[PATCH v3] tester: Add script to generate html coverage report from covoar output
Wed Jun 6 12:18:38 UTC 2018
On Wed, Jun 6, 2018, 1:16 AM Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> On Wed, 6 Jun 2018, 01:52 Joel Sherrill, <joel at rtems.org> wrote:
>> On Tue, Jun 5, 2018, 7:22 PM Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 6 June 2018 at 03:57, Joel Sherrill <joel at rtems.org> wrote:
>>>> I think everything is pushed. Is there any patch outstanding?
>>>> Thank you.
>>> No outstanding patch, everything on my side is squashed into it. :)
>> So we can (finally) switch to the RTEMS.org repos to as the baseline?
> That's everything! Started summer 2014 and now it's all merged, it's great
> to see. Well done Vijay.
Agreed! Now to finish this GSoC's goals and define the near term things to
work on.
>> On Mon, Jun 4, 2018 at 3:44 PM, Vijay Kumar Banerjee <
>>>>> Add support in tester to run covoar and generate an html report to
>>>>> display
>>>>> the summary of the coverage reports generated from covoar.
>>>>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>  .gitignore                                    |   1 +
>>>>>  tester/rt/coverage.py                         | 385
>>>>>  tester/rt/test.py                             |  34 ++-
>>>>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>>  6 files changed, 450 insertions(+), 13 deletions(-)
>>>>>  create mode 100644 tester/rt/coverage.py
>>>>>  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>>>> diff --git a/.gitignore b/.gitignore
>>>>> index 6ab3709..93cb5d2 100644
>>>>> --- a/.gitignore
>>>>> +++ b/.gitignore
>>>>> @@ -9,3 +9,4 @@ waf3-*
>>>>>  .lock-waf*
>>>>>  build
>>>>>  VERSION*
>>>>> +*symbols.ini
>>>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>> new file mode 100644
>>>>> index 0000000..54933d5
>>>>> --- /dev/null
>>>>> +++ b/tester/rt/coverage.py
>>>>> @@ -0,0 +1,385 @@
>>>>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>>>>> +# All rights reserved.
>>>>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>> +# Redistribution and use in source and binary forms, with or without
>>>>> +# modification, are permitted provided that the following conditions
>>>>> are met:
>>>>> +# 1. Redistributions of source code must retain the above copyright
>>>>> notice,
>>>>> +# this list of conditions and the following disclaimer.
>>>>> +# 2. Redistributions in binary form must reproduce the above
>>>>> copyright notice,
>>>>> +# this list of conditions and the following disclaimer in the
>>>>> documentation
>>>>> +# and/or other materials provided with the distribution.
>>>>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>>> 'AS IS'
>>>>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>> TO, THE
>>>>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>>> PURPOSE
>>>>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>> CONTRIBUTORS BE
>>>>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>> BUSINESS
>>>>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>> WHETHER IN
>>>>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>> OTHERWISE)
>>>>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>>>> OF THE
>>>>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>> +from rtemstoolkit import error
>>>>> +from rtemstoolkit import path
>>>>> +from rtemstoolkit import log
>>>>> +from rtemstoolkit import execute
>>>>> +from rtemstoolkit import macros
>>>>> +from datetime import datetime
>>>>> +from . import options
>>>>> +import shutil
>>>>> +import os
>>>>> +try:
>>>>> +    import configparser
>>>>> +except:
>>>>> +    import ConfigParser as configparser
>>>>> +class summary:
>>>>> +    def __init__(self, p_summary_dir):
>>>>> +        self.summary_file_path = path.join(p_summary_dir,
>>>>> 'summary.txt')
>>>>> +        self.index_file_path = path.join(p_summary_dir, 'index.html')
>>>>> +        self.bytes_analyzed = 0
>>>>> +        self.bytes_not_executed = 0
>>>>> +        self.percentage_executed = 0.0
>>>>> +        self.percentage_not_executed = 100.0
>>>>> +        self.ranges_uncovered = 0
>>>>> +        self.branches_uncovered = 0
>>>>> +        self.branches_total = 0
>>>>> +        self.branches_always_taken = 0
>>>>> +        self.branches_never_taken = 0
