[PATCH] Generate coverage analysis Report
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Jun 6 04:07:24 UTC 2018
On Wed, 6 Jun 2018, 08:31 Joel Sherrill, <joel at rtems.org> wrote:
> On Tue, Jun 5, 2018, 9:54 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 31/5/18 6:44 am, Vijay Kumar Banerjee wrote:
>> > On 31 May 2018 at 02:02, Joel Sherrill <joel at rtems.org <mailto:
>> joel at rtems.org>>
>> > wrote:
>> > On Wed, May 30, 2018 at 3:29 PM, Vijay Kumar Banerjee
>> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>> > On 31 May 2018 at 00:28, Joel Sherrill <joel at rtems.org
>> > <mailto:joel at rtems.org>> wrote:
>> > I may not understand correctly but there is test_run and
>> > coverage_run. Someone
>> > suggested making coverage_running an option to test_run. If
>> that's
>> > what's being
>> > asked for, then I think doing it in a follow up patch is OK.
>> > If that's the intended request, perhaps a ticket should be
>> filed.
>> > Sorry for all the confusion.
>> > This patch doesn't change the way test works. It only adds an
>> option to run
>> > the coverage script. coverage_run just runs the
>> coverage.coverage_run
>> > :) And I am saying if we want to have one test_run with an
>> argument, do it as
>> > a future work iteration. File a ticket.
>> > We need to get the code working on the master.
>> > Okay, we can keep that as a future work (I haven't thought about it
>> though). :)
>> > Getting it to work on master is our primary objective.
>> Was a ticket raised to removing 'coverage_run' and to use 'test_run'?
> I haven't seen tickets for any of the issues we identified.
was there supposed to be tickets for each issue?
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180606/fe84b4d8/attachment.html>
