[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Jun 1 07:46:38 UTC 2018
Here's the list of Ideas for improvements:
1. Include the section coverage in the bsp config file.
If the section is not found then the script will show
proper error showing coverage is not supported for the
provided bsp config file.
2. Update covoar to add support for separate coverage report
for each symbol set.
3. Add a method somewhere in covoar to get the size of an instruction
and fix the hard coded size 4 in ObjdumpProcessor.cc
On 1 June 2018 at 04:43, Joel Sherrill <joel at rtems.org> wrote:
> Just chatted with Chris. The coverage BSP ini file was a temporary
> measure as I thought.
> Make a list of all the ideas we have had for improvements. We want
> the code to get onto master.
> The list should be converted to Trac tickets very soon. Then we can
> decide which are critical for GSoC, which Chris or I will work on, and
> which are part of your GSoC.
> --joel
> On Thu, May 31, 2018 at 5:18 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On Fri, 1 Jun 2018, 03:40 Joel Sherrill, <joel at rtems.org> wrote:
>>> On Thu, May 31, 2018 at 4:57 PM, Vijay Kumar Banerjee <
>>>> On 1 June 2018 at 02:50, Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Thu, May 31, 2018 at 4:15 PM, Cillian O'Donnell <
>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>> On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <
>>>>>>> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> There is now a seperate bsp config for coverage, leon3-qemu-cov.
>>>>>>>> That is enough to trigger coverage now and --coverage could be reserved for
>>>>>>>> picking sets, probably renamed to --coverage-sets=... Or require sets to be
>>>>>>>> chosen --coverage-sets=all or specific sets --coverage-sets=score,sapi,cor
>>>>>>>> e
>>>>>>>> Actually the idea of having separate bsp configs for cov
>>>>>>> in each of the bsps will create a lot of files. The intention is
>>>>>>> to make it simple for the user. just adding --coverage
>>>>>>> should run coverage analysis. There's a plan to include
>>>>>>> the 'coverage' section into the bsp ini file, and hence the user
>>>>>>> wouldn't
>>>>>>> have to keep switching the bsp config files.
>>>>>> Actually that's exactly the way I had it working before Chris' recent
>>>>>> changes, he had a look at the way it's working and chose to create seperate
>>>>>> bsp config files. That may be the way he'd prefer. This was before the
>>>>>> --coverage option had another use other than triggering coverage, so his
>>>>>> thoughts may have changed on it.
>>>>> Chris should comment on the separate ini files. I think that might
>>>>> have been
>>>>> driven by couverture vs regular qemu before couverture was available
>>>>> from
>>>>> the RSB.
>>>>> Okay, we wait for Chris to comment on it then.
>>>>> I think it would be nice to have --coverage and if the BSP ini file
>>>>> doesn't support
>>>>> coverage, give an error.
>>>> Is the set option in the Python and processed by covoar in a way that
>>>>> still
>>>>> lets covoar be used on something besides RTEMS?
>>>> yes, it is totally handled by the script to 'feed' covoar with the
>>>> options,
>>>> without changing the way it works.
>>>> I have a question/doubt.
>>>> By adding separate bsp config for cov. Are we not assuming that
>>>> the provided bsp ini supports coverage ?
>>> I think having two leon3 configurations like we do now is temporary
>>> just to have something that works. Any changes to the coverage
>>> version don't impact the baseline.
>> Understood. Thanks.
>>> I am hoping Chris has an idea to unified these. :)
>>>>>>> The idea of modifying it to --coverage-sets=all ;
>>>>>>> --coverage-sets=set1,set2,set3..... can surely be implemented
>>>>>>> in place of --coverage ; --coverage=set1,set2....
>>>>>>>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>>>>>>>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> So is it checking whether it's --coverage or
>>>>>>>>>> --coverage=set1,set2? Are those the 2 possibilities your checking?
>>>>>>>>>> Yes, right. :)
>>>>>>>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>>>>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <
>>>>>>>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>>>>>>>> >> wrote:
>>>>>>>>>>>> >>> Add support in tester to run covoar and generate an html
>>>>>>>>>>>> report to
>>>>>>>>>>>> >>> display
>>>>>>>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>>>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>>>>>> >>> tester/rt/coverage.py | 379
>>>>>>>>>>>> >>> tester/rt/test.py | 36 ++-
>>>>>>>>>>>> >>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>>>>>>>>>>> >>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>>>>>>>>>>> >>> tester/rtems/testing/qemu.cfg | 4 +-
>>>>>>>>>>>> >>> 5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>>>>>>>> >>> create mode 100644 tester/rt/coverage.py
>>>>>>>>>>>> >>> create mode 100644 tester/rtems/testing/coverage/
>>>>>>>>>>>> symbol-sets.ini
>>>>>>>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>>>>>>>> >>> new file mode 100644
>>>>>>>>>>>> >>> index 0000000..25fbb9d
>>>>>>>>>>>> >>> --- /dev/null
>>>>>>>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>>>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>>>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>>>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>>>>>>>> >>> +# All rights reserved.
>>>>>>>>>>>> >>> +# This file is part of the RTEMS Tools package in
>>>>>>>>>>>> 'rtems-tools'.
