[PATCH v3] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Jul 5 20:38:48 UTC 2018
Hello Chris,
If you find some time, please review this patch.
It's a small patch but it's important since it affects how the command
will look like.
please review if this patch is alright or we need to have a different
approach.
Thanks
On 3 July 2018 at 20:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Close #3440
> tester/rt/test.py | 21 ++++++++++++++-------
> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 1 +
> 2 files changed, 15 insertions(+), 7 deletions(-)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 9214ad6..5d25d82 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -232,7 +232,7 @@ def run(command_path = None):
> '--filter': 'Glob that executables must match
> to run (default: ' +
> default_exefilter + ')',
> '--stacktrace': 'Dump a stack trace on a user
> termination (^C)',
> - '--coverage': 'Perform coverage analysis of
> test executables.'}
> + '--coverage-sets': 'Perform coverage analysis for
> specific sets.'}
> mailer.append_options(optargs)
> opts = options.load(sys.argv,
> optargs = optargs,
> @@ -283,14 +283,21 @@ def run(command_path = None):
> raise error.general('RTEMS BSP not provided or an invalid
> option')
> bsp = config.load(bsp[1], opts)
> bsp_config = opts.defaults.expand(opts.defaults['tester'])
> - coverage_enabled = opts.find_arg('--coverage')
> + coverage_sets = opts.find_arg('--coverage-sets')
> + try:
> + coverage_enabled = opts.defaults.get('coverage')
> + except:
> + coverage_enabled = False
> if coverage_enabled:
> cov_trace = 'cov' in debug_trace.split(',')
> - if len(coverage_enabled) == 2:
> - coverage_runner = coverage.coverage_run(opts.defaults,
> - executables,
> - symbol_set =
> coverage_enabled[1],
> - trace = cov_trace)
> + if coverage_sets:
> + if len(coverage_sets) != 2:
> + raise error.general('No sets provided in
> --coverage-sets')
> + else:
> + coverage_runner = coverage.coverage_run(opts.
> defaults,
> + executables,
> + symbol_set =
> coverage_sets[1],
> + trace =
> cov_trace)
> else:
> executables,
> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> index 2f89117..6462448 100644
> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> @@ -38,3 +38,4 @@ target = sparc-rtems5
> tester = %{_rtscripts}/qemu.cfg
> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> +coverage = True
> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180706/14e9a0dd/attachment-0002.html>
