[PATCH v2] tester: Add script to generate html coverage report from covoar output
Fri Jun 1 13:54:33 UTC 2018
On Fri, Jun 1, 2018 at 2:46 AM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Here's the list of Ideas for improvements:
> 1. Include the section coverage in the bsp config file.
>     If the section is not found then the script will show
>     proper error showing coverage is not supported for the
>     provided bsp config file.
> 2. Update covoar to add support for separate coverage report
>     for each symbol set.
> 3. Add a method somewhere in covoar to get the size of an instruction
>     and fix the hard coded size 4 in ObjdumpProcessor.cc
What about a single XXX_run command? What about that suggestion?
Will there be an update to this patch?
Once I have the final patch, I think I will push it along with my two
covoar patches. Those will keep the GSoC project moving on sparc
until I can really fix the "+4" issue.
> On 1 June 2018 at 04:43, Joel Sherrill <joel at rtems.org> wrote:
>> Just chatted with Chris. The coverage BSP ini file was a temporary
>> measure as I thought.
>> Make a list of all the ideas we have had for improvements. We want
>> the code to get onto master.
>> The list should be converted to Trac tickets very soon. Then we can
>> decide which are critical for GSoC, which Chris or I will work on, and
>> which are part of your GSoC.
>> --joel
>> On Thu, May 31, 2018 at 5:18 PM, Vijay Kumar Banerjee <
>>> On Fri, 1 Jun 2018, 03:40 Joel Sherrill, <joel at rtems.org> wrote:
>>>> On Thu, May 31, 2018 at 4:57 PM, Vijay Kumar Banerjee <
>>>>> On 1 June 2018 at 02:50, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Thu, May 31, 2018 at 4:15 PM, Cillian O'Donnell <
>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>> On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <
>>>>>>>> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> There is now a seperate bsp config for coverage, leon3-qemu-cov.
>>>>>>>>> That is enough to trigger coverage now and --coverage could be reserved for
>>>>>>>>> picking sets, probably renamed to --coverage-sets=... Or require sets to be
>>>>>>>>> chosen --coverage-sets=all or specific sets --coverage-sets=score,sapi,cor
>>>>>>>>> e
>>>>>>>>> Actually the idea of having separate bsp configs for cov
>>>>>>>> in each of the bsps will create a lot of files. The intention is
>>>>>>>> to make it simple for the user. just adding --coverage
>>>>>>>> should run coverage analysis. There's a plan to include
>>>>>>>> the 'coverage' section into the bsp ini file, and hence the user
>>>>>>>> wouldn't
>>>>>>>> have to keep switching the bsp config files.
>>>>>>> Actually that's exactly the way I had it working before Chris'
>>>>>>> recent changes, he had a look at the way it's working and chose to create
>>>>>>> seperate bsp config files. That may be the way he'd prefer. This was before
>>>>>>> the --coverage option had another use other than triggering coverage, so
>>>>>>> his thoughts may have changed on it.
>>>>>> Chris should comment on the separate ini files. I think that might
>>>>>> have been
>>>>>> driven by couverture vs regular qemu before couverture was available
>>>>>> from
>>>>>> the RSB.
>>>>>> Okay, we wait for Chris to comment on it then.
>>>>>> I think it would be nice to have --coverage and if the BSP ini file
>>>>>> doesn't support
>>>>>> coverage, give an error.
>>>>> Is the set option in the Python and processed by covoar in a way that
>>>>>> still
>>>>>> lets covoar be used on something besides RTEMS?
>>>>> yes, it is totally handled by the script to 'feed' covoar with the
>>>>> options,
>>>>> without changing the way it works.
>>>>> I have a question/doubt.
>>>>> By adding separate bsp config for cov. Are we not assuming that
>>>>> the provided bsp ini supports coverage ?
>>>> I think having two leon3 configurations like we do now is temporary
>>>> just to have something that works. Any changes to the coverage
>>>> version don't impact the baseline.
>>> Understood. Thanks.
>>>> I am hoping Chris has an idea to unified these. :)
>>>>>>>> The idea of modifying it to --coverage-sets=all ;
>>>>>>>> --coverage-sets=set1,set2,set3..... can surely be implemented
>>>>>>>> in place of --coverage ; --coverage=set1,set2....
>>>>>>>>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>>>>>>>>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>>>> > wrote:
>>>>>>>>>>> So is it checking whether it's --coverage or
>>>>>>>>>>> --coverage=set1,set2? Are those the 2 possibilities your checking?
>>>>>>>>>>> Yes, right. :)
>>>>>>>>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>>>>>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <
>>>>>>>>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>>>>>>>>> >> wrote:
>>>>>>>>>>>>> >>> Add support in tester to run covoar and generate an html
>>>>>>>>>>>>> report to
>>>>>>>>>>>>> >>> display
>>>>>>>>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>>>>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>>>>>>> >>>  tester/rt/coverage.py                         | 379
>>>>>>>>>>>>> >>>  tester/rt/test.py                             |  36 ++-
>>>>>>>>>>>>> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>>>>>>>>>> >>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>>>>>>>>>> >>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>>>>>>>>>> >>>  5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>>>>>>>>> >>>  create mode 100644 tester/rt/coverage.py
>>>>>>>>>>>>> >>>  create mode 100644 tester/rtems/testing/coverage/
>>>>>>>>>>>>> symbol-sets.ini
>>>>>>>>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>>>>>>>>> >>> new file mode 100644
>>>>>>>>>>>>> >>> index 0000000..25fbb9d
>>>>>>>>>>>>> >>> --- /dev/null
>>>>>>>>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>>>>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>>>>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>>>>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>>>>>>>>> >>> +# All rights reserved.
