[PATCH 3/6] shgen: Import from RTEMS
Mon Jun 11 14:21:43 UTC 2018
On Mon, Jun 11, 2018 at 5:35 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 11/6/18 5:49 pm, Sebastian Huber wrote:
>> On 11/06/18 08:22, Joel Sherrill wrote:
>>>     >     >>> Does this tool need to move over?
>>>     >     >> I would like to move all host tools out of the RTEMS
>>>     repository
>>>     >     to simplify the
>>>     >     >> build. If we get rid of the host tools, then we have only to
>>>     >     deal with the
>>>     >     >> cross-build tools.
>>>     >     > This is a good thing to do, thank you.
>>>     >     >>>    Is the sh arch active?
>>>     >     >> I don't know.
>>>     >     > I suggest we remove this code until someone needs it and can
>>>     >     resolve this issue.
>>>     >     > The code is in the 4.11 releases so is easy to find.
>>>     >     The shgen tool is used to build the gensh1 and gensh2 BSPs to
>>>     >     generate
>>>     >     the scitab.c source file.
>>> Sorry..I missed this.
>>>     >     One option to get rid of the shgen tool would be to remove the
>>>     >     CPU_CLOCK_RATE_HZ BSP option.
>>> Ok. Or retroactively deprecate in 4.11
>> The tool generates a scitab.c with this header:
>>  * DO NOT EDIT - this file is automatically generated by shgen
>> 5.07adc7f7e37a_modified
>>  * Copyright (c) 1998,1999,2000 Ralf Corsepius (corsepiu at faw.uni-ulm.de)
>> /* This file is not copyrighted */
>> Files with such a header are not acceptable for an import into the RTEMS sources
>> repository  from my point of view.
> I agree.
>> We have three options now:
>> 1. Keep the tools in the RTEMS source repository.
> I prefer they are moved out.
>> 2. Add GPL software to rtems-tools.
> I prefer this not happen. I have worked hard over the life of repo to be careful
> not to have GPL in the repo.
Option 2.b: Create contrib-tools repo with third party licensed softwares.
>> 3. Remove the gensh1 and gensh2 BSPs.
> What is in the generated file?
> We use weak symbols in the Zynq BSP to allow us to override defaults. Could this
> approach be used?
> Chris
> devel mailing list
> devel at rtems.org
