Thoughts on Reusing FreeBSD msun tests
Thu Jun 7 19:02:08 UTC 2018
Well, after this summer, maybe you can write a couple of
paravirtualized x86_64 BSPs to run under *nix, *BSD, MacOS, and
Windows to test newlib and rtems on native hosting.
On Thu, Jun 7, 2018 at 2:59 PM, Joel Sherrill <joel at rtems.org> wrote:
> Sigh.. that makes things even more complex.
> As a general rule, we probably should just set a goal to run newlib
> tests on an RTEMS BSP and help improve newlib's tests.
> --joel
> On Thu, Jun 7, 2018 at 1:40 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Relatedly, you may also want to read through
>> https://sourceware.org/ml/newlib/2017/msg01216.html
>> On Wed, Jun 6, 2018 at 12:05 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > Hi
>> > I can't find this on FreeBSD head but it looks like a decent
>> > set of tests for fenv and other libm functionality.
>> > http://web.mit.edu/freebsd/head/tools/regression/lib/msun/
>> > Thoughts on incorporating this into our tests?
>> > --joel
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
