jffs2 changes and Coverity issue in porting code
Fri Jul 6 12:52:41 UTC 2018
On 06/07/18 14:44, Joel Sherrill wrote:
> On Fri, Jul 6, 2018, 12:19 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello Joel,
>     On 05/07/18 17:52, Joel Sherrill wrote:
>     > Hi
>     > By any chance, do any of the jffs2 updates pick up changes
>     > to that method in the porting layer which Coverity thought
>     > had an issue?
>     > I know the code is the same across multiple OSes and you
>     > didn't invent or modify it porting jffs2 to RTEMS. Just curious
>     > if the situation might have changed.
>     you mean this one:
>     https://lists.rtems.org/pipermail/devel/2014-November/009331.html
>     The eCos upstream seems to be dead. So, we have to fix this on our
>     own.
>     Would it be possible to run Coverity with the latest RTEMS?
> I will try to do this next week. All the computers at OAR are down.
Ok, thanks. No need to hurry. I am not in the office next week.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
