[PATCH] score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE()
Joel Sherrill
joel at rtems.org
Tue Jul 24 12:14:55 UTC 2018
On Tue, Jul 24, 2018, 2:03 AM Sebastian Huber <
> Add RTEMS_PREDICT_TRUE() and RTEMS_PREDICT_FALSE() for static branch
> prediction hints.
> Close #3475.
> cpukit/include/rtems/score/basedefs.h | 28 ++++++++++++++++++++++++++++
> cpukit/posix/src/sempost.c | 4 ++--
> cpukit/posix/src/semtimedwait.c | 2 +-
> cpukit/posix/src/semtrywait.c | 2 +-
> cpukit/score/src/condition.c | 4 +++-
> cpukit/score/src/futex.c | 2 +-
> cpukit/score/src/mutex.c | 16 ++++++++--------
> cpukit/score/src/semaphore.c | 10 +++++-----
> testsuites/sptests/spmisc01/init.c | 25 +++++++++++++++++++++++++
> 9 files changed, 74 insertions(+), 19 deletions(-)
> diff --git a/cpukit/include/rtems/score/basedefs.h
> b/cpukit/include/rtems/score/basedefs.h
> index 8169f6db8c..7a52de895d 100644
> --- a/cpukit/include/rtems/score/basedefs.h
> +++ b/cpukit/include/rtems/score/basedefs.h
> @@ -281,6 +281,34 @@
> #define RTEMS_DEFINE_GLOBAL_SYMBOL( _name, _value )
> #endif
> + * @brief Returns the value of the specified integral expressen and tells
> the
Spelling error here and in the other comment block. Search to make sure it
isn't elsewhere.
+ * compiler that the predicted value is true (1).
> + * @param[in] _exp The expression.
> + * @return The value of the expression.
> +#if defined(__GNUC__)
> + #define RTEMS_PREDICT_TRUE( _exp ) __builtin_expect( ( _exp ), 1 )
> +#else
> + #define RTEMS_PREDICT_TRUE( _exp ) ( _exp )
> +#endif
> the
> + * compiler that the predicted value is false (0).
> + #define RTEMS_PREDICT_FALSE( _exp ) __builtin_expect( ( _exp ), 0 )
> +#else
> + #define RTEMS_PREDICT_FALSE( _exp ) ( _exp )
> +#endif
> #if __cplusplus >= 201103L
> #define RTEMS_STATIC_ASSERT(cond, msg) \
> static_assert(cond, # msg)
> diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
> index de0ae71fc7..d750c1178c 100644
> --- a/cpukit/posix/src/sempost.c
> +++ b/cpukit/posix/src/sempost.c
> @@ -40,13 +40,13 @@ int sem_post( sem_t *_sem )
> heads = sem->Queue.Queue.heads;
> count = sem->count;
> - if ( __predict_true( heads == NULL && count < SEM_VALUE_MAX ) ) {
> + if ( RTEMS_PREDICT_TRUE( heads == NULL && count < SEM_VALUE_MAX ) ) {
> sem->count = count + 1;
> _Sem_Queue_release( sem, level, &queue_context );
> return 0;
> - if ( __predict_true( heads != NULL ) ) {
> + if ( RTEMS_PREDICT_TRUE( heads != NULL ) ) {
> const Thread_queue_Operations *operations;
> Thread_Control *first;
> diff --git a/cpukit/posix/src/semtimedwait.c
> b/cpukit/posix/src/semtimedwait.c
> index 9e7bb466dd..16d0c24c9f 100644
> --- a/cpukit/posix/src/semtimedwait.c
> +++ b/cpukit/posix/src/semtimedwait.c
> @@ -46,7 +46,7 @@ int sem_timedwait(
> executing = _Sem_Queue_acquire_critical( sem, &queue_context );
> count = sem->count;
> - if ( __predict_true( count > 0 ) ) {
> + if ( RTEMS_PREDICT_TRUE( count > 0 ) ) {
> sem->count = count - 1;
> return 0;
> diff --git a/cpukit/posix/src/semtrywait.c b/cpukit/posix/src/semtrywait.c
> index 673343d4b4..759744ec8e 100644
> --- a/cpukit/posix/src/semtrywait.c
> +++ b/cpukit/posix/src/semtrywait.c
> @@ -35,7 +35,7 @@ int sem_trywait( sem_t *_sem )
> count = sem->count;
> return 0;
> diff --git a/cpukit/score/src/condition.c b/cpukit/score/src/condition.c
> index 9913d86d34..892245baf5 100644
> --- a/cpukit/score/src/condition.c
> +++ b/cpukit/score/src/condition.c
> @@ -279,7 +279,9 @@ static void _Condition_Wake( struct _Condition_Control
> *_condition, int count )
> * In common uses cases of condition variables there are normally no
> threads
> * on the queue, so check this condition early.
> - if ( __predict_true( _Thread_queue_Is_empty( &condition->Queue.Queue )
> + if (
> + RTEMS_PREDICT_TRUE( _Thread_queue_Is_empty( &condition->Queue.Queue )
> _Condition_Queue_release( condition, &context.Base );
> return;
> diff --git a/cpukit/score/src/futex.c b/cpukit/score/src/futex.c
> index 6487882819..f32a13c449 100644
> --- a/cpukit/score/src/futex.c
> +++ b/cpukit/score/src/futex.c
> @@ -151,7 +151,7 @@ int _Futex_Wake( struct _Futex_Control *_futex, int
> count )
> * called in the fast path. Normally there are no threads on the
> queue, so
> * check this condition early.