>>>>>>>>>>>>> >>> +# This file is part of the RTEMS Tools package in
>>>>>>>>>>>>> 'rtems-tools'.
>>>>>>>>>>>>> >>> +# Redistribution and use in source and binary forms, with
>>>>>>>>>>>>> or without
>>>>>>>>>>>>> >>> +# modification, are permitted provided that the following
>>>>>>>>>>>>> conditions are
>>>>>>>>>>>>> >>> met:
>>>>>>>>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>>>>>>>>> copyright
>>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>>>>>>>>> >>> +# 2. Redistributions in binary form must reproduce the
>>>>>>>>>>>>> above copyright
>>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>>> >>> +# this list of conditions and the following disclaimer in
>>>>>>>>>>>>> the
>>>>>>>>>>>>> >>> documentation
>>>>>>>>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>>>>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>>>>> >>> 'AS IS'
>>>>>>>>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT
>>>>>>>>>>>>> NOT LIMITED TO,
>>>>>>>>>>>>> >>> THE
>>>>>>>>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>>>>>>> PARTICULAR
>>>>>>>>>>>>> >>> PURPOSE
>>>>>>>>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER
>>>>>>>>>>>>> OR CONTRIBUTORS
>>>>>>>>>>>>> >>> BE
>>>>>>>>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
>>>>>>>>>>>>> PROFITS; OR
>>>>>>>>>>>>> >>> BUSINESS
>>>>>>>>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
>>>>>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>>>>>> >>> IN
>>>>>>>>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
>>>>>>>>>>>>> NEGLIGENCE OR
>>>>>>>>>>>>> >>> OTHERWISE)
>>>>>>>>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
>>>>>>>>>>>>> EVEN IF ADVISED OF
>>>>>>>>>>>>> >>> THE
>>>>>>>>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>>>>>>>>> >>> +from rtemstoolkit import error
>>>>>>>>>>>>> >>> +from rtemstoolkit import path
>>>>>>>>>>>>> >>> +from rtemstoolkit import log
>>>>>>>>>>>>> >>> +from rtemstoolkit import execute
>>>>>>>>>>>>> >>> +from rtemstoolkit import macros
>>>>>>>>>>>>> >>> +from datetime import datetime
>>>>>>>>>>>>> >>> +from . import options
>>>>>>>>>>>>> >>> +import shutil
>>>>>>>>>>>>> >>> +import os
>>>>>>>>>>>>> >>> +try:
>>>>>>>>>>>>> >>> +    import configparser
>>>>>>>>>>>>> >>> +except:
>>>>>>>>>>>>> >>> +    import ConfigParser as configparser
>>>>>>>>>>>>> >>> +class summary:
>>>>>>>>>>>>> >>> +    def __init__(self, p_summary_dir):
>>>>>>>>>>>>> >>> +        self.summary_file_path = path.join(p_summary_dir,
>>>>>>>>>>>>> 'summary.txt')
>>>>>>>>>>>>> >>> +        self.index_file_path = path.join(p_summary_dir,
>>>>>>>>>>>>> 'index.html')
>>>>>>>>>>>>> >>> +        self.bytes_analyzed = 0
>>>>>>>>>>>>> >>> +        self.bytes_not_executed = 0
>>>>>>>>>>>>> >>> +        self.percentage_executed = 0.0
>>>>>>>>>>>>> >>> +        self.percentage_not_executed = 100.0
>>>>>>>>>>>>> >>> +        self.ranges_uncovered = 0
>>>>>>>>>>>>> >>> +        self.branches_uncovered = 0
>>>>>>>>>>>>> >>> +        self.branches_total = 0
>>>>>>>>>>>>> >>> +        self.branches_always_taken = 0
>>>>>>>>>>>>> >>> +        self.branches_never_taken = 0
>>>>>>>>>>>>> >>> +        self.percentage_branches_covered = 0.0
>>>>>>>>>>>>> >>> +        self.is_failure = False
>>>>>>>>>>>>> >>> +    def parse(self):
>>>>>>>>>>>>> >>> +        if(not path.exists(self.summary_file_path)):
>>>>>>>>>>>>> >>> +            log.notice('summary file %s does not exist!' %
>>>>>>>>>>>>> >>> +            self.is_failure = True
>>>>>>>>>>>>> >>> +            return
>>>>>>>>>>>>> >>> +        with open(self.summary_file_path,'r') as
>>>>>>>>>>>>> summary_file:
>>>>>>>>>>>>> self._get_next_with_colon(summary_file)
>>>>>>>>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>>>>>>>>> >>> +        if len(self.branches_uncovered) > 0 and
>>>>>>>>>>>>> len(self.branches_total)
>>>>>>>>>>>>> >>> > 0:
>>>>>>>>>>>>> >>> +            self.percentage_branches_covered = \
>>>>>>>>>>>>> >>> +            1 - (float(self.branches_uncovered) /
>>>>>>>>>>>>> >>> float(self.branches_total))
>>>>>>>>>>>>> >>> +        else:
>>>>>>>>>>>>> >>> +        return
>>>>>>>>>>>>> >>> +    def _get_next_with_colon(self, summary_file):
>>>>>>>>>>>>> >>> +        line = summary_file.readline()
>>>>>>>>>>>>> >>> +        if ':' in line:
>>>>>>>>>>>>> >>> +            return line.split(':')[1].strip()
>>>>>>>>>>>>> >>> +        else:
>>>>>>>>>>>>> >>> +            return ''