>>>>> +        self.percentage_branches_covered = 0.0
>>>>> +        self.is_failure = False
>>>>> +    def parse(self):
>>>>> +        if(not path.exists(self.summary_file_path)):
>>>>> +            log.notice('summary file %s does not exist!' %
>>>>> +            self.is_failure = True
>>>>> +            return
>>>>> +        with open(self.summary_file_path,'r') as summary_file:
>>>>> self._get_next_with_colon(summary_file)
>>>>> self._get_next_without_colon(summary_file)
>>>>> +        if len(self.branches_uncovered) > 0 and
>>>>> len(self.branches_total) > 0:
>>>>> +            self.percentage_branches_covered = \
>>>>> +            1 - (float(self.branches_uncovered) /
>>>>> float(self.branches_total))
>>>>> +        else:
>>>>> +        return
>>>>> +    def _get_next_with_colon(self, summary_file):
>>>>> +        line = summary_file.readline()
>>>>> +        if ':' in line:
>>>>> +            return line.split(':')[1].strip()
>>>>> +        else:
>>>>> +            return ''
>>>>> +    def _get_next_without_colon(self, summary_file):
>>>>> +        return line.strip().split(' ')[0]
>>>>> +class report_gen_html:
>>>>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
>>>>> +        self.symbol_sets_list = ['score']
>>>>> +        self.build_dir = build_dir
>>>>> +        self.partial_reports_files = list(["index.html",
>>>>> "summary.txt"])
>>>>> +        self.number_of_columns = 1
>>>>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>> +        self.bsp = bsp
>>>>> +    def _find_partial_reports(self):
>>>>> +        partial_reports = {}
>>>>> +        for symbol_set in self.symbol_sets_list:
>>>>> +            set_summary = summary(path.join(self.build_dir,
>>>>> +                                  self.bsp + "-coverage",
>>>>> +                                  symbol_set))
>>>>> +            set_summary.parse()
>>>>> +            partial_reports[symbol_set] = set_summary
>>>>> +        return partial_reports
>>>>> +    def _prepare_head_section(self):
>>>>> +        head_section = '''
>>>>> +        <head>
>>>>> +        <title>RTEMS coverage report</title>
>>>>> +        <style type="text/css">
>>>>> +            progress[value] {
>>>>> +              -webkit-appearance: none;
>>>>> +               appearance: none;
>>>>> +              width: 150px;
>>>>> +              height: 15px;
>>>>> +        </style>
>>>>> +        </head>'''
>>>>> +        return head_section
>>>>> +    def _prepare_index_content(self, partial_reports):
>>>>> +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>> +        table = "<table>"
>>>>> +        table += self._header_row()
>>>>> +        for symbol_set in partial_reports:
>>>>> +            table += self._row(symbol_set,
>>>>> partial_reports[symbol_set])
>>>>> +        table += "</table> </br>"
>>>>> +        timestamp = "Analysis performed on " + datetime.now().ctime()
>>>>> +        return "<body>\n" + header + table + timestamp + "\n</body>"
>>>>> +    def _row(self, symbol_set, summary):
>>>>> +        row = "<tr>"
>>>>> +        row += "<td>" + symbol_set + "</td>"
>>>>> +        if summary.is_failure:
>>>>> +            row += ' <td colspan="' + str(self.number_of_columns-1) \
>>>>> +            + '" style="background-color:red">FAILURE</td>'
>>>>> +        else:
>>>>> +            row += " <td>" +
>>>>> self._link(summary.index_file_path,"Index") \
>>>>> +            + "</td>"
>>>>> +            row += " <td>" +
>>>>> self._link(summary.summary_file_path,"Summary") \
>>>>> +            + "</td>"
>>>>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>> +            row += " <td>" + summary.bytes_not_executed + "</td>"
>>>>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
>>>>> +            row += " <td>" + summary.percentage_executed + "%</td>"
>>>>> +            row += " <td>" + summary.percentage_not_executed +
>>>>> "%</td>"
>>>>> +            row += ' <td><progress value="' +
>>>>> summary.percentage_executed \
>>>>> +            + '" max="100"></progress></td>'
>>>>> +            row += " <td>" + summary.branches_uncovered + "</td>"
>>>>> +            row += " <td>" + summary.branches_total + "</td>"
>>>>> +            row += " <td> {:.3%}
>>>>> </td>".format(summary.percentage_branches_covered)
