[PATCH] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Jun 19 03:36:04 UTC 2018
On Tue, 19 Jun 2018, 08:54 Chris Johns, <chrisj at rtems.org> wrote:
> On 19/06/2018 13:16, Vijay Kumar Banerjee wrote:
> > I would like to get my 22 patches pushed to master before moving on
> this topic.
> > This is the report I generate:
> https://ftp.rtems.org/pub/rtems/people/chrisj/coverage/leon3/leon3-qemu-report.html
> > How does this look?
> > The report looks good.
> > This report is from two subsystems score and rtems
> > that are mentioned in the symbols ini file.
> Excellent, I will push the patches. I have just run all the samples and
> updated
> the report.
Awesome! report looks good.
> I get the size warning ...
Yes, I'm getting these warnings as well.
> INFO: DesiredSymbols::createCoverageMap - Attempt to create unified
> coverage
> maps for _Workspace_Allocate_or_fatal_error with different sizes
> (/opt/work/chris/rtems/kernel/bsps/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture.exe/80!=
> /opt/work/chris/rtems/kernel/bsps/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp.exe/60)
> My version of covoar has the DWARF function details from for a CU for an
> executable so it will be interesting to see what this shows. I will take a
> look
> at some point.
I was hoping that these warnings would go away after your covoar patches
> Also the execute wrapper needs to catch stderr and redirect that to the
> log. I
> will take a look at that.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180619/f1ada61c/attachment-0001.html>
