[PATCH v2 2/2] coverage/symbol-sets.ini : Add symbol-sets and paths to respective libraries
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Jul 26 17:50:49 UTC 2018
On Thu, Jul 26, 2018, 10:34 PM Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> Kryzstof is the original author, so his name should probably stick. You
> could add lines for
> Reviewed by: Vijay on date: ...
> I think that's standard enough
> All the best,
> Cillian
Thanks for the reply and for all the help
throughout the summer. It was a great
experience !!
>> On Thu, 26 Jul 2018, 17:22 Vijay Kumar Banerjee, <
> vijaykumar9597 at gmail.com> wrote:
>> Hello,
>> I have a question which I forgot to ask before.
>> Should the coverage.py and symbol-sets.ini files have mine and/or
>> Cillian's name
>> included in the copyright notice?
>> --vijayk
>> On 26 July 2018 at 13:09, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> I have added all the libs in cpukit and commented them out.
>>> Please have a look at the attached file.
>>> On 26 July 2018 at 04:50, Joel Sherrill <joel at rtems.org> wrote:
>>>> On Wed, Jul 25, 2018 at 10:41 AM, Vijay Kumar Banerjee <
>>>>>  tester/rtems/testing/coverage/symbol-sets.ini | 11 ++++++++---
>>>>>  1 file changed, 8 insertions(+), 3 deletions(-)
>>>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> index a2ec7bc..3900f14 100644
>>>>> --- a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> @@ -29,8 +29,13 @@
>>>>>  [symbol-sets]
>>>>> -sets = score,rtems
>>>>> +sets = score,rtems,libblock,libcrypt,libcsupport,libmd,libnetworking
>>>>>  [libraries]
>>>>> -score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>> -rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>> +score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>> +rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>> +libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
>>>>> +libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
>>>>> +libcsupport   = @BUILD-TARGET@/c/@BSP@
>>>>> /cpukit/libcsupport/libcsupport.a
>>>>> +libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
>>>>> +libnetworking = @BUILD-TARGET@/c/@BSP@
>>>>> /cpukit/libnetworking/libnetworking.a
>>>> To be at parity with the old reports but reported on finer granularity,
>>>> follow the list at
>>>> https://git.rtems.org/rtems-testing/tree/rtems-coverage/do_coverage#n507
>>>> and check what is not listed there that is in cpukit now.  For example,
>>>> jffs2
>>>> isn't listed in the above. But the things consciously skipped have a
>>>> good
>>>> reason. Add a list of the ones not included. It may make sense to
>>>> have something like this for the ones deliberately skipped:
>>>> # librpc = @....libXXX.a
>>>> It will make auditing what's in the cpukit versus the ini file easier.
>>>> That's why my old script has them in order and commented out the
>>>> ones we were not ready to do or never would.
>>>> But for sure, add posix, sapi, libdl, individual filesystem, and catch
>>>> the libmisc subdirectories listed in the old script for inclusion. for
>>>> new
>>>> libmisc content, we can make a decision.
>>>> Don't include libnetworking. As a general rule, we don't do coverage
>>>> testing
>>>> on networking or any  (complex) third party software.
>>>> I don't think dtc will get coverage either.
>>>> That should get us closer. I expect you will find some libraries
>>>> to ask questions on. :)
>>>> --joel
>>>>> 2.14.4
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180726/dcca76ae/attachment-0002.html>
