[PATCH] Coverage: Add support to generate separate reports for each symbol-set
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Jul 30 16:33:18 UTC 2018
On 30 July 2018 at 21:54, Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Jul 30, 2018 at 3:30 AM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > Invoke covoar multiple times from the script to generate separate
> > reports for each symbol-set.
> >  tester/rt/coverage.py | 32 +++++++++++++++-----------------
> >  1 file changed, 15 insertions(+), 17 deletions(-)
> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> > index 7dd5002..99342e1 100644
> > --- a/tester/rt/coverage.py
> > +++ b/tester/rt/coverage.py
> > @@ -100,7 +100,7 @@ class summary:
> >  class report_gen_html:
> >      def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
> > -        self.symbol_sets_list = ['score']
> > +        self.symbol_sets_list = p_symbol_sets_list
> This is still encoding _list in the names of these variables
Sorry about this. Will change it. :)
> >          self.build_dir = build_dir
> >          self.partial_reports_files = list(['index.html', 'summary.txt'])
> >          self.number_of_columns = 1
> > @@ -264,27 +264,23 @@ class symbol_parser(object):
> >              for sset in self.ssets:
> >                  lib = path.join(self.build_dir, config.get('libraries',
> sset))
> >                  self.symbol_sets[sset] = lib.encode('utf-8')
> > +            return self.ssets
> >          except:
> >              raise error.general('Symbol set parsing failed')
> > -    def _write_ini(self):
> > +    def write_ini(self, symbol_set):
> >          config = configparser.ConfigParser()
> >          try:
> > -            sets = ', '.join(self.symbol_sets.keys())
> > +            sset = symbol_set
> >              config.add_section('symbol-sets')
> > -            config.set('symbol-sets', 'sets', sets)
> > -            for key in self.symbol_sets.keys():
> > -                config.add_section(key)
> > -                config.set(key, 'libraries', self.symbol_sets[key])
> > +            config.set('symbol-sets', 'sets', sset)
> > +            config.add_section(sset)
> > +            config.set(sset, 'libraries', self.symbol_sets[sset])
> >              with open(self.symbol_select_file, 'w') as conf:
> >                  config.write(conf)
> >          except:
> >              raise error.general('symbol parser write failed')
> > -    def run(self):
> > -        self.parse()
> > -        self._write_ini()
> >  class covoar(object):
> >      Covoar runner
> > @@ -371,20 +367,22 @@ class coverage_run(object):
> >                                     self.symbol_select_path,
> >                                     self.symbol_set,
> >                                     build_dir)
> > -            parser.run()
> > -            covoar_runner = covoar(self.test_dir,
> > +            symbol_sets = parser.parse()
> > +            for sset in symbol_sets:
> > +                parser.write_ini(sset)
> > +                covoar_runner = covoar(self.test_dir,
> >                                     self.executables,
> self.explanations_txt,
> >                                     self.trace)
> > -            covoar_runner.run('score', self.symbol_select_path)
> > -            self._generate_reports();
> > +                covoar_runner.run(sset, self.symbol_select_path)
> > +            self._generate_reports(symbol_sets);
> >              self._summarize();
> >          finally:
> >              self._cleanup();
> > -    def _generate_reports(self):
> > +    def _generate_reports(self, symbol_sets):
> >          log.notice('Coverage generating reports')
> >          if self.report_format == 'html':
> > -            report = report_gen_html(self.symbol_sets,
> > +            report = report_gen_html(symbol_sets,
> >                                       self.build_dir,
> >                                       self.rtdir,
> >                                       self.macros['bsp'])
> > 2.14.4
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180730/70799773/attachment-0002.html>
