[PATCH] Generate coverage analysis Report
Joel Sherrill
joel at rtems.org
Wed Jun 6 03:01:14 UTC 2018
On Tue, Jun 5, 2018, 9:54 PM Chris Johns <chrisj at rtems.org> wrote:
> On 31/5/18 6:44 am, Vijay Kumar Banerjee wrote:
> > On 31 May 2018 at 02:02, Joel Sherrill <joel at rtems.org <mailto:
> joel at rtems.org>>
> > wrote:
> > On Wed, May 30, 2018 at 3:29 PM, Vijay Kumar Banerjee
> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
> > On 31 May 2018 at 00:28, Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> > I may not understand correctly but there is test_run and
> > coverage_run. Someone
> > suggested making coverage_running an option to test_run. If
> that's
> > what's being
> > asked for, then I think doing it in a follow up patch is OK.
> > If that's the intended request, perhaps a ticket should be
> filed.
> > Sorry for all the confusion.
> > This patch doesn't change the way test works. It only adds an
> option to run
> > the coverage script. coverage_run just runs the
> coverage.coverage_run
> > :) And I am saying if we want to have one test_run with an argument,
> do it as
> > a future work iteration. File a ticket.
> > We need to get the code working on the master.
> > Okay, we can keep that as a future work (I haven't thought about it
> though). :)
> > Getting it to work on master is our primary objective.
> Was a ticket raised to removing 'coverage_run' and to use 'test_run'?
I haven't seen tickets for any of the issues we identified.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180605/08ecd6c2/attachment.html>