>>>>>>>>>>>> >>> +# Redistribution and use in source and binary forms, with
>>>>>>>>>>>> or without
>>>>>>>>>>>> >>> +# modification, are permitted provided that the following
>>>>>>>>>>>> conditions are
>>>>>>>>>>>> >>> met:
>>>>>>>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>>>>>>>> copyright
>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>>>>>>>> >>> +# 2. Redistributions in binary form must reproduce the
>>>>>>>>>>>> above copyright
>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>> >>> +# this list of conditions and the following disclaimer in
>>>>>>>>>>>> the
>>>>>>>>>>>> >>> documentation
>>>>>>>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>>>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>>>> >>> 'AS IS'
>>>>>>>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT
>>>>>>>>>>>> NOT LIMITED TO,
>>>>>>>>>>>> >>> THE
>>>>>>>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>>>>>> PARTICULAR
>>>>>>>>>>>> >>> PURPOSE
>>>>>>>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER
>>>>>>>>>>>> OR CONTRIBUTORS
>>>>>>>>>>>> >>> BE
>>>>>>>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
>>>>>>>>>>>> PROFITS; OR
>>>>>>>>>>>> >>> BUSINESS
>>>>>>>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
>>>>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>>>>> >>> IN
>>>>>>>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
>>>>>>>>>>>> NEGLIGENCE OR
>>>>>>>>>>>> >>> OTHERWISE)
>>>>>>>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
>>>>>>>>>>>> IF ADVISED OF
>>>>>>>>>>>> >>> THE
>>>>>>>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>>>>>>>> >>> +from rtemstoolkit import error
>>>>>>>>>>>> >>> +from rtemstoolkit import path
>>>>>>>>>>>> >>> +from rtemstoolkit import log
>>>>>>>>>>>> >>> +from rtemstoolkit import execute
>>>>>>>>>>>> >>> +from rtemstoolkit import macros
>>>>>>>>>>>> >>> +from datetime import datetime
>>>>>>>>>>>> >>> +from . import options
>>>>>>>>>>>> >>> +import shutil
>>>>>>>>>>>> >>> +import os
>>>>>>>>>>>> >>> +try:
>>>>>>>>>>>> >>> + import configparser
>>>>>>>>>>>> >>> +except:
>>>>>>>>>>>> >>> + import ConfigParser as configparser
>>>>>>>>>>>> >>> +class summary:
>>>>>>>>>>>> >>> + def __init__(self, p_summary_dir):
>>>>>>>>>>>> >>> + self.summary_file_path = path.join(p_summary_dir,
>>>>>>>>>>>> 'summary.txt')
>>>>>>>>>>>> >>> + self.index_file_path = path.join(p_summary_dir,
>>>>>>>>>>>> 'index.html')
>>>>>>>>>>>> >>> + self.bytes_analyzed = 0
>>>>>>>>>>>> >>> + self.bytes_not_executed = 0
>>>>>>>>>>>> >>> + self.percentage_executed = 0.0
>>>>>>>>>>>> >>> + self.percentage_not_executed = 100.0
>>>>>>>>>>>> >>> + self.ranges_uncovered = 0
>>>>>>>>>>>> >>> + self.branches_uncovered = 0
>>>>>>>>>>>> >>> + self.branches_total = 0
>>>>>>>>>>>> >>> + self.branches_always_taken = 0
>>>>>>>>>>>> >>> + self.branches_never_taken = 0
>>>>>>>>>>>> >>> + self.percentage_branches_covered = 0.0
>>>>>>>>>>>> >>> + self.is_failure = False
>>>>>>>>>>>> >>> + def parse(self):
>>>>>>>>>>>> >>> + if(not path.exists(self.summary_file_path)):
>>>>>>>>>>>> >>> + log.notice('summary file %s does not exist!' %
>>>>>>>>>>>> >>> + self.is_failure = True
>>>>>>>>>>>> >>> + return
>>>>>>>>>>>> >>> + with open(self.summary_file_path,'r') as
>>>>>>>>>>>> summary_file:
>>>>>>>>>>>> self._get_next_with_colon(summary_file)
>>>>>>>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>>>>>>>> >>> + if len(self.branches_uncovered) > 0 and
>>>>>>>>>>>> len(self.branches_total)
>>>>>>>>>>>> >>> > 0:
>>>>>>>>>>>> >>> + self.percentage_branches_covered = \
>>>>>>>>>>>> >>> + 1 - (float(self.branches_uncovered) /
>>>>>>>>>>>> >>> float(self.branches_total))
>>>>>>>>>>>> >>> + else:
>>>>>>>>>>>> >>> + return
>>>>>>>>>>>> >>> + def _get_next_with_colon(self, summary_file):
