[PATCH v3] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Jul 10 12:11:15 UTC 2018
ping :)
On 6 July 2018 at 02:08, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello Chris,
> If you find some time, please review this patch.
> It's a small patch but it's important since it affects how the command
> will look like.
> please review if this patch is alright or we need to have a different
> approach.
> Thanks
> On 3 July 2018 at 20:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Close #3440
>>  tester/rt/test.py                            | 21 ++++++++++++++-------
>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini |  1 +
>>  2 files changed, 15 insertions(+), 7 deletions(-)
>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>> index 9214ad6..5d25d82 100644
>> --- a/tester/rt/test.py
>> +++ b/tester/rt/test.py
>> @@ -232,7 +232,7 @@ def run(command_path = None):
>>                      '--filter':         'Glob that executables must
>> match to run (default: ' +
>>                                default_exefilter + ')',
>>                      '--stacktrace':     'Dump a stack trace on a user
>> termination (^C)',
>> -                    '--coverage':       'Perform coverage analysis of
>> test executables.'}
>> +                    '--coverage-sets':  'Perform coverage analysis for
>> specific sets.'}
>>          mailer.append_options(optargs)
>>          opts = options.load(sys.argv,
>>                              optargs = optargs,
>> @@ -283,14 +283,21 @@ def run(command_path = None):
>>              raise error.general('RTEMS BSP not provided or an invalid
>> option')
>>          bsp = config.load(bsp[1], opts)
>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>> -        coverage_enabled = opts.find_arg('--coverage')
>> +        coverage_sets = opts.find_arg('--coverage-sets')
>> +        try:
>> +            coverage_enabled = opts.defaults.get('coverage')
>> +        except:
>> +            coverage_enabled = False
>>          if coverage_enabled:
>>              cov_trace = 'cov' in debug_trace.split(',')
>> -            if len(coverage_enabled) == 2:
>> -                coverage_runner = coverage.coverage_run(opts.defaults,
>> -                                                        executables,
>> -                                                        symbol_set =
>> coverage_enabled[1],
>> -                                                        trace =
>> cov_trace)
>> +            if coverage_sets:
>> +                if len(coverage_sets) != 2:
>> +                    raise error.general('No sets provided in
>> --coverage-sets')
>> +                else:
>> +                    coverage_runner = coverage.coverage_run(opts.def
>> aults,
>> +                                                            executables,
>> +                                                            symbol_set =
>> coverage_sets[1],
>> +                                                            trace =
>> cov_trace)
>>              else:
>>                                                          executables,
>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> index 2f89117..6462448 100644
>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> @@ -38,3 +38,4 @@ target            = sparc-rtems5
>>  tester            = %{_rtscripts}/qemu.cfg
>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>> +coverage          = True
>> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180710/12e72b04/attachment-0002.html>
