[GSoC - x86_64] Using FreeBSD's UEFI loader for RTEMS static binaries
Thu Jun 14 05:55:35 UTC 2018
On 14/06/2018 05:33, Joel Sherrill wrote:
> On Wed, Jun 13, 2018, 6:57 PM Amaan Cheval <amaan.cheval at gmail.com
> <mailto:amaan.cheval at gmail.com>> wrote:
>     On Wed, Jun 13, 2018 at 9:35 PM, Gedare Bloom <gedare at rtems.org
>     <mailto:gedare at rtems.org>> wrote:
>     > On Wed, Jun 13, 2018 at 11:33 AM, Amaan Cheval <amaan.cheval at gmail.com
>     >> Hi!
>     >> As we discussed in the last thread on the topic[1], I'm trying to use
>     >> FreeBSD's loader.efi directly with RTEMS' generated static binaries
>     >> (since FreeBSD's loader.efi has an ELF loader).
>     >> In brief, I did this by:
>     >> - Installing FreeBSD in QEMU with UEFI firmware
>     >> - Confirming that FreeBSD's loader.efi is in fact used
>     >> - Replacing FreeBSD's ELF kernel with a "custom" kernel[2] with an RTEMS ELF
>     >> - Verifying that the code running after FreeBSD's loader.efi is in
>     >> fact the "RTEMS ELF" by attaching gdb to QEMU (the rtems ELF is simply
>     >> a while(1) loop compiled with RTEMS' tools - see later on why I can't
>     >> do something more elaborate)
>     >> Some more details of the process I followed for testing this:
>     >> https://gist.github.com/AmaanC/42faa131ee97a1d6c4c7c25c29f0fde9z
>     >> I think this method is superior to the PIC RTEMS method because:
>     >> - FreeBSD uses it
>     >> - RTEMS retains static ELF binaries, which can likely easily be
>     >> combined with a Multiboot header + protect mode starter code
>     >> - FreeBSD has methods to provide ACPI related hints to their ELF
>     >> kernel - this might make our implementation with regards to ACPI
>     >> simpler too
I agree this is the best approach. In time we can host on our file server a
package of FreeBSD binaries that boot an RTEMS kernel.
>     >> Regarding some concerns Chris had with linker options and whatnot,
>     >> here's what FreeBSD uses:
>     >> https://www.freebsd.org/doc/en/books/arch-handbook/boot-kernel.html
>     >> Here's what I used (with the code being a simple while(1) loop):
>     >>   x86_64-rtems5-gcc ktest.c -c -nostdlib
>     >>   x86_64-rtems5-ld ktest.o -e main -o kernel
Nice, this looks fine. It is normal for a bare metal piece of C code.
>     >> What I need input on:
>     >> - Right now, we use the following RTEMS code for testing:
>     >> int main() {
>     >>   while(1) {}
>     > It's not really an RTEMS code, it is a C program (ktest.c) compiled
>     > with the RTEMS-flavored toolchain, right?
>     Yeah, for now that's right. I'm going to conduct the same gdb based
>     debug-stepping style test for RTEMS setting boot_card as the entry
>     point soon - for now, it crashes QEMU with:
>     qemu: fatal: Trying to execute code outside RAM or ROM at 0x00000000000b0000
>     RAX=00000000006004c0 RBX=00000000006003d8 RCX=0000000037f36000
>     RDX=0000000000400000
>     RSI=0000000004000000 RDI=0000000000000180 RBP=00000000006003d8
>     RSP=000000003c589fb8
>     I see that it reaches that stage even from some code it ought not to
>     be executing, so I'll look into what that may be about.
Hmm.
>     > It would be nice to get an RTEMS x86-64 BSP to start, at least to
>     > confirm that you reach _start, and then even you can try to make it to
>     > the "boot_card" startup sequence.
>     Right, I'll aim to have that working soon (using boot_card as the
>     entry, since "_start" usually does the bootloader stuff that we're now
>     offloading to FreeBSD, and then calls boot_card anyway).
> To be consistent with other BSPs, I have a start.c on the Deos BSPs. It fetches
> the boot arguments which are passed to boot_card() and does some other setup
> specific to Deos.
> No need to do this now but there is a good reason to follow the pattern. Start
> doesn't have to be in assembly.
>     >> That's literally it, because we have no access to standard libraries,
>     >> and loader.efi calls ExitBootServices, after which we can't just
>     >> easily directly access video memory (at 0xb8000 for eg.) to print to
>     >> the screen. The way FreeBSD handles this is by initializing the
>     >> console and printing to that - I haven't been able to easily port that
>     >> yet.
>     >> The question is - should I start with that effort (i.e. bringing
>     >> printk console functionality to RTEMS) the way FreeBSD does? This way,
>     >> we skip the bootloader for now by simply using the one built on the
>     >> real FreeBSD - if the console prints and more elaborate linking tests
>     >> work fine, we can be certain that this works. If _not_, I believe the
>     >> console initialization code will likely still remain the same since
>     >> we'll want to do it similar to how FreeBSD does it.
>     > I think this approach to getting a console to work may be reasonable,
>     > assuming the FreeBSD console is not much more complicated than what
>     > RTEMS needs. ...
>     I can't say about this yet, but I'll look into it (and perhaps
>     simplifying it as we port it if it _is_ too complicated).
It has been a couple of years but I think FreeBSD contains some of the Intel
code to interface to UEFI and via this you can get to the UEFI console. This
should be easy but it comes with a side effect.
UEFI boots in graphics mode and so it's console on a PC is a slow scroll one. On
boards like a Minnow using the UEFI console has the advantage of being able to
support any redirection UEFI has enabled such as a serial port. The disadvantage
of this is performance and overhead. In time this may be a boot option.
What I am not sure is the boundary between UEFI and the kernel and what is
enabled or available when the kernel is loaded.
>     >> What do you think?
Awesome work.
Thanks
