[PATCH 33/45] libfdt: Clean up header checking functions
Wed Jul 18 07:35:42 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
Many of the libfdt entry points call some sort of sanity check function
before doing anything else.  These need to do slightly different things for
the various classes of functions.
The read-only version is shared with the exported fdt_check_header(), which
limits us a bit in how we can improve it.  For that reason split the two
functions apart (though the exported one just calls the ro one for now).
We also rename the functions for more consistency - they're all named
fdt_XX_probe_() where the XX indicates which class of functions they're
for.  "probe" is a better "term" than the previous check, since they really
only do minimal validation.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
Tested-by: Alexey Kardashevskiy <aik at ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik at ozlabs.ru>
 cpukit/dtc/libfdt/fdt.c             | 14 ++++++++++++--
 cpukit/dtc/libfdt/fdt_ro.c          | 18 +++++++++---------
 cpukit/dtc/libfdt/fdt_rw.c          | 28 ++++++++++++++--------------
 cpukit/dtc/libfdt/fdt_sw.c          | 18 +++++++++---------
 cpukit/dtc/libfdt/libfdt_internal.h |  5 +++--
 5 files changed, 47 insertions(+), 36 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 7855a17877..8bbf2dc894 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -55,7 +55,12 @@
 #include "libfdt_internal.h"
-int fdt_check_header(const void *fdt)
+ * Minimal sanity check for a read-only tree. fdt_ro_probe_() checks
+ * that the given buffer contains what appears to be a flattened
+ * device tree with sane information in its header.
+int fdt_ro_probe_(const void *fdt)
 	if (fdt_magic(fdt) == FDT_MAGIC) {
 		/* Complete tree */
@@ -74,6 +79,11 @@ int fdt_check_header(const void *fdt)
 	return 0;
+int fdt_check_header(const void *fdt)
+	return fdt_ro_probe_(fdt);
 const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len)
 	unsigned absoffset = offset + fdt_off_dt_struct(fdt);
@@ -244,7 +254,7 @@ const char *fdt_find_string_(const char *strtab, int tabsize, const char *s)
 int fdt_move(const void *fdt, void *buf, int bufsize)
-	FDT_CHECK_HEADER(fdt);
+	FDT_RO_PROBE(fdt);
 	if (fdt_totalsize(fdt) > bufsize)
 		return -FDT_ERR_NOSPACE;
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index dfb3236da3..4f4ef44a3a 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -117,7 +117,7 @@ uint32_t fdt_get_max_phandle(const void *fdt)
 int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size)
 	*address = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->address);
 	*size = fdt64_to_cpu(fdt_mem_rsv_(fdt, n)->size);
 	return 0;
@@ -161,7 +161,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int offset,
 	int depth;
 	for (depth = 0;
 	     (offset >= 0) && (depth >= 0);
@@ -187,7 +187,7 @@ int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen)
 	const char *p = path;
 	int offset = 0;
 	/* see if we have an alias */
 	if (*path != '/') {
@@ -237,7 +237,7 @@ const char *fdt_get_name(const void *fdt, int nodeoffset, int *len)
 	const char *nameptr;
 	int err;
-	if (((err = fdt_check_header(fdt)) != 0)
+	if (((err = fdt_ro_probe_(fdt)) != 0)
 	    || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))
 			goto fail;
@@ -462,7 +462,7 @@ int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen)
 	int offset, depth, namelen;
 	const char *name;
 	if (buflen < 2)
@@ -514,7 +514,7 @@ int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset,
 	int offset, depth;
 	int supernodeoffset = -FDT_ERR_INTERNAL;
 	if (supernodedepth < 0)
 		return -FDT_ERR_NOTFOUND;
@@ -573,7 +573,7 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset,
 	const void *val;
 	int len;
 	/* FIXME: The algorithm here is pretty horrible: we scan each
 	 * property of a node in fdt_getprop(), then if that didn't
@@ -599,7 +599,7 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle)
 	if ((phandle == 0) || (phandle == -1))
 		return -FDT_ERR_BADPHANDLE;
 	 * potentially scan each property of a node in
@@ -752,7 +752,7 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset,
 	int offset, err;
 	 * property of a node in fdt_node_check_compatible(), then if
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 9b829051e4..2e49855d7c 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -67,9 +67,9 @@ static int fdt_blocks_misordered_(const void *fdt,