>>>>>>>>>>>>> >>> +    def _get_next_without_colon(self, summary_file):
>>>>>>>>>>>>> >>> +        return line.strip().split(' ')[0]
>>>>>>>>>>>>> >>> +class report_gen_html:
>>>>>>>>>>>>> >>> +    def __init__(self, p_symbol_sets_list, build_dir,
>>>>>>>>>>>>> rtdir):
>>>>>>>>>>>>> >>> +        self.symbol_sets_list = ['score']
>>>>>>>>>>>>> >>> +        self.build_dir = build_dir
>>>>>>>>>>>>> >>> +        self.partial_reports_files = list(["index.html",
>>>>>>>>>>>>> "summary.txt"])
>>>>>>>>>>>>> >>> +        self.number_of_columns = 1
>>>>>>>>>>>>> >>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>>>>>>>>> >>> +    def _find_partial_reports(self):
>>>>>>>>>>>>> >>> +        partial_reports = {}
>>>>>>>>>>>>> >>> +        for symbol_set in self.symbol_sets_list:
>>>>>>>>>>>>> >>> +            set_summary = summary(path.join(self.build_dir,
>>>>>>>>>>>>> "coverage",
>>>>>>>>>>>>> >>> +                                  symbol_set))
>>>>>>>>>>>>> >>> +            set_summary.parse()
>>>>>>>>>>>>> >>> +            partial_reports[symbol_set] = set_summary
>>>>>>>>>>>>> >>> +        return partial_reports
>>>>>>>>>>>>> >>> +    def _prepare_head_section(self):
>>>>>>>>>>>>> >>> +        head_section = '''
>>>>>>>>>>>>> >>> +        <head>
>>>>>>>>>>>>> >>> +        <title>RTEMS coverage report</title>
>>>>>>>>>>>>> >>> +        <style type="text/css">
>>>>>>>>>>>>> >>> +            progress[value] {
>>>>>>>>>>>>> >>> +              -webkit-appearance: none;
>>>>>>>>>>>>> >>> +               appearance: none;
>>>>>>>>>>>>> >>> +              width: 150px;
>>>>>>>>>>>>> >>> +              height: 15px;
>>>>>>>>>>>>> >>> +        </style>
>>>>>>>>>>>>> >>> +        </head>'''
>>>>>>>>>>>>> >>> +        return head_section
>>>>>>>>>>>>> >>> +    def _prepare_index_content(self, partial_reports):
>>>>>>>>>>>>> >>> +        header = "<h1> RTEMS coverage analysis report
>>>>>>>>>>>>> </h1>"
>>>>>>>>>>>>> >>> +        header += "<h3>Coverage reports by symbols
>>>>>>>>>>>>> sets:</h3>"
>>>>>>>>>>>>> >>> +        table = "<table>"
>>>>>>>>>>>>> >>> +        table += self._header_row()
>>>>>>>>>>>>> >>> +        for symbol_set in partial_reports:
>>>>>>>>>>>>> >>> +            table += self._row(symbol_set,
>>>>>>>>>>>>> partial_reports[symbol_set])
>>>>>>>>>>>>> >>> +        table += "</table> </br>"
>>>>>>>>>>>>> >>> +        timestamp = "Analysis performed on " +
>>>>>>>>>>>>> datetime.now().ctime()
>>>>>>>>>>>>> >>> +        return "<body>\n" + header + table + timestamp +
>>>>>>>>>>>>> "\n</body>"
>>>>>>>>>>>>> >>> +    def _row(self, symbol_set, summary):
>>>>>>>>>>>>> >>> +        row = "<tr>"
>>>>>>>>>>>>> >>> +        row += "<td>" + symbol_set + "</td>"
>>>>>>>>>>>>> >>> +        if summary.is_failure:
>>>>>>>>>>>>> >>> +            row += ' <td colspan="' +
>>>>>>>>>>>>> str(self.number_of_columns-1) \
>>>>>>>>>>>>> >>> +            + '" style="background-color:red">F
>>>>>>>>>>>>> AILURE</td>'
>>>>>>>>>>>>> >>> +        else:
>>>>>>>>>>>>> >>> +            row += " <td>" +
>>>>>>>>>>>>> self._link(summary.index_file_path,"Index")
>>>>>>>>>>>>> >>> +            + "</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" +
>>>>>>>>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>>>>>>>>> >>> +            + "</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" + summary.bytes_analyzed +
>>>>>>>>>>>>> "</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" + summary.bytes_not_executed +
>>>>>>>>>>>>> "</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" + summary.ranges_uncovered +
>>>>>>>>>>>>> "</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" + summary.percentage_executed
>>>>>>>>>>>>> + "%</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" +
>>>>>>>>>>>>> summary.percentage_not_executed + "%</td>"
>>>>>>>>>>>>> >>> +            row += ' <td><progress value="' +
>>>>>>>>>>>>> >>> summary.percentage_executed \
>>>>>>>>>>>>> >>> +            + '" max="100"></progress></td>'
>>>>>>>>>>>>> >>> +            row += " <td>" + summary.branches_uncovered +
>>>>>>>>>>>>> "</td>"
>>>>>>>>>>>>> >>> +            row += " <td>" + summary.branches_total +
>>>>>>>>>>>>> "</td>"
>>>>>>>>>>>>> >>> +            row += " <td> {:.3%}
>>>>>>>>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>>>>>>>>> >>> +            row += ' <td><progress value="{:.3}"
>>>>>>>>>>>>> >>> max="100"></progress></td>'.fo