>>>>>>>>>>>> >>> + line = summary_file.readline()
>>>>>>>>>>>> >>> + if ':' in line:
>>>>>>>>>>>> >>> + return line.split(':')[1].strip()
>>>>>>>>>>>> >>> + else:
>>>>>>>>>>>> >>> + return ''
>>>>>>>>>>>> >>> + def _get_next_without_colon(self, summary_file):
>>>>>>>>>>>> >>> + return line.strip().split(' ')[0]
>>>>>>>>>>>> >>> +class report_gen_html:
>>>>>>>>>>>> >>> + def __init__(self, p_symbol_sets_list, build_dir,
>>>>>>>>>>>> rtdir):
>>>>>>>>>>>> >>> + self.symbol_sets_list = ['score']
>>>>>>>>>>>> >>> + self.build_dir = build_dir
>>>>>>>>>>>> >>> + self.partial_reports_files = list(["index.html",
>>>>>>>>>>>> "summary.txt"])
>>>>>>>>>>>> >>> + self.number_of_columns = 1
>>>>>>>>>>>> >>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>>>>>>>> >>> + def _find_partial_reports(self):
>>>>>>>>>>>> >>> + partial_reports = {}
>>>>>>>>>>>> >>> + for symbol_set in self.symbol_sets_list:
>>>>>>>>>>>> >>> + set_summary = summary(path.join(self.build_dir,
>>>>>>>>>>>> "coverage",
>>>>>>>>>>>> >>> + symbol_set))
>>>>>>>>>>>> >>> + set_summary.parse()
>>>>>>>>>>>> >>> + partial_reports[symbol_set] = set_summary
>>>>>>>>>>>> >>> + return partial_reports
>>>>>>>>>>>> >>> + def _prepare_head_section(self):
>>>>>>>>>>>> >>> + head_section = '''
>>>>>>>>>>>> >>> + <head>
>>>>>>>>>>>> >>> + <title>RTEMS coverage report</title>
>>>>>>>>>>>> >>> + <style type="text/css">
>>>>>>>>>>>> >>> + progress[value] {
>>>>>>>>>>>> >>> + -webkit-appearance: none;
>>>>>>>>>>>> >>> + appearance: none;
>>>>>>>>>>>> >>> + width: 150px;
>>>>>>>>>>>> >>> + height: 15px;
>>>>>>>>>>>> >>> + </style>
>>>>>>>>>>>> >>> + </head>'''
>>>>>>>>>>>> >>> + return head_section
>>>>>>>>>>>> >>> + def _prepare_index_content(self, partial_reports):
>>>>>>>>>>>> >>> + header = "<h1> RTEMS coverage analysis report
>>>>>>>>>>>> </h1>"
>>>>>>>>>>>> >>> + header += "<h3>Coverage reports by symbols
>>>>>>>>>>>> sets:</h3>"
>>>>>>>>>>>> >>> + table = "<table>"
>>>>>>>>>>>> >>> + table += self._header_row()
>>>>>>>>>>>> >>> + for symbol_set in partial_reports:
>>>>>>>>>>>> >>> + table += self._row(symbol_set,
>>>>>>>>>>>> partial_reports[symbol_set])
>>>>>>>>>>>> >>> + table += "</table> </br>"
>>>>>>>>>>>> >>> + timestamp = "Analysis performed on " +
>>>>>>>>>>>> datetime.now().ctime()
>>>>>>>>>>>> >>> + return "<body>\n" + header + table + timestamp +
>>>>>>>>>>>> "\n</body>"
>>>>>>>>>>>> >>> + def _row(self, symbol_set, summary):
>>>>>>>>>>>> >>> + row = "<tr>"
>>>>>>>>>>>> >>> + row += "<td>" + symbol_set + "</td>"
>>>>>>>>>>>> >>> + if summary.is_failure:
>>>>>>>>>>>> >>> + row += ' <td colspan="' +
>>>>>>>>>>>> str(self.number_of_columns-1) \
>>>>>>>>>>>> >>> + + '" style="background-color:red">F
>>>>>>>>>>>> AILURE</td>'
>>>>>>>>>>>> >>> + else:
>>>>>>>>>>>> >>> + row += " <td>" + self._link(summary.index_file_
>>>>>>>>>>>> path,"Index")
>>>>>>>>>>>> >>> + + "</td>"
>>>>>>>>>>>> >>> + row += " <td>" +
>>>>>>>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>>>>>>>> >>> + + "</td>"
>>>>>>>>>>>> >>> + row += " <td>" + summary.bytes_analyzed +
>>>>>>>>>>>> "</td>"
>>>>>>>>>>>> >>> + row += " <td>" + summary.bytes_not_executed +
>>>>>>>>>>>> "</td>"
>>>>>>>>>>>> >>> + row += " <td>" + summary.ranges_uncovered +
>>>>>>>>>>>> "</td>"
>>>>>>>>>>>> >>> + row += " <td>" + summary.percentage_executed +
>>>>>>>>>>>> "%</td>"
>>>>>>>>>>>> >>> + row += " <td>" + summary.percentage_not_executed
>>>>>>>>>>>> + "%</td>"
>>>>>>>>>>>> >>> + row += ' <td><progress value="' +
>>>>>>>>>>>> >>> summary.percentage_executed \
>>>>>>>>>>>> >>> + + '" max="100"></progress></td>'
>>>>>>>>>>>> >>> + row += " <td>" + summary.branches_uncovered +
>>>>>>>>>>>> "</td>"
>>>>>>>>>>>> >>> + row += " <td>" + summary.branches_total +