>>>>> +            row += ' <td><progress value="{:.3}"
>>>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>>> +            row += "</tr>\n"
>>>>> +        return row
>>>>> +    def _header_row(self):
>>>>> +        row = "<tr>"
>>>>> +        row += "<th> Symbols set name </th>"
>>>>> +        row += "<th> Index file </th>"
>>>>> +        row += "<th> Summary file </th>"
>>>>> +        row += "<th> Bytes analyzed </th>"
>>>>> +        row += "<th> Bytes not executed </th>"
>>>>> +        row += "<th> Uncovered ranges </th>"
>>>>> +        row += "<th> Percentage covered </th>"
>>>>> +        row += "<th> Percentage uncovered </th>"
>>>>> +        row += "<th> Instruction coverage </th>"
>>>>> +        row += "<th> Branches uncovered </th>"
>>>>> +        row += "<th> Branches total </th>"
>>>>> +        row += "<th> Branches covered percentage </th>"
>>>>> +        row += "<th> Branches coverage </th>"
>>>>> +        row += "</tr>\n"
>>>>> +        self.number_of_columns = row.count('<th>')
>>>>> +        return row
>>>>> +    def _link(self, address, text):
>>>>> +        return '<a href="' + address + '">' + text + '</a>'
>>>>> +    def _create_index_file(self, head_section, content):
>>>>> +        with open(path.join(self.build_dir,
>>>>> +                            self.bsp + "-report.html"),'w') as f:
>>>>> +            f.write(head_section)
>>>>> +            f.write(content)
>>>>> +    def generate(self):
>>>>> +        partial_reports = self._find_partial_reports()
>>>>> +        head_section = self._prepare_head_section()
>>>>> +        index_content = self._prepare_index_content(partial_reports)
>>>>> +        self._create_index_file(head_section,index_content)
>>>>> +    def add_covoar_src_path(self):
>>>>> +        table_js_path = path.join(self.covoar_src_path, 'table.js')
>>>>> +        covoar_css_path = path.join(self.covoar_src_path,
>>>>> 'covoar.css')
>>>>> +            symbol_set_dir = path.join(self.build_dir,
>>>>> +                                       self.bsp + '-coverage',
>>>>> symbol_set)
>>>>> +            html_files = os.listdir(symbol_set_dir)
>>>>> +            for html_file in html_files:
>>>>> +                html_file = path.join(symbol_set_dir, html_file)
>>>>> +                if path.exists(html_file) and 'html' in html_file:
>>>>> +                    with open(html_file, 'r') as f:
>>>>> +                        file_data = f.read()
>>>>> +                    file_data = file_data.replace('table.js',
>>>>> table_js_path)
>>>>> +                    file_data = file_data.replace('covoar.css',
>>>>> +                                                  covoar_css_path)
>>>>> +                    with open(html_file, 'w') as f:
>>>>> +                        f.write(file_data)
>>>>> +class build_path_generator(object):
>>>>> +    Generates the build path from the path to executables
>>>>> +    def __init__(self, executables, target):
>>>>> +        self.executables = executables
>>>>> +        self.target = target
>>>>> +    def run(self):
>>>>> +        build_path = '/'
>>>>> +        Path = self.executables[0].split('/')
>>>>> +        for P in Path:
>>>>> +            if P == self.target:
>>>>> +                break;
>>>>> +            else:
>>>>> +                build_path = path.join(build_path, P)
>>>>> +        return build_path
>>>>> +class symbol_parser(object):
>>>>> +    Parse the symbol sets ini and create custom ini file for covoar
>>>>> +    def __init__(self, symbol_config_path,
>>>>> +                 symbol_select_path, coverage_arg, build_dir):
>>>>> +        self.symbol_select_file = symbol_select_path
>>>>> +        self.symbol_file = symbol_config_path
>>>>> +        self.symbol_sets = {}
>>>>> +        self.cov_arg = coverage_arg
>>>>> +        self.ssets = []
>>>>> +    def parse(self):
>>>>> +        config = configparser.ConfigParser()
>>>>> +        try:
>>>>> +            config.read(self.symbol_file)
>>>>> +            if self.cov_arg:
>>>>> +                self.ssets = self.cov_arg.split(',')
>>>>> +            else:
>>>>> +                self.ssets = config.get('symbol-sets',
>>>>> 'sets').split(',')
>>>>> +                self.ssets = [ sset.encode('utf-8') for sset in
>>>>> self.ssets]