>>>>>>>>>>>>> rmat(100*summary.percentage_branches_covered)
>>>>>>>>>>>>> >>> +            row += "</tr>\n"
>>>>>>>>>>>>> >>> +        return row
>>>>>>>>>>>>> >>> +    def _header_row(self):
>>>>>>>>>>>>> >>> +        row = "<tr>"
>>>>>>>>>>>>> >>> +        row += "<th> Symbols set name </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Index file </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Summary file </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Bytes analyzed </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Bytes not executed </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Uncovered ranges </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Percentage covered </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Percentage uncovered </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Instruction coverage </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Branches uncovered </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Branches total </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Branches covered percentage </th>"
>>>>>>>>>>>>> >>> +        row += "<th> Branches coverage </th>"
>>>>>>>>>>>>> >>> +        row += "</tr>\n"
>>>>>>>>>>>>> >>> +        self.number_of_columns = row.count('<th>')
>>>>>>>>>>>>> >>> +        return row
>>>>>>>>>>>>> >>> +    def _link(self, address, text):
>>>>>>>>>>>>> >>> +        return '<a href="' + address + '">' + text +
>>>>>>>>>>>>> '</a>'
>>>>>>>>>>>>> >>> +    def _create_index_file(self, head_section, content):
>>>>>>>>>>>>> >>> +        with open(path.join(self.build_dir,"report.html"),'w')
>>>>>>>>>>>>> as f:
>>>>>>>>>>>>> >>> +            f.write(head_section)
>>>>>>>>>>>>> >>> +            f.write(content)
>>>>>>>>>>>>> >>> +    def generate(self):
>>>>>>>>>>>>> >>> +        partial_reports = self._find_partial_reports()
>>>>>>>>>>>>> >>> +        head_section = self._prepare_head_section()
>>>>>>>>>>>>> >>> +        index_content = self._prepare_index_content(pa
>>>>>>>>>>>>> rtial_reports)
>>>>>>>>>>>>> >>> +        self._create_index_file(head_s
>>>>>>>>>>>>> ection,index_content)
>>>>>>>>>>>>> >>> +    def add_covoar_src_path(self):
>>>>>>>>>>>>> >>> +        table_js_path = path.join(self.covoar_src_path,
>>>>>>>>>>>>> 'table.js')
>>>>>>>>>>>>> >>> +        covoar_css_path = path.join(self.covoar_src_path,
>>>>>>>>>>>>> 'covoar.css')
>>>>>>>>>>>>> >>> +            symbol_set_dir = path.join(self.build_dir,
>>>>>>>>>>>>> "coverage",
>>>>>>>>>>>>> >>> symbol_set)
>>>>>>>>>>>>> >>> +            html_files = os.listdir(symbol_set_dir)
>>>>>>>>>>>>> >>> +            for html_file in html_files:
>>>>>>>>>>>>> >>> +                html_file = path.join(symbol_set_dir,
>>>>>>>>>>>>> html_file)
>>>>>>>>>>>>> >>> +                if path.exists(html_file) and 'html' in
>>>>>>>>>>>>> html_file:
>>>>>>>>>>>>> >>> +                    with open(html_file, 'r') as f:
>>>>>>>>>>>>> >>> +                        file_data = f.read()
>>>>>>>>>>>>> >>> +                    file_data =
>>>>>>>>>>>>> file_data.replace('table.js',
>>>>>>>>>>>>> >>> table_js_path)
>>>>>>>>>>>>> >>> +                    file_data =
>>>>>>>>>>>>> file_data.replace('covoar.css',
>>>>>>>>>>>>> covoar_css_path)
>>>>>>>>>>>>> >>> +                    with open(html_file, 'w') as f:
>>>>>>>>>>>>> >>> +                        f.write(file_data)
>>>>>>>>>>>>> >>> +class build_path_generator(object):
>>>>>>>>>>>>> >>> +    Generates the build path from the path to executables
>>>>>>>>>>>>> >>> +    def __init__(self, executables, target):
>>>>>>>>>>>>> >>> +        self.executables = executables
>>>>>>>>>>>>> >>> +        self.target = target
>>>>>>>>>>>>> >>> +    def run(self):
>>>>>>>>>>>>> >>> +        build_path = '/'
>>>>>>>>>>>>> >>> +        Path = self.executables[0].split('/')
>>>>>>>>>>>>> >>> +        for P in Path:
>>>>>>>>>>>>> >>> +            if P == self.target:
>>>>>>>>>>>>> >>> +                break;
>>>>>>>>>>>>> >>> +            else:
>>>>>>>>>>>>> >>> +                build_path = path.join(build_path, P)
>>>>>>>>>>>>> >>> +        return build_path
>>>>>>>>>>>>> >>> +class symbol_parser(object):
>>>>>>>>>>>>> >>> +    Parse the symbol sets ini and create custom ini file
>>>>>>>>>>>>> for covoar
>>>>>>>>>>>>> >>> +    def __init__(self, symbol_config_path,
>>>>>>>>>>>>> >>> +                 symbol_select_path, coverage_arg,