 		    (fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt)));
-static int fdt_rw_check_header_(void *fdt)
+static int fdt_rw_probe_(void *fdt)
 	if (fdt_version(fdt) < 17)
 		return -FDT_ERR_BADVERSION;
@@ -82,10 +82,10 @@ static int fdt_rw_check_header_(void *fdt)
 	return 0;
-#define FDT_RW_CHECK_HEADER(fdt) \
+#define FDT_RW_PROBE(fdt) \
 		int err_; \
-		if ((err_ = fdt_rw_check_header_(fdt)) != 0) \
+		if ((err_ = fdt_rw_probe_(fdt)) != 0) \
 			return err_; \
@@ -176,7 +176,7 @@ int fdt_add_mem_rsv(void *fdt, uint64_t address, uint64_t size)
 	struct fdt_reserve_entry *re;
 	int err;
-	FDT_RW_CHECK_HEADER(fdt);
+	FDT_RW_PROBE(fdt);
 	re = fdt_mem_rsv_w_(fdt, fdt_num_mem_rsv(fdt));
 	err = fdt_splice_mem_rsv_(fdt, re, 0, 1);
@@ -192,7 +192,7 @@ int fdt_del_mem_rsv(void *fdt, int n)
 	struct fdt_reserve_entry *re = fdt_mem_rsv_w_(fdt, n);
 	if (n >= fdt_num_mem_rsv(fdt))
@@ -252,7 +252,7 @@ int fdt_set_name(void *fdt, int nodeoffset, const char *name)
 	int oldlen, newlen;
 	int err;
 	namep = (char *)(uintptr_t)fdt_get_name(fdt, nodeoffset, &oldlen);
 	if (!namep)
@@ -275,7 +275,7 @@ int fdt_setprop_placeholder(void *fdt, int nodeoffset, const char *name,
 	struct fdt_property *prop;
 	int err;
 	err = fdt_resize_property_(fdt, nodeoffset, name, len, &prop);
 	if (err == -FDT_ERR_NOTFOUND)
@@ -308,7 +308,7 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name,
 	int err, oldlen, newlen;
 	prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen);
 	if (prop) {
@@ -334,7 +334,7 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name)
 	int len, proplen;
 	prop = fdt_get_property_w(fdt, nodeoffset, name, &len);
 	if (!prop)
@@ -354,7 +354,7 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset,
 	uint32_t tag;
 	fdt32_t *endtag;
 	offset = fdt_subnode_offset_namelen(fdt, parentoffset, name, namelen);
 	if (offset >= 0)
@@ -394,7 +394,7 @@ int fdt_del_node(void *fdt, int nodeoffset)
 	int endoffset;
 	endoffset = fdt_node_end_offset_(fdt, nodeoffset);
 	if (endoffset < 0)
@@ -435,7 +435,7 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize)
 	const char *fdtend = fdtstart + fdt_totalsize(fdt);
 	char *tmp;
 	mem_rsv_size = (fdt_num_mem_rsv(fdt)+1)
 		* sizeof(struct fdt_reserve_entry);
@@ -494,7 +494,7 @@ int fdt_pack(void *fdt)
 	int mem_rsv_size;
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 6d33cc29d0..9f6fe2085d 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -55,7 +55,7 @@
-static int fdt_sw_check_header_(void *fdt)
+static int fdt_sw_probe_(void *fdt)
 	if (fdt_magic(fdt) != FDT_SW_MAGIC)
 		return -FDT_ERR_BADMAGIC;
@@ -63,10 +63,10 @@ static int fdt_sw_check_header_(void *fdt)
 	return 0;
-#define FDT_SW_CHECK_HEADER(fdt) \
+#define FDT_SW_PROBE(fdt) \
 		int err; \
-		if ((err = fdt_sw_check_header_(fdt)) != 0) \
+		if ((err = fdt_sw_probe_(fdt)) != 0) \
 			return err; \
@@ -112,7 +112,7 @@ int fdt_resize(void *fdt, void *buf, int bufsize)
 	size_t headsize, tailsize;
 	char *oldtail, *newtail;
-	FDT_SW_CHECK_HEADER(fdt);
+	FDT_SW_PROBE(fdt);
 	headsize = fdt_off_dt_struct(fdt);
 	tailsize = fdt_size_dt_strings(fdt);
@@ -144,7 +144,7 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
 	int offset;
 	if (fdt_size_dt_struct(fdt))
 		return -FDT_ERR_BADSTATE;
@@ -172,7 +172,7 @@ int fdt_begin_node(void *fdt, const char *name)
 	struct fdt_node_header *nh;
 	int namelen = strlen(name) + 1;
 	nh = fdt_grab_space_(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen));
 	if (! nh)
@@ -187,7 +187,7 @@ int fdt_end_node(void *fdt)
 	fdt32_t *en;
 	en = fdt_grab_space_(fdt, FDT_TAGSIZE);
 	if (! en)
@@ -225,7 +225,7 @@ int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp)
 	int nameoff;
 	nameoff = fdt_find_add_string_(fdt, name);
 	if (nameoff == 0)
@@ -262,7 +262,7 @@ int fdt_finish(void *fdt)
 	uint32_t tag;
 	int offset, nextoffset;
 	/* Add terminator */
 	end = fdt_grab_space_(fdt, sizeof(*end));
diff --git a/cpukit/dtc/libfdt/libfdt_internal.h b/cpukit/dtc/libfdt/libfdt_internal.h
index 7681e19229..4109f890ae 100644
--- a/cpukit/dtc/libfdt/libfdt_internal.h
+++ b/cpukit/dtc/libfdt/libfdt_internal.h
@@ -55,10 +55,11 @@
 #define FDT_ALIGN(x, a)		(((x) + (a) - 1) & ~((a) - 1))
 #define FDT_TAGALIGN(x)		(FDT_ALIGN((x), FDT_TAGSIZE))
-#define FDT_CHECK_HEADER(fdt) \
+int fdt_ro_probe_(const void *fdt);
+#define FDT_RO_PROBE(fdt)			\
 		int err_; \
-		if ((err_ = fdt_check_header(fdt)) != 0) \
+		if ((err_ = fdt_ro_probe_(fdt)) != 0)	\
 			return err_; \
2.13.7
