[PATCH 34/45] libfdt: Improve sequential write state checking
Wed Jul 18 07:35:43 UTC 2018
From: David Gibson <david at gibson.dropbear.id.au>
When creating a tree with the sequential write functions, certain things
have to be done in a certain order.  You must create the memory reserve map
and only then can you create the actual tree structure.
The -FDT_ERR_BADSTATE return code is for if you try to do things out of
order.  However, we weren't checking that very thoroughly, so it was
possible to generate a corrupted blob if, for example, you started calling
fdt_begin_node() etc. before calling fdt_finish_reservemap().
This makes the state checking more thorough disallow that.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
Tested-by: Alexey Kardashevskiy <aik at ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik at ozlabs.ru>
Reviewed-by: Simon Glass <sjg at chromium.org>
 cpukit/dtc/libfdt/fdt_sw.c | 89 ++++++++++++++++++++++++++++++++++++++--------
 1 file changed, 75 insertions(+), 14 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 9f6fe2085d..178b3657b0 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -57,9 +57,10 @@
 static int fdt_sw_probe_(void *fdt)
-	if (fdt_magic(fdt) != FDT_SW_MAGIC)
+	if (fdt_magic(fdt) == FDT_MAGIC)
+		return -FDT_ERR_BADSTATE;
+	else if (fdt_magic(fdt) != FDT_SW_MAGIC)
 		return -FDT_ERR_BADMAGIC;
-	/* FIXME: should check more details about the header state */
 	return 0;
@@ -70,6 +71,61 @@ static int fdt_sw_probe_(void *fdt)
 			return err; \
+/* 'memrsv' state:	Initial state after fdt_create()
+ * Allowed functions:
+ *	fdt_add_reservmap_entry()
+ *	fdt_finish_reservemap()		[moves to 'struct' state]
+static int fdt_sw_probe_memrsv_(void *fdt)
+	int err = fdt_sw_probe_(fdt);
+	if (err)
+		return err;
+	if (fdt_off_dt_strings(fdt) != 0)
+	return 0;
+#define FDT_SW_PROBE_MEMRSV(fdt) \
+		int err; \
+		if ((err = fdt_sw_probe_memrsv_(fdt)) != 0) \
+			return err; \
+/* 'struct' state:	Enter this state after fdt_finish_reservemap()
+ *	fdt_begin_node()
+ *	fdt_end_node()
+ *	fdt_property*()
+ *	fdt_finish()			[moves to 'complete' state]
+static int fdt_sw_probe_struct_(void *fdt)
+	if (err)
+		return err;
+	if (fdt_off_dt_strings(fdt) != fdt_totalsize(fdt))
+	return 0;
+#define FDT_SW_PROBE_STRUCT(fdt) \
+		int err; \
+		if ((err = fdt_sw_probe_struct_(fdt)) != 0) \
+			return err; \
+/* 'complete' state:	Enter this state after fdt_finish()
+ * Allowed functions: none
 static void *fdt_grab_space_(void *fdt, size_t len)
 	int offset = fdt_size_dt_struct(fdt);
@@ -102,7 +158,7 @@ int fdt_create(void *buf, int bufsize)
 	fdt_set_off_mem_rsvmap(fdt, FDT_ALIGN(sizeof(struct fdt_header),
 					      sizeof(struct fdt_reserve_entry)));
 	fdt_set_off_dt_struct(fdt, fdt_off_mem_rsvmap(fdt));
-	fdt_set_off_dt_strings(fdt, bufsize);
+	fdt_set_off_dt_strings(fdt, 0);
 	return 0;
@@ -133,8 +189,9 @@ int fdt_resize(void *fdt, void *buf, int bufsize)
 		memmove(buf, fdt, headsize);
-	fdt_set_off_dt_strings(buf, bufsize);
 	fdt_set_totalsize(buf, bufsize);
+	if (fdt_off_dt_strings(buf))
+		fdt_set_off_dt_strings(buf, bufsize);
 	return 0;
@@ -144,10 +201,7 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
 	struct fdt_reserve_entry *re;
 	int offset;
-	FDT_SW_PROBE(fdt);
-	if (fdt_size_dt_struct(fdt))
-		return -FDT_ERR_BADSTATE;
+	FDT_SW_PROBE_MEMRSV(fdt);
 	offset = fdt_off_dt_struct(fdt);
 	if ((offset + sizeof(*re)) > fdt_totalsize(fdt))
@@ -164,16 +218,23 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size)
 int fdt_finish_reservemap(void *fdt)
-	return fdt_add_reservemap_entry(fdt, 0, 0);
+	int err = fdt_add_reservemap_entry(fdt, 0, 0);
+	if (err)
+		return err;
+	fdt_set_off_dt_strings(fdt, fdt_totalsize(fdt));
+	return 0;
 int fdt_begin_node(void *fdt, const char *name)
 	struct fdt_node_header *nh;
-	int namelen = strlen(name) + 1;
+	int namelen;
+	FDT_SW_PROBE_STRUCT(fdt);
+	namelen = strlen(name) + 1;
 	nh = fdt_grab_space_(fdt, sizeof(*nh) + FDT_TAGALIGN(namelen));
 	if (! nh)
 		return -FDT_ERR_NOSPACE;
@@ -187,7 +248,7 @@ int fdt_end_node(void *fdt)
 	fdt32_t *en;
 	en = fdt_grab_space_(fdt, FDT_TAGSIZE);
 	if (! en)
@@ -225,7 +286,7 @@ int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp)
 	struct fdt_property *prop;
 	int nameoff;
 	nameoff = fdt_find_add_string_(fdt, name);
 	if (nameoff == 0)
@@ -262,7 +323,7 @@ int fdt_finish(void *fdt)
 	uint32_t tag;
 	int offset, nextoffset;
 	/* Add terminator */
 	end = fdt_grab_space_(fdt, sizeof(*end));
2.13.7
