[PATCH v2 1/2] Coverage: Add support to generate separate reports for each symbol-set
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Jul 30 05:44:06 UTC 2018
On 30 July 2018 at 06:27, Chris Johns <chrisj at rtems.org> wrote:
> On 26/07/2018 01:40, Vijay Kumar Banerjee wrote:
> > Invoke covoar multiple times from the script to generate separate
> > reports for each symbol-set.
> >  tester/rt/coverage.py | 42 ++++++++++++++++++++----------------------
> >  1 file changed, 20 insertions(+), 22 deletions(-)
> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> > index 7dd5002..fe92d0a 100644
> > --- a/tester/rt/coverage.py
> > +++ b/tester/rt/coverage.py
> > @@ -100,7 +100,7 @@ class summary:
> >  class report_gen_html:
> >      def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
> I am not a fan of adding type info to variable names, for example
> 'p_symbol_sets_list' where a design change may make this a dict. Please use
> something else.
Understood. Thanks.
> > -        self.symbol_sets_list = ['score']
> > +        self.symbol_sets_list = p_symbol_sets_list
> >          self.build_dir = build_dir
> >          self.partial_reports_files = list(['index.html', 'summary.txt'])
> >          self.number_of_columns = 1
> > @@ -250,41 +250,37 @@ class symbol_parser(object):
> >          self.symbol_sets = {}
> >          self.symbol_set = symbol_set
> > -        self.ssets = []
> > +        self.symbol_set_list = []
> Same here and so on in the patch. Also I do not think this last change is
> needed.
Understood. I'll remove this last change.
> Chris
> >      def parse(self):
> >          config = configparser.ConfigParser()
> >          try:
> >              config.read(self.symbol_file)
> >              if self.symbol_set is not None:
> > -                self.ssets = self.symbol_set.split(',')
> > +                self.symbol_set_list = self.symbol_set.split(',')
> >              else:
> > -                self.ssets = config.get('symbol-sets',
> 'sets').split(',')
> > -                self.ssets = [sset.encode('utf-8') for sset in
> self.ssets]
> > -            for sset in self.ssets:
> > +                self.symbol_set_list = config.get('symbol-sets',
> 'sets').split(',')
> > +                self.symbol_set_list = [sset.encode('utf-8') for sset
> in self.symbol_set_list]
> > +            for sset in self.symbol_set_list:
> >                  lib = path.join(self.build_dir, config.get('libraries',
> sset))
> >                  self.symbol_sets[sset] = lib.encode('utf-8')
> > +            return self.symbol_set_list
> >          except:
> >              raise error.general('Symbol set parsing failed')
> > -    def _write_ini(self):
> > +    def write_ini(self, symbol_set):
> >          try:
> > -            sets = ', '.join(self.symbol_sets.keys())
> > +            sset = symbol_set
> >              config.add_section('symbol-sets')
> > -            config.set('symbol-sets', 'sets', sets)
> > -            for key in self.symbol_sets.keys():
> > -                config.add_section(key)
> > -                config.set(key, 'libraries', self.symbol_sets[key])
> > +            config.set('symbol-sets', 'sets', sset)
> > +            config.add_section(sset)
> > +            config.set(sset, 'libraries', self.symbol_sets[sset])
> >              with open(self.symbol_select_file, 'w') as conf:
> >                  config.write(conf)
> >          except:
> >              raise error.general('symbol parser write failed')
> > -    def run(self):
> > -        self.parse()
> > -        self._write_ini()
> >  class covoar(object):
> >      Covoar runner
> > @@ -371,20 +367,22 @@ class coverage_run(object):
> >                                     self.symbol_select_path,
> >                                     self.symbol_set,
> >                                     build_dir)
> > -            parser.run()
> > -            covoar_runner = covoar(self.test_dir,
> > +            symbol_set_list = parser.parse()
> > +            for sset in symbol_set_list:
> > +                parser.write_ini(sset)
> > +                covoar_runner = covoar(self.test_dir,
> >                                     self.executables,
> self.explanations_txt,
> >                                     self.trace)
> > -            covoar_runner.run('score', self.symbol_select_path)
> > -            self._generate_reports();
> > +                covoar_runner.run(sset, self.symbol_select_path)
> > +            self._generate_reports(symbol_set_list);
> >              self._summarize();
> >          finally:
> >              self._cleanup();
> > -    def _generate_reports(self):
> > +    def _generate_reports(self, symbol_sets):
> >          log.notice('Coverage generating reports')
> >          if self.report_format == 'html':
> > -            report = report_gen_html(self.symbol_sets,
> > +            report = report_gen_html(symbol_sets,
> >                                       self.build_dir,
> >                                       self.rtdir,
> >                                       self.macros['bsp'])
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180730/8f8e60b9/attachment-0002.html>