>>>>>>>>>>>>> build_dir):
>>>>>>>>>>>>> >>> +        self.symbol_select_file = symbol_select_path
>>>>>>>>>>>>> >>> +        self.symbol_file = symbol_config_path
>>>>>>>>>>>>> >>> +        self.symbol_sets = {}
>>>>>>>>>>>>> >>> +        self.cov_arg = coverage_arg
>>>>>>>>>>>>> >>> +        self.ssets = []
>>>>>>>>>>>>> >>> +    def parse(self):
>>>>>>>>>>>>> >>> +        config = configparser.ConfigParser()
>>>>>>>>>>>>> >>> +        try:
>>>>>>>>>>>>> >>> +            config.read(self.symbol_file)
>>>>>>>>>>>>> >>> +            if self.cov_arg:
>>>>>>>>>>>>> >>> +                self.ssets = self.cov_arg.split(',')
>>>>>>>>>>>>> >>> +            else:
>>>>>>>>>>>>> >>> +                self.ssets = config.get('symbol-sets',
>>>>>>>>>>>>> >>> 'sets').split(',')
>>>>>>>>>>>>> >>> +                self.ssets = [ sset.encode('utf-8') for
>>>>>>>>>>>>> sset in
>>>>>>>>>>>>> >>> self.ssets]
>>>>>>>>>>>>> >>> +            for sset in self.ssets:
>>>>>>>>>>>>> >>> +                lib = path.join(self.build_dir,
>>>>>>>>>>>>> >>> +                                config.get('libraries',
>>>>>>>>>>>>> sset))
>>>>>>>>>>>>> >>> +                self.symbol_sets[sset] =
>>>>>>>>>>>>> lib.encode('utf-8')
>>>>>>>>>>>>> >>> +        except:
>>>>>>>>>>>>> >>> +            raise error.general('Symbol set parsing
>>>>>>>>>>>>> failed')
>>>>>>>>>>>>> >>> +    def _write_ini(self):
>>>>>>>>>>>>> >>> +        try:
>>>>>>>>>>>>> >>> +            sets = ', '.join(self.symbol_sets.keys())
>>>>>>>>>>>>> >>> +            config.add_section('symbol-sets')
>>>>>>>>>>>>> >>> +            config.set('symbol-sets', 'sets', sets)
>>>>>>>>>>>>> >>> +            for key in self.symbol_sets.keys():
>>>>>>>>>>>>> >>> +                config.add_section(key)
>>>>>>>>>>>>> >>> +                config.set(key, 'libraries',
>>>>>>>>>>>>> self.symbol_sets[key])
>>>>>>>>>>>>> >>> +            with open(self.symbol_select_file, 'w') as
>>>>>>>>>>>>> conf:
>>>>>>>>>>>>> >>> +                config.write(conf)
>>>>>>>>>>>>> >>> +        except:
>>>>>>>>>>>>> >>> +            raise error.general('write failed')
>>>>>>>>>>>>> >>> +    def run(self):
>>>>>>>>>>>>> >>> +        self.parse()
>>>>>>>>>>>>> >>> +        self._write_ini()
>>>>>>>>>>>>> >>> +class covoar(object):
>>>>>>>>>>>>> >>> +    Covoar runner
>>>>>>>>>>>>> >>> +    def __init__(self, base_result_dir, config_dir,
>>>>>>>>>>>>> executables,
>>>>>>>>>>>>> >>> explanations_txt):
>>>>>>>>>>>>> >>> +        self.base_result_dir = base_result_dir
>>>>>>>>>>>>> >>> +        self.config_dir = config_dir
>>>>>>>>>>>>> >>> +        self.executables = ' '.join(executables)
>>>>>>>>>>>>> >>> +        self.explanations_txt = explanations_txt
>>>>>>>>>>>>> >>> +        self.project_name = 'RTEMS-5'
>>>>>>>>>>>>> >>> +    def run(self, set_name, symbol_file):
>>>>>>>>>>>>> >>> +        covoar_result_dir = path.join(self.base_result_dir,
>>>>>>>>>>>>> set_name)
>>>>>>>>>>>>> >>> +        if (not path.exists(covoar_result_dir)):
>>>>>>>>>>>>> >>> +            path.mkdir(covoar_result_dir)
>>>>>>>>>>>>> >>> +        if (not path.exists(symbol_file)):
>>>>>>>>>>>>> >>> +            raise error.general('symbol set file:
>>>>>>>>>>>>> coverage %s was not
>>>>>>>>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>>>>>>>>> >>> +        command = ('covoar -S ' + symbol_file
>>>>>>>>>>>>> >>> +                  + ' -O ' + covoar_result_dir
>>>>>>>>>>>>> >>> +                  + ' -E ' + self.explanations_txt
>>>>>>>>>>>>> >>> +                  + ' -p ' + self.project_name + ' ' +
>>>>>>>>>>>>> self.executables)
>>>>>>>>>>>>> >>> +        log.notice('Running covoar for %s' % (set_name))
>>>>>>>>>>>>> >>> +        print( 'covoar results directory:\n' +
>>>>>>>>>>>>> covoar_result_dir )
>>>>>>>>>>>>> >>> +        executor = execute.execute(verbose = True, output
>>>>>>>>>>>>> >>> self.output_handler)
>>>>>>>>>>>>> >>> +        exit_code = executor.shell(command,
>>>>>>>>>>>>> cwd=os.getcwd())
>>>>>>>>>>>>> >>> +        if (exit_code[0] != 0):
>>>>>>>>>>>>> >>> +            raise error.general('covoar failure exit
>>>>>>>>>>>>> code: %d' %
>>>>>>>>>>>>> >>> (exit_code[0]))
>>>>>>>>>>>>> >>> +        log.notice('Coverage run for %s finished
>>>>>>>>>>>>> successfully.' %
>>>>>>>>>>>>> >>> (set_name))
>>>>>>>>>>>>> >>> +        log.notice('------------------
>>>>>>>>>>>>> >>> +    def output_handler(self, text):
