[GSoC - x86_64] Using FreeBSD's UEFI loader for RTEMS static binaries
Wed Jun 13 19:33:48 UTC 2018
On Wed, Jun 13, 2018, 6:57 PM Amaan Cheval <amaan.cheval at gmail.com> wrote:
> On Wed, Jun 13, 2018 at 9:35 PM, Gedare Bloom <gedare at rtems.org> wrote:
> > On Wed, Jun 13, 2018 at 11:33 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
> >> Hi!
> >> As we discussed in the last thread on the topic[1], I'm trying to use
> >> FreeBSD's loader.efi directly with RTEMS' generated static binaries
> >> (since FreeBSD's loader.efi has an ELF loader).
> >> In brief, I did this by:
> >> - Installing FreeBSD in QEMU with UEFI firmware
> >> - Confirming that FreeBSD's loader.efi is in fact used
> >> - Replacing FreeBSD's ELF kernel with a "custom" kernel[2] with an
> RTEMS ELF
> >> - Verifying that the code running after FreeBSD's loader.efi is in
> >> fact the "RTEMS ELF" by attaching gdb to QEMU (the rtems ELF is simply
> >> a while(1) loop compiled with RTEMS' tools - see later on why I can't
> >> do something more elaborate)
> >> Some more details of the process I followed for testing this:
> >> https://gist.github.com/AmaanC/42faa131ee97a1d6c4c7c25c29f0fde9z
> >> I think this method is superior to the PIC RTEMS method because:
> >> - FreeBSD uses it
> >> - RTEMS retains static ELF binaries, which can likely easily be
> >> combined with a Multiboot header + protect mode starter code
> >> - FreeBSD has methods to provide ACPI related hints to their ELF
> >> kernel - this might make our implementation with regards to ACPI
> >> simpler too
> >> Regarding some concerns Chris had with linker options and whatnot,
> >> here's what FreeBSD uses:
> >> https://www.freebsd.org/doc/en/books/arch-handbook/boot-kernel.html
> >> Here's what I used (with the code being a simple while(1) loop):
> >>   x86_64-rtems5-gcc ktest.c -c -nostdlib
> >>   x86_64-rtems5-ld ktest.o -e main -o kernel
> >> What I need input on:
> >> - Right now, we use the following RTEMS code for testing:
> >> int main() {
> >>   while(1) {}
> > It's not really an RTEMS code, it is a C program (ktest.c) compiled
> > with the RTEMS-flavored toolchain, right?
> Yeah, for now that's right. I'm going to conduct the same gdb based
> debug-stepping style test for RTEMS setting boot_card as the entry
> point soon - for now, it crashes QEMU with:
> qemu: fatal: Trying to execute code outside RAM or ROM at
> 0x00000000000b0000
> RAX=00000000006004c0 RBX=00000000006003d8 RCX=0000000037f36000
> RDX=0000000000400000
> RSI=0000000004000000 RDI=0000000000000180 RBP=00000000006003d8
> RSP=000000003c589fb8
> I see that it reaches that stage even from some code it ought not to
> be executing, so I'll look into what that may be about.
> > It would be nice to get an RTEMS x86-64 BSP to start, at least to
> > confirm that you reach _start, and then even you can try to make it to
> > the "boot_card" startup sequence.
> Right, I'll aim to have that working soon (using boot_card as the
> entry, since "_start" usually does the bootloader stuff that we're now
> offloading to FreeBSD, and then calls boot_card anyway).
To be consistent with other BSPs, I have a start.c on the Deos BSPs. It
fetches the boot arguments which are passed to boot_card() and does some
other setup specific to Deos.
No need to do this now but there is a good reason to follow the pattern.
Start doesn't have to be in assembly.
> >> That's literally it, because we have no access to standard libraries,
> >> and loader.efi calls ExitBootServices, after which we can't just
> >> easily directly access video memory (at 0xb8000 for eg.) to print to
> >> the screen. The way FreeBSD handles this is by initializing the
> >> console and printing to that - I haven't been able to easily port that
> >> yet.
> >> The question is - should I start with that effort (i.e. bringing
> >> printk console functionality to RTEMS) the way FreeBSD does? This way,
> >> we skip the bootloader for now by simply using the one built on the
> >> real FreeBSD - if the console prints and more elaborate linking tests
> >> work fine, we can be certain that this works. If _not_, I believe the
> >> console initialization code will likely still remain the same since
> >> we'll want to do it similar to how FreeBSD does it.
> > I think this approach to getting a console to work may be reasonable,
> > assuming the FreeBSD console is not much more complicated than what
> > RTEMS needs. ...
> I can't say about this yet, but I'll look into it (and perhaps
> simplifying it as we port it if it _is_ too complicated).
> >> What do you think?
> >> Cheers,
> >> Amaan
> >> [1] https://lists.rtems.org/pipermail/devel/2018-June/022052.html
> >> [2] https://www.freebsd.org/doc/handbook/kernelconfig-building.html
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180613/5de88ef1/attachment-0001.html>
