[PATCH] Fix --show-commands.
Thu Jun 14 07:40:14 UTC 2018
On 14/6/18 5:34 pm, Christian Mauderer wrote:
> Am 14.06.2018 um 09:31 schrieb Chris Johns:
>> On 14/6/18 4:27 pm, Sebastian Huber wrote:
>>> Hello,
>>> On 13/06/18 13:27, Christian Mauderer wrote:
>>>> OK. I'll have a look at all repos in the next few days where the
>>>> submodule is used and change the URL. I'll post a message to the mailing
>>>> lists as soon as it is done to inform the user that a "git submodule
>>>> sync" fixes the address.
>>> since we have to change the URL anyway, would it be possible to rename this
>>> repository from "rtems_waf" to "rtems-waf" similar to all other RTEMS repositories?
>> The name would have to be transformed into 'rtems_waf' in each submodule as:
>>   import rtems-waf
>> is not valid Python. Can git perform this type of transformation?
>> Chris
> Hello Chris,
> basically it's no problem to use a URL that doesn't have the same name
> as the directory. You just have to use a
>   git submodule add some-url target-path-name
> So it's not really a problem. It only means that the one adding the
> submodule to some new repo has to use the right target path.
This makes sense. I am OK with a name change for the repo as I like consistent
naming so if this can be made to work that would be good.
The README in the repo would need to be updated.
If you want the repo's name changed please let me know. I can update cgit's config.