>>>>>>>>>>>>> >>> +        log.notice('%s' % (text))
>>>>>>>>>>>>> >>> +class coverage_run(object):
>>>>>>>>>>>>> >>> +    Coverage analysis support for rtems-test
>>>>>>>>>>>>> >>> +    def __init__(self, p_macros, coverage_arg, target):
>>>>>>>>>>>>> >>> +        Constructor
>>>>>>>>>>>>> >>> +        self.macros = p_macros
>>>>>>>>>>>>> >>> +        self.build_dir = self.macros['_cwd']
>>>>>>>>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>>>>>>>>> >>> +        self.test_dir = path.join(self.build_dir,
>>>>>>>>>>>>> 'coverage')
>>>>>>>>>>>>> >>> +        if (not path.exists(self.test_dir)):
>>>>>>>>>>>>> >>> +            path.mkdir(self.test_dir)
>>>>>>>>>>>>> >>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>>>>>>>>> >>> +        self.rtscripts = self.macros.expand(self.macros
>>>>>>>>>>>>> ['_rtscripts'])
>>>>>>>>>>>>> >>> +        self.coverage_config_path =
>>>>>>>>>>>>> path.join(self.rtscripts,
>>>>>>>>>>>>> >>> 'coverage')
>>>>>>>>>>>>> >>> +        self.symbol_config_path =
>>>>>>>>>>>>> path.join(self.coverage_config_path,
>>>>>>>>>>>>> 'symbol-sets.ini')
>>>>>>>>>>>>> >>> +        self.symbol_select_path =
>>>>>>>>>>>>> 'symbol-select.ini')
>>>>>>>>>>>>> >>> +        self.executables = None
>>>>>>>>>>>>> >>> +        self.symbol_sets = []
>>>>>>>>>>>>> >>> +        self.no_clean = int(self.macros['_no_clean'])
>>>>>>>>>>>>> >>> +        self.report_format =
>>>>>>>>>>>>> self.macros['cov_report_format']
>>>>>>>>>>>>> >>> +        self.coverage_arg = coverage_arg
>>>>>>>>>>>>> >>> +    def run(self):
>>>>>>>>>>>>> >>> +        try:
>>>>>>>>>>>>> >>> +            if self.executables is None:
>>>>>>>>>>>>> >>> +                raise error.general('no test executables
>>>>>>>>>>>>> provided.')
>>>>>>>>>>>>> >>> +            build_dir = build_path_generator(self.exec
>>>>>>>>>>>>> utables,
>>>>>>>>>>>>> >>> self.target).run()
>>>>>>>>>>>>> >>> +            parser = symbol_parser(self.symbol_conf
>>>>>>>>>>>>> ig_path,
>>>>>>>>>>>>>  self.symbol_select_path,
>>>>>>>>>>>>> >>> +                                   self.coverage_arg,
>>>>>>>>>>>>> >>> +                                   build_dir)
>>>>>>>>>>>>> >>> +            parser.run()
>>>>>>>>>>>>> >>> +            covoar_runner = covoar(self.test_dir,
>>>>>>>>>>>>> >>> +                                   self.executables,
>>>>>>>>>>>>> >>> self.explanations_txt)
>>>>>>>>>>>>> >>> +            covoar_runner.run('score',
>>>>>>>>>>>>> self.symbol_select_path)
>>>>>>>>>>>>> >>> +            self._generate_reports();
>>>>>>>>>>>>> >>> +            self._summarize();
>>>>>>>>>>>>> >>> +        finally:
>>>>>>>>>>>>> >>> +            self._cleanup();
>>>>>>>>>>>>> >>> +    def _generate_reports(self):
>>>>>>>>>>>>> >>> +        log.notice('Generating reports')
>>>>>>>>>>>>> >>> +        if self.report_format == 'html':
>>>>>>>>>>>>> >>> +            report = report_gen_html(self.symbol_sets,
>>>>>>>>>>>>> >>> +                                     self.build_dir,
>>>>>>>>>>>>> >>> +                                     self.rtdir)
>>>>>>>>>>>>> >>> +            report.generate()
>>>>>>>>>>>>> >>> +            report.add_covoar_src_path()
>>>>>>>>>>>>> >>> +    def _cleanup(self):
>>>>>>>>>>>>> >>> +        if not self.no_clean:
>>>>>>>>>>>>> >>> +            log.notice('***Cleaning tempfiles***')
>>>>>>>>>>>>> >>> +            for exe in self.executables:
>>>>>>>>>>>>> >>> +                trace_file = exe + '.cov'
>>>>>>>>>>>>> >>> +                if path.exists(trace_file):
>>>>>>>>>>>>> >>> +                    os.remove(trace_file)
>>>>>>>>>>>>> >>> +    def _summarize(self):
>>>>>>>>>>>>> >>> +        log.notice('Coverage analysis finished. You can
>>>>>>>>>>>>> find results in
>>>>>>>>>>>>> >>> %s' % (self.build_dir))
>>>>>>>>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>>>>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>>>>>>>>> >>> --- a/tester/rt/test.py
>>>>>>>>>>>>> >>> +++ b/tester/rt/test.py
>>>>>>>>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>>>>>>>> >>>  from rtemstoolkit import reraise
>>>>>>>>>>>>> >>>  from rtemstoolkit import stacktraces
>>>>>>>>>>>>> >>>  from rtemstoolkit import version
>>>>>>>>>>>>> >>> +from rtemstoolkit import check
>>>>>>>>>>>>> >>>  from . import bsps
>>>>>>>>>>>>> >>>  from . import config
>>>>>>>>>>>>> >>>  from . import console
>>>>>>>>>>>>> >>>  from . import report