>>>>>>>>>>>> "</td>"
>>>>>>>>>>>> >>> + row += " <td> {:.3%}
>>>>>>>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>>>>>>>> >>> + row += ' <td><progress value="{:.3}"
>>>>>>>>>>>> >>> max="100"></progress></td>'.fo
>>>>>>>>>>>> rmat(100*summary.percentage_branches_covered)
>>>>>>>>>>>> >>> + row += "</tr>\n"
>>>>>>>>>>>> >>> + return row
>>>>>>>>>>>> >>> + def _header_row(self):
>>>>>>>>>>>> >>> + row = "<tr>"
>>>>>>>>>>>> >>> + row += "<th> Symbols set name </th>"
>>>>>>>>>>>> >>> + row += "<th> Index file </th>"
>>>>>>>>>>>> >>> + row += "<th> Summary file </th>"
>>>>>>>>>>>> >>> + row += "<th> Bytes analyzed </th>"
>>>>>>>>>>>> >>> + row += "<th> Bytes not executed </th>"
>>>>>>>>>>>> >>> + row += "<th> Uncovered ranges </th>"
>>>>>>>>>>>> >>> + row += "<th> Percentage covered </th>"
>>>>>>>>>>>> >>> + row += "<th> Percentage uncovered </th>"
>>>>>>>>>>>> >>> + row += "<th> Instruction coverage </th>"
>>>>>>>>>>>> >>> + row += "<th> Branches uncovered </th>"
>>>>>>>>>>>> >>> + row += "<th> Branches total </th>"
>>>>>>>>>>>> >>> + row += "<th> Branches covered percentage </th>"
>>>>>>>>>>>> >>> + row += "<th> Branches coverage </th>"
>>>>>>>>>>>> >>> + row += "</tr>\n"
>>>>>>>>>>>> >>> + self.number_of_columns = row.count('<th>')
>>>>>>>>>>>> >>> + return row
>>>>>>>>>>>> >>> + def _link(self, address, text):
>>>>>>>>>>>> >>> + return '<a href="' + address + '">' + text + '</a>'
>>>>>>>>>>>> >>> + def _create_index_file(self, head_section, content):
>>>>>>>>>>>> >>> + with open(path.join(self.build_dir,"report.html"),'w')
>>>>>>>>>>>> as f:
>>>>>>>>>>>> >>> + f.write(head_section)
>>>>>>>>>>>> >>> + f.write(content)
>>>>>>>>>>>> >>> + def generate(self):
>>>>>>>>>>>> >>> + partial_reports = self._find_partial_reports()
>>>>>>>>>>>> >>> + head_section = self._prepare_head_section()
>>>>>>>>>>>> >>> + index_content = self._prepare_index_content(pa
>>>>>>>>>>>> rtial_reports)
>>>>>>>>>>>> >>> + self._create_index_file(head_s
>>>>>>>>>>>> ection,index_content)
>>>>>>>>>>>> >>> + def add_covoar_src_path(self):
>>>>>>>>>>>> >>> + table_js_path = path.join(self.covoar_src_path,
>>>>>>>>>>>> 'table.js')
>>>>>>>>>>>> >>> + covoar_css_path = path.join(self.covoar_src_path,
>>>>>>>>>>>> 'covoar.css')
>>>>>>>>>>>> >>> + symbol_set_dir = path.join(self.build_dir,
>>>>>>>>>>>> "coverage",
>>>>>>>>>>>> >>> symbol_set)
>>>>>>>>>>>> >>> + html_files = os.listdir(symbol_set_dir)
>>>>>>>>>>>> >>> + for html_file in html_files:
>>>>>>>>>>>> >>> + html_file = path.join(symbol_set_dir,
>>>>>>>>>>>> html_file)
>>>>>>>>>>>> >>> + if path.exists(html_file) and 'html' in
>>>>>>>>>>>> html_file:
>>>>>>>>>>>> >>> + with open(html_file, 'r') as f:
>>>>>>>>>>>> >>> + file_data = f.read()
>>>>>>>>>>>> >>> + file_data =
>>>>>>>>>>>> file_data.replace('table.js',
>>>>>>>>>>>> >>> table_js_path)
>>>>>>>>>>>> >>> + file_data =
>>>>>>>>>>>> file_data.replace('covoar.css',
>>>>>>>>>>>> covoar_css_path)
>>>>>>>>>>>> >>> + with open(html_file, 'w') as f:
>>>>>>>>>>>> >>> + f.write(file_data)
>>>>>>>>>>>> >>> +class build_path_generator(object):
>>>>>>>>>>>> >>> + Generates the build path from the path to executables
>>>>>>>>>>>> >>> + def __init__(self, executables, target):
>>>>>>>>>>>> >>> + self.executables = executables
>>>>>>>>>>>> >>> + self.target = target
>>>>>>>>>>>> >>> + def run(self):
>>>>>>>>>>>> >>> + build_path = '/'
>>>>>>>>>>>> >>> + Path = self.executables[0].split('/')
>>>>>>>>>>>> >>> + for P in Path:
>>>>>>>>>>>> >>> + if P == self.target:
>>>>>>>>>>>> >>> + break;
>>>>>>>>>>>> >>> + else:
>>>>>>>>>>>> >>> + build_path = path.join(build_path, P)
>>>>>>>>>>>> >>> + return build_path
>>>>>>>>>>>> >>> +class symbol_parser(object):
>>>>>>>>>>>> >>> + Parse the symbol sets ini and create custom ini file
