains the length of the property
2.13.7