> - if ( __predict_true( _Thread_queue_Is_empty( &futex->Queue.Queue ) ) ) {
> + if ( RTEMS_PREDICT_TRUE( _Thread_queue_Is_empty( &futex->Queue.Queue )
> _Futex_Queue_release( futex, level, &context.Base );
> return 0;
> diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
> index e2f5bb52fc..8cc47f28bb 100644
> --- a/cpukit/score/src/mutex.c
> +++ b/cpukit/score/src/mutex.c
> @@ -128,7 +128,7 @@ static void _Mutex_Release_critical(
> mutex->Queue.Queue.owner = NULL;
> _Thread_Resource_count_decrement( executing );
> - if ( __predict_true( heads == NULL ) ) {
> + if ( RTEMS_PREDICT_TRUE( heads == NULL ) ) {
> _Mutex_Queue_release( mutex, level, queue_context );
> } else {
> _Thread_queue_Context_set_ISR_level( queue_context, level );
> @@ -157,7 +157,7 @@ void _Mutex_Acquire( struct _Mutex_Control *_mutex )
> owner = mutex->Queue.Queue.owner;
> - if ( __predict_true( owner == NULL ) ) {
> + if ( RTEMS_PREDICT_TRUE( owner == NULL ) ) {
> mutex->Queue.Queue.owner = executing;
> _Thread_Resource_count_increment( executing );
> _Mutex_Queue_release( mutex, level, &queue_context );
> @@ -185,7 +185,7 @@ int _Mutex_Acquire_timed(
> @@ -218,7 +218,7 @@ int _Mutex_Try_acquire( struct _Mutex_Control *_mutex )
> eno = 0;
> @@ -270,7 +270,7 @@ void _Mutex_recursive_Acquire( struct
> _Mutex_recursive_Control *_mutex )
> owner = mutex->Mutex.Queue.Queue.owner;
> mutex->Mutex.Queue.Queue.owner = executing;
> _Mutex_Queue_release( &mutex->Mutex, level, &queue_context );
> @@ -301,7 +301,7 @@ int _Mutex_recursive_Acquire_timed(
> @@ -339,7 +339,7 @@ int _Mutex_recursive_Try_acquire( struct
> eno = 0;
> @@ -372,7 +372,7 @@ void _Mutex_recursive_Release( struct
> nest_level = mutex->nest_level;
> - if ( __predict_true( nest_level == 0 ) ) {
> + if ( RTEMS_PREDICT_TRUE( nest_level == 0 ) ) {
> _Mutex_Release_critical( &mutex->Mutex, executing, level,
> &queue_context );
> } else {
> mutex->nest_level = nest_level - 1;
> diff --git a/cpukit/score/src/semaphore.c b/cpukit/score/src/semaphore.c
> index f76ee332a4..f9b8b48fe1 100644
> --- a/cpukit/score/src/semaphore.c
> +++ b/cpukit/score/src/semaphore.c
> @@ -53,7 +53,7 @@ void _Semaphore_Wait( struct _Semaphore_Control *_sem )
> count = sem->count;
> } else {
> @@ -86,7 +86,7 @@ int _Semaphore_Wait_timed_ticks( struct
> _Semaphore_Control *_sem, uint32_t ticks
> count = sem->count;
> return 0;
> @@ -121,7 +121,7 @@ int _Semaphore_Try_wait( struct _Semaphore_Control
> *_sem )
> count = sem->count;
> eno = 0;
> } else {
> @@ -145,7 +145,7 @@ void _Semaphore_Post( struct _Semaphore_Control *_sem )
> ++sem->count;
> } else {
> @@ -178,7 +178,7 @@ void _Semaphore_Post_binary( struct _Semaphore_Control
> *_sem )
> sem->count = 1;
> } else {
> diff --git a/testsuites/sptests/spmisc01/init.c
> b/testsuites/sptests/spmisc01/init.c
> index 4fab3f0e84..c406cd07aa 100644
> --- a/testsuites/sptests/spmisc01/init.c
> +++ b/testsuites/sptests/spmisc01/init.c
> @@ -229,6 +229,31 @@ static void Init(rtems_task_argument arg)
> rtems_test_assert(RTEMS_XCONCAT(CON, CAT)() == 91);
> rtems_test_assert(strcmp(RTEMS_STRING(str), "str") == 0);
> rtems_test_assert(strcmp(RTEMS_XSTRING(STR), "ing") == 0);
> + if (RTEMS_PREDICT_TRUE(true)) {
> + rtems_test_assert(true);
> + } else {
> + rtems_test_assert(false);
> + if (RTEMS_PREDICT_FALSE(true)) {
> + } else {
> + if (RTEMS_PREDICT_TRUE(false)) {
> + } else {
> + if (RTEMS_PREDICT_FALSE(false)) {
> + } else {
> TEST_END();
> rtems_test_exit(0);
> 2.13.7
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180724/0fea55ac/attachment-0002.html>