>>>>>>>>>>>> for covoar
>>>>>>>>>>>> >>> + def __init__(self, symbol_config_path,
>>>>>>>>>>>> >>> + symbol_select_path, coverage_arg,
>>>>>>>>>>>> build_dir):
>>>>>>>>>>>> >>> + self.symbol_select_file = symbol_select_path
>>>>>>>>>>>> >>> + self.symbol_file = symbol_config_path
>>>>>>>>>>>> >>> + self.symbol_sets = {}
>>>>>>>>>>>> >>> + self.cov_arg = coverage_arg
>>>>>>>>>>>> >>> + self.ssets = []
>>>>>>>>>>>> >>> + def parse(self):
>>>>>>>>>>>> >>> + config = configparser.ConfigParser()
>>>>>>>>>>>> >>> + try:
>>>>>>>>>>>> >>> + config.read(self.symbol_file)
>>>>>>>>>>>> >>> + if self.cov_arg:
>>>>>>>>>>>> >>> + self.ssets = self.cov_arg.split(',')
>>>>>>>>>>>> >>> + else:
>>>>>>>>>>>> >>> + self.ssets = config.get('symbol-sets',
>>>>>>>>>>>> >>> 'sets').split(',')
>>>>>>>>>>>> >>> + self.ssets = [ sset.encode('utf-8') for
>>>>>>>>>>>> sset in
>>>>>>>>>>>> >>> self.ssets]
>>>>>>>>>>>> >>> + for sset in self.ssets:
>>>>>>>>>>>> >>> + lib = path.join(self.build_dir,
>>>>>>>>>>>> >>> + config.get('libraries',
>>>>>>>>>>>> sset))
>>>>>>>>>>>> >>> + self.symbol_sets[sset] =
>>>>>>>>>>>> lib.encode('utf-8')
>>>>>>>>>>>> >>> + except:
>>>>>>>>>>>> >>> + raise error.general('Symbol set parsing
>>>>>>>>>>>> failed')
>>>>>>>>>>>> >>> + def _write_ini(self):
>>>>>>>>>>>> >>> + try:
>>>>>>>>>>>> >>> + sets = ', '.join(self.symbol_sets.keys())
>>>>>>>>>>>> >>> + config.add_section('symbol-sets')
>>>>>>>>>>>> >>> + config.set('symbol-sets', 'sets', sets)
>>>>>>>>>>>> >>> + for key in self.symbol_sets.keys():
>>>>>>>>>>>> >>> + config.add_section(key)
>>>>>>>>>>>> >>> + config.set(key, 'libraries',
>>>>>>>>>>>> self.symbol_sets[key])
>>>>>>>>>>>> >>> + with open(self.symbol_select_file, 'w') as
>>>>>>>>>>>> conf:
>>>>>>>>>>>> >>> + config.write(conf)
>>>>>>>>>>>> >>> + except:
>>>>>>>>>>>> >>> + raise error.general('write failed')
>>>>>>>>>>>> >>> + def run(self):
>>>>>>>>>>>> >>> + self.parse()
>>>>>>>>>>>> >>> + self._write_ini()
>>>>>>>>>>>> >>> +class covoar(object):
>>>>>>>>>>>> >>> + Covoar runner
>>>>>>>>>>>> >>> + def __init__(self, base_result_dir, config_dir,
>>>>>>>>>>>> executables,
>>>>>>>>>>>> >>> explanations_txt):
>>>>>>>>>>>> >>> + self.base_result_dir = base_result_dir
>>>>>>>>>>>> >>> + self.config_dir = config_dir
>>>>>>>>>>>> >>> + self.executables = ' '.join(executables)
>>>>>>>>>>>> >>> + self.explanations_txt = explanations_txt
>>>>>>>>>>>> >>> + self.project_name = 'RTEMS-5'
>>>>>>>>>>>> >>> + def run(self, set_name, symbol_file):
>>>>>>>>>>>> >>> + covoar_result_dir = path.join(self.base_result_dir,
>>>>>>>>>>>> set_name)
>>>>>>>>>>>> >>> + if (not path.exists(covoar_result_dir)):
>>>>>>>>>>>> >>> + path.mkdir(covoar_result_dir)
>>>>>>>>>>>> >>> + if (not path.exists(symbol_file)):
>>>>>>>>>>>> >>> + raise error.general('symbol set file: coverage
>>>>>>>>>>>> %s was not
>>>>>>>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>>>>>>>> >>> + command = ('covoar -S ' + symbol_file
>>>>>>>>>>>> >>> + + ' -O ' + covoar_result_dir
>>>>>>>>>>>> >>> + + ' -E ' + self.explanations_txt
>>>>>>>>>>>> >>> + + ' -p ' + self.project_name + ' ' +
>>>>>>>>>>>> self.executables)
>>>>>>>>>>>> >>> + log.notice('Running covoar for %s' % (set_name))
>>>>>>>>>>>> >>> + print( 'covoar results directory:\n' +
>>>>>>>>>>>> covoar_result_dir )
>>>>>>>>>>>> >>> + executor = execute.execute(verbose = True, output =
>>>>>>>>>>>> >>> self.output_handler)
>>>>>>>>>>>> >>> + exit_code = executor.shell(command,
>>>>>>>>>>>> cwd=os.getcwd())
>>>>>>>>>>>> >>> + if (exit_code[0] != 0):
>>>>>>>>>>>> >>> + raise error.general('covoar failure exit code:
>>>>>>>>>>>> %d' %
>>>>>>>>>>>> >>> (exit_code[0]))
>>>>>>>>>>>> >>> + log.notice('Coverage run for %s finished
>>>>>>>>>>>> successfully.' %
