[PATCH] Coverage: Add support to generate separate reports for each symbol-set
Gedare Bloom
gedare at rtems.org
Mon Jul 30 16:24:10 UTC 2018
On Mon, Jul 30, 2018 at 3:30 AM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> Invoke covoar multiple times from the script to generate separate
> reports for each symbol-set.
> tester/rt/coverage.py | 32 +++++++++++++++-----------------
> 1 file changed, 15 insertions(+), 17 deletions(-)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index 7dd5002..99342e1 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -100,7 +100,7 @@ class summary:
> class report_gen_html:
> def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
> - self.symbol_sets_list = ['score']
> + self.symbol_sets_list = p_symbol_sets_list
This is still encoding _list in the names of these variables
> self.build_dir = build_dir
> self.partial_reports_files = list(['index.html', 'summary.txt'])
> self.number_of_columns = 1
> @@ -264,27 +264,23 @@ class symbol_parser(object):
> for sset in self.ssets:
> lib = path.join(self.build_dir, config.get('libraries', sset))
> self.symbol_sets[sset] = lib.encode('utf-8')
> + return self.ssets
> except:
> raise error.general('Symbol set parsing failed')
> - def _write_ini(self):
> + def write_ini(self, symbol_set):
> config = configparser.ConfigParser()
> try:
> - sets = ', '.join(self.symbol_sets.keys())
> + sset = symbol_set
> config.add_section('symbol-sets')
> - config.set('symbol-sets', 'sets', sets)
> - for key in self.symbol_sets.keys():
> - config.add_section(key)
> - config.set(key, 'libraries', self.symbol_sets[key])
> + config.set('symbol-sets', 'sets', sset)
> + config.add_section(sset)
> + config.set(sset, 'libraries', self.symbol_sets[sset])
> with open(self.symbol_select_file, 'w') as conf:
> config.write(conf)
> except:
> raise error.general('symbol parser write failed')
> - def run(self):
> - self.parse()
> - self._write_ini()
> class covoar(object):
> Covoar runner
> @@ -371,20 +367,22 @@ class coverage_run(object):
> self.symbol_select_path,
> self.symbol_set,
> build_dir)
> - parser.run()
> - covoar_runner = covoar(self.test_dir, self.symbol_select_path,
> + symbol_sets = parser.parse()
> + for sset in symbol_sets:
> + parser.write_ini(sset)
> + covoar_runner = covoar(self.test_dir, self.symbol_select_path,
> self.executables, self.explanations_txt,
> self.trace)
> - covoar_runner.run('score', self.symbol_select_path)
> - self._generate_reports();
> + covoar_runner.run(sset, self.symbol_select_path)
> + self._generate_reports(symbol_sets);
> self._summarize();
> finally:
> self._cleanup();
> - def _generate_reports(self):
> + def _generate_reports(self, symbol_sets):
> log.notice('Coverage generating reports')
> if self.report_format == 'html':
> - report = report_gen_html(self.symbol_sets,
> + report = report_gen_html(symbol_sets,
> self.build_dir,
> self.rtdir,
> self.macros['bsp'])
> 2.14.4
> devel mailing list
> devel at rtems.org