>>>>> +            for sset in self.ssets:
>>>>> +                lib = path.join(self.build_dir,
>>>>> +                                config.get('libraries', sset))
>>>>> +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>>> +        except:
>>>>> +            raise error.general('Symbol set parsing failed')
>>>>> +    def _write_ini(self):
>>>>> +        try:
>>>>> +            sets = ', '.join(self.symbol_sets.keys())
>>>>> +            config.add_section('symbol-sets')
>>>>> +            config.set('symbol-sets', 'sets', sets)
>>>>> +            for key in self.symbol_sets.keys():
>>>>> +                config.add_section(key)
>>>>> +                config.set(key, 'libraries', self.symbol_sets[key])
>>>>> +            with open(self.symbol_select_file, 'w') as conf:
>>>>> +                config.write(conf)
>>>>> +        except:
>>>>> +            raise error.general('write failed')
>>>>> +    def run(self):
>>>>> +        self.parse()
>>>>> +        self._write_ini()
>>>>> +class covoar(object):
>>>>> +    Covoar runner
>>>>> +    def __init__(self, base_result_dir, config_dir, executables,
>>>>> explanations_txt):
>>>>> +        self.base_result_dir = base_result_dir
>>>>> +        self.config_dir = config_dir
>>>>> +        self.executables = ' '.join(executables)
>>>>> +        self.explanations_txt = explanations_txt
>>>>> +        self.project_name = 'RTEMS-5'
>>>>> +    def run(self, set_name, symbol_file):
>>>>> +        covoar_result_dir = path.join(self.base_result_dir, set_name)
>>>>> +        if (not path.exists(covoar_result_dir)):
>>>>> +            path.mkdir(covoar_result_dir)
>>>>> +        if (not path.exists(symbol_file)):
>>>>> +            raise error.general('symbol set file: coverage %s was not
>>>>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>> +        command = ('covoar -S ' + symbol_file
>>>>> +                  + ' -O ' + covoar_result_dir
>>>>> +                  + ' -E ' + self.explanations_txt
>>>>> +                  + ' -p ' + self.project_name + ' ' +
>>>>> self.executables)
>>>>> +        log.notice('Running covoar for %s' % (set_name))
>>>>> +        print( 'covoar results directory:\n' + covoar_result_dir )
>>>>> +        executor = execute.execute(verbose = True, output =
>>>>> self.output_handler)
>>>>> +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>>> +        if (exit_code[0] != 0):
>>>>> +            raise error.general('covoar failure exit code: %d' %
>>>>> (exit_code[0]))
>>>>> +        log.notice('Coverage run for %s finished successfully.' %
>>>>> (set_name))
>>>>> +        log.notice('-----------------------------------------------')
>>>>> +    def output_handler(self, text):
>>>>> +        log.notice('%s' % (text))
>>>>> +class coverage_run(object):
>>>>> +    Coverage analysis support for rtems-test
>>>>> +    def __init__(self, p_macros, coverage_arg, executables):
>>>>> +        Constructor
>>>>> +        self.macros = p_macros
>>>>> +        self.build_dir = self.macros['_cwd']
>>>>> self.macros.expand(self.macros['cov_explanations'])
>>>>> +        self.test_dir = path.join(self.build_dir, self.macros['bsp']
>>>>> + '-coverage')
>>>>> +        if (not path.exists(self.test_dir)):
>>>>> +            path.mkdir(self.test_dir)
>>>>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>> +        self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
>>>>> +        self.coverage_config_path = path.join(self.rtscripts,
>>>>> 'coverage')
>>>>> +        self.symbol_config_path = path.join(self.coverage_config_path,
>>>>> +                                            'symbol-sets.ini')
>>>>> +        self.symbol_select_path = path.join(self.coverage_config_path,
>>>>> +                                            self.macros['bsp'] +
>>>>> '-symbols.ini')
>>>>> +        self.symbol_sets = []
>>>>> +        self.no_clean = int(self.macros['_no_clean'])
>>>>> +        self.report_format = self.macros['cov_report_format']
>>>>> +        self.coverage_arg = coverage_arg
>>>>> +        self.target = self.macros['target']
>>>>> +    def run(self):
>>>>> +        try:
>>>>> +            if self.executables is None:
>>>>> +                raise error.general('no test executables provided.')