>>>>>>>>>>>> >>> (set_name))
>>>>>>>>>>>> >>> + log.notice('------------------
>>>>>>>>>>>> >>> + def output_handler(self, text):
>>>>>>>>>>>> >>> + log.notice('%s' % (text))
>>>>>>>>>>>> >>> +class coverage_run(object):
>>>>>>>>>>>> >>> + Coverage analysis support for rtems-test
>>>>>>>>>>>> >>> + def __init__(self, p_macros, coverage_arg, target):
>>>>>>>>>>>> >>> + Constructor
>>>>>>>>>>>> >>> + self.macros = p_macros
>>>>>>>>>>>> >>> + self.build_dir = self.macros['_cwd']
>>>>>>>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>>>>>>>> >>> + self.test_dir = path.join(self.build_dir,
>>>>>>>>>>>> 'coverage')
>>>>>>>>>>>> >>> + if (not path.exists(self.test_dir)):
>>>>>>>>>>>> >>> + path.mkdir(self.test_dir)
>>>>>>>>>>>> >>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>>>>>>>> >>> + self.rtscripts = self.macros.expand(self.macros
>>>>>>>>>>>> ['_rtscripts'])
>>>>>>>>>>>> >>> + self.coverage_config_path =
>>>>>>>>>>>> path.join(self.rtscripts,
>>>>>>>>>>>> >>> 'coverage')
>>>>>>>>>>>> >>> + self.symbol_config_path =
>>>>>>>>>>>> path.join(self.coverage_config_path,
>>>>>>>>>>>> 'symbol-sets.ini')
>>>>>>>>>>>> >>> + self.symbol_select_path =
>>>>>>>>>>>> 'symbol-select.ini')
>>>>>>>>>>>> >>> + self.executables = None
>>>>>>>>>>>> >>> + self.symbol_sets = []
>>>>>>>>>>>> >>> + self.no_clean = int(self.macros['_no_clean'])
>>>>>>>>>>>> >>> + self.report_format = self.macros['cov_report_format
>>>>>>>>>>>> >>> + self.coverage_arg = coverage_arg
>>>>>>>>>>>> >>> + def run(self):
>>>>>>>>>>>> >>> + try:
>>>>>>>>>>>> >>> + if self.executables is None:
>>>>>>>>>>>> >>> + raise error.general('no test executables
>>>>>>>>>>>> provided.')
>>>>>>>>>>>> >>> + build_dir = build_path_generator(self.exec
>>>>>>>>>>>> utables,
>>>>>>>>>>>> >>> self.target).run()
>>>>>>>>>>>> >>> + parser = symbol_parser(self.symbol_conf
>>>>>>>>>>>> ig_path,
>>>>>>>>>>>> >>> + self.symbol_select_path,
>>>>>>>>>>>> >>> + self.coverage_arg,
>>>>>>>>>>>> >>> + build_dir)
>>>>>>>>>>>> >>> + parser.run()
>>>>>>>>>>>> >>> + covoar_runner = covoar(self.test_dir,
>>>>>>>>>>>> >>> + self.executables,
>>>>>>>>>>>> >>> self.explanations_txt)
>>>>>>>>>>>> >>> + covoar_runner.run('score',
>>>>>>>>>>>> self.symbol_select_path)
>>>>>>>>>>>> >>> + self._generate_reports();
>>>>>>>>>>>> >>> + self._summarize();
>>>>>>>>>>>> >>> + finally:
>>>>>>>>>>>> >>> + self._cleanup();
>>>>>>>>>>>> >>> + def _generate_reports(self):
>>>>>>>>>>>> >>> + log.notice('Generating reports')
>>>>>>>>>>>> >>> + if self.report_format == 'html':
>>>>>>>>>>>> >>> + report = report_gen_html(self.symbol_sets,
>>>>>>>>>>>> >>> + self.build_dir,
>>>>>>>>>>>> >>> + self.rtdir)
>>>>>>>>>>>> >>> + report.generate()
>>>>>>>>>>>> >>> + report.add_covoar_src_path()
>>>>>>>>>>>> >>> + def _cleanup(self):
>>>>>>>>>>>> >>> + if not self.no_clean:
>>>>>>>>>>>> >>> + log.notice('***Cleaning tempfiles***')
>>>>>>>>>>>> >>> + for exe in self.executables:
>>>>>>>>>>>> >>> + trace_file = exe + '.cov'
>>>>>>>>>>>> >>> + if path.exists(trace_file):
>>>>>>>>>>>> >>> + os.remove(trace_file)
>>>>>>>>>>>> >>> + def _summarize(self):
>>>>>>>>>>>> >>> + log.notice('Coverage analysis finished. You can
>>>>>>>>>>>> find results in
>>>>>>>>>>>> >>> %s' % (self.build_dir))
>>>>>>>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>>>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>>>>>>>> >>> --- a/tester/rt/test.py
>>>>>>>>>>>> >>> +++ b/tester/rt/test.py
>>>>>>>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>>>>>>> >>> from rtemstoolkit import reraise
>>>>>>>>>>>> >>> from rtemstoolkit import stacktraces
>>>>>>>>>>>> >>> from rtemstoolkit import version
>>>>>>>>>>>> >>> +from rtemstoolkit import check
>>>>>>>>>>>> >>> from . import bsps
>>>>>>>>>>>> >>> from . import config