>>>>>>>>>>>>> >>> +from . import coverage
>>>>>>>>>>>>> >>>  class log_capture(object):
>>>>>>>>>>>>> >>>      def __init__(self):
>>>>>>>>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>>>>>>>> >>>      def run(self):
>>>>>>>>>>>>> >>>          self.thread = threading.Thread(target =
>>>>>>>>>>>>> self.runner,
>>>>>>>>>>>>> >>> -                                       name = 'test[%s]' %
>>>>>>>>>>>>> >>> path.basename(self.executable))
>>>>>>>>>>>>> >>> +                            name = 'test[%s]' %
>>>>>>>>>>>>> >>>          self.thread.start()
>>>>>>>>>>>>> >>>      def is_alive(self):
>>>>>>>>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>>>>>>>>> >>>      for test in tests:
>>>>>>>>>>>>> >>>          test.kill()
>>>>>>>>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>>>>>>>>> >>> +    coverage.executables = executables
>>>>>>>>>>>>> >>> +    coverage.run()
>>>>>>>>>>>>> >>>  def run(command_path = None):
>>>>>>>>>>>>> >>>      import sys
>>>>>>>>>>>>> >>>      tests = []
>>>>>>>>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>>>>>>>>> >>>      opts = None
>>>>>>>>>>>>> >>>      default_exefilter = '*.exe'
>>>>>>>>>>>>> >>>      try:
>>>>>>>>>>>>> >>> -        optargs = { '--rtems-tools': 'The path to the
>>>>>>>>>>>>> RTEMS tools',
>>>>>>>>>>>>> >>> -                    '--rtems-bsp':   'The RTEMS BSP to
>>>>>>>>>>>>> run the test on',
>>>>>>>>>>>>> >>> -                    '--user-config': 'Path to your local
>>>>>>>>>>>>> user
>>>>>>>>>>>>> >>> configuration INI file',
>>>>>>>>>>>>> >>> -                    '--report-mode': 'Reporting modes,
>>>>>>>>>>>>> failures
>>>>>>>>>>>>> >>> (default),all,none',
>>>>>>>>>>>>> >>> -                    '--list-bsps':   'List the supported
>>>>>>>>>>>>> BSPs',
>>>>>>>>>>>>> >>> -                    '--debug-trace': 'Debug trace based
>>>>>>>>>>>>> on specific
>>>>>>>>>>>>> >>> flags',
>>>>>>>>>>>>> >>> -                    '--filter':      'Glob that
>>>>>>>>>>>>> executables must match
>>>>>>>>>>>>> >>> to run (default: ' +
>>>>>>>>>>>>> >>> +        optargs = { '--rtems-tools':    'The path to the
>>>>>>>>>>>>> RTEMS tools',
>>>>>>>>>>>>> >>> +                    '--rtems-bsp':      'The RTEMS BSP to
>>>>>>>>>>>>> run the test
>>>>>>>>>>>>> >>> on',
>>>>>>>>>>>>> >>> +                    '--user-config':    'Path to your
>>>>>>>>>>>>> local user
>>>>>>>>>>>>> >>> +                    '--report-mode':    'Reporting modes,
>>>>>>>>>>>>> failures
>>>>>>>>>>>>> >>> +                    '--list-bsps':      'List the
>>>>>>>>>>>>> supported BSPs',
>>>>>>>>>>>>> >>> +                    '--debug-trace':    'Debug trace
>>>>>>>>>>>>> based on specific
>>>>>>>>>>>>> >>> flags',
>>>>>>>>>>>>> >>> +                    '--filter':         'Glob that
>>>>>>>>>>>>> executables must
>>>>>>>>>>>>> >>> match to run (default: ' +
>>>>>>>>>>>>> >>>                                default_exefilter + ')',
>>>>>>>>>>>>> >>> -                    '--stacktrace':  'Dump a stack trace
>>>>>>>>>>>>> on a user
>>>>>>>>>>>>> >>> termination (^C)' }
>>>>>>>>>>>>> >>> +                    '--stacktrace':     'Dump a stack
>>>>>>>>>>>>> trace on a user
>>>>>>>>>>>>> >>> termination (^C)',
>>>>>>>>>>>>> >>> +                    '--coverage':       'Perform coverage
>>>>>>>>>>>>> analysis of
>>>>>>>>>>>>> >>> test executables.'}
>>>>>>>>>>>>> >>>          mailer.append_options(optargs)
>>>>>>>>>>>>> >>>          opts = options.load(sys.argv,
>>>>>>>>>>>>> >>>                              optargs = optargs,
>>>>>>>>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>>>>>>>>> >>>              raise error.general('RTEMS BSP not provided
>>>>>>>>>>>>> or an invalid
>>>>>>>>>>>>> >>> option')
>>>>>>>>>>>>> >>>          bsp = config.load(bsp[1], opts)
>>>>>>>>>>>>> >>>          bsp_config = opts.defaults.expand(opts.defa
>>>>>>>>>>>>> ults['tester'])
>>>>>>>>>>>>> >>> +        coverage_enabled = opts.find_arg('--coverage')
>>>>>>>>>>>>> >>> +        if coverage_enabled:
>>>>>>>>>>>>> >>> +            if len(coverage_enabled) == 2:
>>>>>>>>>>>>> >> Is this to check if sets have been provided to
>>>>>>>>>>>>> --coverage=score,sapi, that
>>>>>>>>>>>>> >> kind of thing? If so the variable name coverage_enabled
>>>>>>>>>>>>> doesn't make sense
>>>>>>>>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets)
>>>>>>>>>>>>> will make more
>>>>>>>>>>>>> >> sense for both cases.
