IMFS - Impact of 32 vs 64 bit Pointers
Joel Sherrill
joel at rtems.org
Wed Jul 25 22:54:10 UTC 2018
Hi
In some recent discussions, the maximum file size supported
by the IMFS came up. I proposed increasing the allowed block
size from the maximum of 512. When asked what the impact
on maximum file size would be, I decided to hack the imfs.h
macros into a simple test program. When I ran that program
natively, it didn't produce the same maximum file sizes in
imfs.h. After some investigation, it occurred to me that the
native pointer was 64-bits and the maximum file sizes were
computed based on 32-bit pointers to the malloc'ed blocks.
$ ./imfs_size # source attached
=========== Pointer = 4 bytes ===========
16 ==> 1328 or < 1MB
32 ==> 18656 or < 1MB
64 ==> 279488 or < 1MB
128 ==> 4329344 or 4MB
256 ==> 68173568 or 65MB
512 ==> 1082195456 or 1032MB
1024 ==> 17247239168 or 16448MB
2048 ==> 275415824384 or 262656MB
=========== Pointer = 8 bytes ===========
16 ==> 208 or < 1MB
32 ==> 2656 or < 1MB
64 ==> 37312 or < 1MB
128 ==> 558976 or < 1MB
256 ==> 8658688 or 8MB
512 ==> 136347136 or 130MB
1024 ==> 2164390912 or 2064MB
2048 ==> 34494478336 or 32896MB
What this means is that on target architectures with 64-bit pointers
the maximum file size is much smaller.
I am proposing two things:
(1) that the default block size (128 now) be dependent on
whether __SIZEOF_POINTER__ is 4 or 8.
(2) that the maximum block size be increased from 512 to at
least 2048. On 32-bit pointer targets, this is ridiculously large and
on 64-bit targets, it should be large enough for any foreseeable
use case.
At the risk of increased complexity, the maximum block size could
be conditional on pointer size also. 512 for 32-bit pointers and
2K for 64-bit pointers. But I think 2K blocks has efficiency improvements
because it reduces the number of allocations and per allocation
overhead so I don't want to do this.
I am prone to even allow 4K blocks based on allocation efficiency.
The maximum filesize is likely larger than available RAM on many
boards anyway.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180725/f6ceb953/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180725/f6ceb953/attachment.obj>