>>>>>>>>>>>> >>> from . import console
>>>>>>>>>>>> >>> from . import report
>>>>>>>>>>>> >>> +from . import coverage
>>>>>>>>>>>> >>> class log_capture(object):
>>>>>>>>>>>> >>> def __init__(self):
>>>>>>>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>>>>>>> >>> def run(self):
>>>>>>>>>>>> >>> self.thread = threading.Thread(target =
>>>>>>>>>>>> self.runner,
>>>>>>>>>>>> >>> - name = 'test[%s]' %
>>>>>>>>>>>> >>> path.basename(self.executable))
>>>>>>>>>>>> >>> + name = 'test[%s]' %
>>>>>>>>>>>> >>> self.thread.start()
>>>>>>>>>>>> >>> def is_alive(self):
>>>>>>>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>>>>>>>> >>> for test in tests:
>>>>>>>>>>>> >>> test.kill()
>>>>>>>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>>>>>>>> >>> + coverage.executables = executables
>>>>>>>>>>>> >>> + coverage.run()
>>>>>>>>>>>> >>> def run(command_path = None):
>>>>>>>>>>>> >>> import sys
>>>>>>>>>>>> >>> tests = []
>>>>>>>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>>>>>>>> >>> opts = None
>>>>>>>>>>>> >>> default_exefilter = '*.exe'
>>>>>>>>>>>> >>> try:
>>>>>>>>>>>> >>> - optargs = { '--rtems-tools': 'The path to the
>>>>>>>>>>>> RTEMS tools',
>>>>>>>>>>>> >>> - '--rtems-bsp': 'The RTEMS BSP to run
>>>>>>>>>>>> the test on',
>>>>>>>>>>>> >>> - '--user-config': 'Path to your local
>>>>>>>>>>>> user
>>>>>>>>>>>> >>> configuration INI file',
>>>>>>>>>>>> >>> - '--report-mode': 'Reporting modes,
>>>>>>>>>>>> failures
>>>>>>>>>>>> >>> (default),all,none',
>>>>>>>>>>>> >>> - '--list-bsps': 'List the supported
>>>>>>>>>>>> BSPs',
>>>>>>>>>>>> >>> - '--debug-trace': 'Debug trace based on
>>>>>>>>>>>> specific
>>>>>>>>>>>> >>> flags',
>>>>>>>>>>>> >>> - '--filter': 'Glob that
>>>>>>>>>>>> executables must match
>>>>>>>>>>>> >>> to run (default: ' +
>>>>>>>>>>>> >>> + optargs = { '--rtems-tools': 'The path to the
>>>>>>>>>>>> RTEMS tools',
>>>>>>>>>>>> >>> + '--rtems-bsp': 'The RTEMS BSP to
>>>>>>>>>>>> run the test
>>>>>>>>>>>> >>> on',
>>>>>>>>>>>> >>> + '--user-config': 'Path to your
>>>>>>>>>>>> local user
>>>>>>>>>>>> >>> + '--report-mode': 'Reporting modes,
>>>>>>>>>>>> failures
>>>>>>>>>>>> >>> + '--list-bsps': 'List the
>>>>>>>>>>>> supported BSPs',
>>>>>>>>>>>> >>> + '--debug-trace': 'Debug trace based
>>>>>>>>>>>> on specific
>>>>>>>>>>>> >>> flags',
>>>>>>>>>>>> >>> + '--filter': 'Glob that
>>>>>>>>>>>> executables must
>>>>>>>>>>>> >>> match to run (default: ' +
>>>>>>>>>>>> >>> default_exefilter + ')',
>>>>>>>>>>>> >>> - '--stacktrace': 'Dump a stack trace
>>>>>>>>>>>> on a user
>>>>>>>>>>>> >>> termination (^C)' }
>>>>>>>>>>>> >>> + '--stacktrace': 'Dump a stack
>>>>>>>>>>>> trace on a user
>>>>>>>>>>>> >>> termination (^C)',
>>>>>>>>>>>> >>> + '--coverage': 'Perform coverage
>>>>>>>>>>>> analysis of
>>>>>>>>>>>> >>> test executables.'}
>>>>>>>>>>>> >>> mailer.append_options(optargs)
>>>>>>>>>>>> >>> opts = options.load(sys.argv,
>>>>>>>>>>>> >>> optargs = optargs,
>>>>>>>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>>>>>>>> >>> raise error.general('RTEMS BSP not provided or
>>>>>>>>>>>> an invalid
>>>>>>>>>>>> >>> option')
>>>>>>>>>>>> >>> bsp = config.load(bsp[1], opts)
>>>>>>>>>>>> >>> bsp_config = opts.defaults.expand(opts.defa
>>>>>>>>>>>> ults['tester'])
>>>>>>>>>>>> >>> + coverage_enabled = opts.find_arg('--coverage')
>>>>>>>>>>>> >>> + if coverage_enabled:
>>>>>>>>>>>> >>> + if len(coverage_enabled) == 2:
>>>>>>>>>>>> >> Is this to check if sets have been provided to
>>>>>>>>>>>> --coverage=score,sapi, that
>>>>>>>>>>>> >> kind of thing? If so the variable name coverage_enabled
>>>>>>>>>>>> doesn't make sense
>>>>>>>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets)
>>>>>>>>>>>> will make more
>>>>>>>>>>>> >> sense for both cases.
