RISC-V tool chain
Mon Jun 11 05:08:47 UTC 2018
On 08/06/18 07:54, Chris Johns wrote:
> On 06/06/2018 19:57, Sebastian Huber wrote:
>> On 06/06/18 07:16, Sebastian Huber wrote:
>>> We could use an unofficial mirror on Github, e.g.
>>> https://codeload.github.com/bminor/binutils-gdb/tar.gz/c61b06a19a34baab66e3809c7b41b0c31009ed9f
>>> My main concern with using all these different download sources is that this
>>> will likely not work if we want to use it in five or ten years due to URL
>>> changes.
>> A proof of concept patch series is here:
>> https://lists.rtems.org/pipermail/devel/2018-June/021951.html
>> One problem with the using Binutils/GDB Git snapshots is that they share a
>> repository.
> Yes.
>> I uses currently the Git mirror of some random user ("bminor"). I
>> will try to set up a Binutils Git mirror for RTEMS. We don't need an automatic
>> synchronization. We just have to do this for an RSB update.
> What would be involved in making it automatic?
> You could add cron a job on dispatch.rtems.org once a day. It would be a nice
> server to have it close to current.:)
Ok, I will try to create a cron job.
Do we want to mirror all branches or just the ones we use?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