>>>>>>>>>>>>> > That's a good point.
>>>>>>>>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>>>>>>>>> > Because it's still checking whether the option is given or
>>>>>>>>>>>>> > not. symbol_sets might create confusion.
>>>>>>>>>>>>> > Will that be OK ?
>>>>>>>>>>>>> That name might collide with your class object (coverage)?
>>>>>>>>>>>> That's actually why I kept it as coverage_enabled.
>>>>>>>>>>>> I think we can go for coverage_option (?)
>>>>>>>>>>>>> >>> +                coverage_runner =
>>>>>>>>>>>>> coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>> coverage_enabled[1],
>>>>>>>>>>>>> opts.defaults['target'])
>>>>>>>>>>>>> >>> +            else:
>>>>>>>>>>>>> >>> +                coverage_runner =
>>>>>>>>>>>>> >>> 0,
>>>>>>>>>>>>> >>>          report_mode = opts.find_arg('--report-mode')
>>>>>>>>>>>>> >>>          if report_mode:
>>>>>>>>>>>>> >>>              if report_mode[1] != 'failures' and \
>>>>>>>>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>>>>>>>>> >>>                      reports.failures(),
>>>>>>>>>>>>> >>>                      'Log', '===', ''] + output.get()
>>>>>>>>>>>>> >>>              mail.send(to_addr, subject,
>>>>>>>>>>>>> os.linesep.join(body))
>>>>>>>>>>>>> >>> +            coverage_run(opts, coverage_runner,
>>>>>>>>>>>>> executables)
>>>>>>>>>>>>> >>>      except error.general as gerr:
>>>>>>>>>>>>> >>>          print(gerr)
>>>>>>>>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>>>>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>>>>>>>>> >>>  # The Leon 3 QEMU BSP
>>>>>>>>>>>>> >>> -[leon3-qemu]
>>>>>>>>>>>>> >>> +[leon3-qemu-cov]
>>>>>>>>>>>>> >>>  bsp               = leon3-qemu
>>>>>>>>>>>>> >>>  arch              = sparc
>>>>>>>>>>>>> >>> +target            = sparc-rtems5
>>>>>>>>>>>>> >>>  tester            = %{_rtscripts}/qemu.cfg
>>>>>>>>>>>>> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>>>>>>>>>> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>>>>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>>>>> >>> index 0000000..a2ec7bc
>>>>>>>>>>>>> >>> --- /dev/null
>>>>>>>>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>>>>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>>>>>>>>> 'rtems-tools'.
>>>>>>>>>>>>> or without
>>>>>>>>>>>>> conditions are
>>>>>>>>>>>>> >>> met:
>>>>>>>>>>>>> copyright
>>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>>> above copyright
>>>>>>>>>>>>> >>> notice,
>>>>>>>>>>>>> the
>>>>>>>>>>>>> >>> documentation
>>>>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>>>>> >>> "AS IS"
>>>>>>>>>>>>> NOT LIMITED TO,
>>>>>>>>>>>>> >>> THE
>>>>>>>>>>>>> PARTICULAR
>>>>>>>>>>>>> >>> PURPOSE
>>>>>>>>>>>>> OR CONTRIBUTORS
>>>>>>>>>>>>> >>> BE
>>>>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>>>>> PROFITS; OR
>>>>>>>>>>>>> >>> BUSINESS
>>>>>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>>>>>> >>> IN
>>>>>>>>>>>>> NEGLIGENCE OR
>>>>>>>>>>>>> >>> OTHERWISE)
>>>>>>>>>>>>> EVEN IF ADVISED OF
>>>>>>>>>>>>> >>> THE
>>>>>>>>>>>>> >>> +[symbol-sets]
>>>>>>>>>>>>> >>> +sets = score,rtems
>>>>>>>>>>>>> >>> +[libraries]
>>>>>>>>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>>>>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>>>>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>>>>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>>>>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>>>>>>>>> >>>  # Qemu common option patterns.
>>>>>>>>>>>>> >>> -#%define qemu_opts_base   -no-reboot -monitor none
>>>>>>>>>>>>> -serial stdio
>>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>>> >>> -%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>>>>>>>> mon:stdio
>>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>>> >>> +%define qemu_opts_base   -no-reboot -monitor none -serial
>>>>>>>>>>>>> stdio
>>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>>> >>> +#%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>>>>>>>> mon:stdio
>>>>>>>>>>>>> >>> -nographic
>>>>>>>>>>>>> >>>  %define qemu_opts_no_net -net none
>>>>>>>>>>>>> >>> 2.14.3
>>>>>>>>>>>>> >>> _______________________________________________
>>>>>>>>>>>>> >>> devel mailing list
>>>>>>>>>>>>> >>> devel at rtems.org
>>>>>>>>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>>> > devel mailing list
>>>>>>>>>>>>> > devel at rtems.org
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/ccc7e42c/attachment-0001.html>