>>>>>>>>>>>> > That's a good point.
>>>>>>>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>>>>>>>> > Because it's still checking whether the option is given or
>>>>>>>>>>>> > not. symbol_sets might create confusion.
>>>>>>>>>>>> > Will that be OK ?
>>>>>>>>>>>> That name might collide with your class object (coverage)?
>>>>>>>>>>> That's actually why I kept it as coverage_enabled.
>>>>>>>>>>> I think we can go for coverage_option (?)
>>>>>>>>>>>> >>> + coverage_runner =
>>>>>>>>>>>> coverage.coverage_run(opts.defaults,
>>>>>>>>>>>> coverage_enabled[1],
>>>>>>>>>>>> opts.defaults['target'])
>>>>>>>>>>>> >>> + else:
>>>>>>>>>>>> >>> + coverage_runner =
>>>>>>>>>>>> >>> 0,
>>>>>>>>>>>> >>> report_mode = opts.find_arg('--report-mode')
>>>>>>>>>>>> >>> if report_mode:
>>>>>>>>>>>> >>> if report_mode[1] != 'failures' and \
>>>>>>>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>>>>>>>> >>> reports.failures(),
>>>>>>>>>>>> >>> 'Log', '===', ''] + output.get()
>>>>>>>>>>>> >>> mail.send(to_addr, subject,
>>>>>>>>>>>> os.linesep.join(body))
>>>>>>>>>>>> >>> + coverage_run(opts, coverage_runner,
>>>>>>>>>>>> executables)
>>>>>>>>>>>> >>> except error.general as gerr:
>>>>>>>>>>>> >>> print(gerr)
>>>>>>>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>>>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>>>>>>>> >>> # The Leon 3 QEMU BSP
>>>>>>>>>>>> >>> -[leon3-qemu]
>>>>>>>>>>>> >>> +[leon3-qemu-cov]
>>>>>>>>>>>> >>> bsp = leon3-qemu
>>>>>>>>>>>> >>> arch = sparc
>>>>>>>>>>>> >>> +target = sparc-rtems5
>>>>>>>>>>>> >>> tester = %{_rtscripts}/qemu.cfg
>>>>>>>>>>>> >>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>>>>>>>>>>> >>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>>>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>>>> >>> index 0000000..a2ec7bc
>>>>>>>>>>>> >>> --- /dev/null
>>>>>>>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>>>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>>>>>>>> 'rtems-tools'.
>>>>>>>>>>>> or without
>>>>>>>>>>>> conditions are
>>>>>>>>>>>> >>> met:
>>>>>>>>>>>> copyright
>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>> above copyright
>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>> the
>>>>>>>>>>>> >>> documentation
>>>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>>>> >>> "AS IS"
>>>>>>>>>>>> NOT LIMITED TO,
>>>>>>>>>>>> >>> THE
>>>>>>>>>>>> PARTICULAR
>>>>>>>>>>>> >>> PURPOSE
>>>>>>>>>>>> OR CONTRIBUTORS
>>>>>>>>>>>> >>> BE
>>>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>>>> PROFITS; OR
>>>>>>>>>>>> >>> BUSINESS
>>>>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>>>>> >>> IN
>>>>>>>>>>>> NEGLIGENCE OR
>>>>>>>>>>>> >>> OTHERWISE)
>>>>>>>>>>>> IF ADVISED OF
>>>>>>>>>>>> >>> THE
>>>>>>>>>>>> >>> +[symbol-sets]
>>>>>>>>>>>> >>> +sets = score,rtems
>>>>>>>>>>>> >>> +[libraries]
>>>>>>>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>>>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>>>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>>>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>>>>>>>> >>> # Qemu common option patterns.
>>>>>>>>>>>> >>> -#%define qemu_opts_base -no-reboot -monitor none -serial
>>>>>>>>>>>> stdio
>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>> >>> -%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>>>>>> mon:stdio
>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>> >>> +%define qemu_opts_base -no-reboot -monitor none -serial
>>>>>>>>>>>> stdio
>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>> >>> +#%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>>>>>> mon:stdio
>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>> >>> %define qemu_opts_no_net -net none
>>>>>>>>>>>> >>> 2.14.3
>>>>>>>>>>>> >>> _______________________________________________
>>>>>>>>>>>> >>> devel mailing list
>>>>>>>>>>>> >>> devel at rtems.org
>>>>>>>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>> > devel mailing list
>>>>>>>>>>>> > devel at rtems.org
>>>>>> devel mailing list
>>>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/f547ad34/attachment-0001.html>
