[GSOC - Tracing] Status Update
Vidushi Vashishth
reachvidu at gmail.com
Thu Jun 28 05:12:56 UTC 2018
>Run on what? RTEMS?
yes.
>Are there any RTEMS repos with your work?
I havent pushed my code since it is throwing errors. Should I push it
nonetheless for you to see? Or create another repo?
>RTEMS does not support `system()`.
Does RTEMS support fdopen or popen? I am trying to execute the babeltrace
command on the shell, from within the c program. I could use babeltrace C
API instead but Gedare suggested during a meeting that it might not be
integrable with RTEMS.
>Could please explain how you are integrating `program.c`?
I have created a new shell utility function in the
*rtems/cpukit/libmisc/shell/main_rtrace.c*. It saves the raw trace buffer
to a file and then uses the logic of `program.c`
to convert it into CTF traces.
On Thu, Jun 28, 2018 at 10:07 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 28/06/2018 13:48, Vidushi Vashishth wrote:
> > Sorry for the delay. I had been trying to make the code run.
> Run on what? RTEMS?
> > https://github.com/VidushiVashishth/babeltrace/tree/master/Demo
> > This is a demonstration of the how to use babeltrace to convert rtems
> traces. I
> > have integrated the program.c code in the rtems main_rtrace.c file. This
> is
> > throwing some errors that I am working on.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180628/afaffcde/attachment-0001.html>