>>>>> +            build_dir = build_path_generator(self.executables,
>>>>> self.target).run()
>>>>> +            parser = symbol_parser(self.symbol_config_path,
>>>>> +                                   self.symbol_select_path,
>>>>> +                                   self.coverage_arg,
>>>>> +                                   build_dir)
>>>>> +            parser.run()
>>>>> +            covoar_runner = covoar(self.test_dir,
>>>>> +                                   self.executables,
>>>>> self.explanations_txt)
>>>>> +            covoar_runner.run('score', self.symbol_select_path)
>>>>> +            self._generate_reports();
>>>>> +            self._summarize();
>>>>> +        finally:
>>>>> +            self._cleanup();
>>>>> +    def _generate_reports(self):
>>>>> +        log.notice('Generating reports')
>>>>> +        if self.report_format == 'html':
>>>>> +            report = report_gen_html(self.symbol_sets,
>>>>> +                                     self.build_dir,
>>>>> +                                     self.rtdir,
>>>>> +                                     self.macros['bsp'])
>>>>> +            report.generate()
>>>>> +            report.add_covoar_src_path()
>>>>> +    def _cleanup(self):
>>>>> +        if not self.no_clean:
>>>>> +            log.notice('***Cleaning tempfiles***')
>>>>> +            for exe in self.executables:
>>>>> +                trace_file = exe + '.cov'
>>>>> +                if path.exists(trace_file):
>>>>> +                    os.remove(trace_file)
>>>>> +            os.remove(self.symbol_select_path)
>>>>> +    def _summarize(self):
>>>>> +        log.notice('Coverage analysis finished. You can find results
>>>>> in %s' % (self.build_dir))
>>>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>> index f4d9b5c..0e744cd 100644
>>>>> --- a/tester/rt/test.py
>>>>> +++ b/tester/rt/test.py
>>>>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>  from rtemstoolkit import reraise
>>>>>  from rtemstoolkit import stacktraces
>>>>>  from rtemstoolkit import version
>>>>> +from rtemstoolkit import check
>>>>>  from . import bsps
>>>>>  from . import config
>>>>>  from . import console
>>>>>  from . import report
>>>>> +from . import coverage
>>>>>  class log_capture(object):
>>>>>      def __init__(self):
>>>>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>      def run(self):
>>>>>          self.thread = threading.Thread(target = self.runner,
>>>>> -                                       name = 'test[%s]' %
>>>>> path.basename(self.executable))
>>>>> +                            name = 'test[%s]' %
>>>>>          self.thread.start()
>>>>>      def is_alive(self):
>>>>> @@ -221,15 +223,16 @@ def run(command_path = None):
>>>>>      opts = None
>>>>>      default_exefilter = '*.exe'
>>>>>      try:
>>>>> -        optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>>>> -                    '--rtems-bsp':   'The RTEMS BSP to run the test
>>>>> on',
>>>>> -                    '--user-config': 'Path to your local user
>>>>> configuration INI file',
>>>>> -                    '--report-mode': 'Reporting modes, failures
>>>>> (default),all,none',
>>>>> -                    '--list-bsps':   'List the supported BSPs',
>>>>> -                    '--debug-trace': 'Debug trace based on specific
>>>>> flags',
>>>>> -                    '--filter':      'Glob that executables must
>>>>> match to run (default: ' +
>>>>> +        optargs = { '--rtems-tools':    'The path to the RTEMS tools',
>>>>> +                    '--rtems-bsp':      'The RTEMS BSP to run the
>>>>> test on',
>>>>> +                    '--user-config':    'Path to your local user
>>>>> +                    '--report-mode':    'Reporting modes, failures
>>>>> +                    '--list-bsps':      'List the supported BSPs',
>>>>> +                    '--debug-trace':    'Debug trace based on
>>>>> specific flags',
>>>>> +                    '--filter':         'Glob that executables must
>>>>>                                default_exefilter + ')',
>>>>> -                    '--stacktrace':  'Dump a stack trace on a user
>>>>> termination (^C)' }
>>>>> +                    '--stacktrace':     'Dump a stack trace on a user
>>>>> termination (^C)',
>>>>> +                    '--coverage':       'Perform coverage analysis of
>>>>> test executables.'}
>>>>>          mailer.append_options(optargs)
>>>>>          opts = options.load(sys.argv,
>>>>>                              optargs = optargs,
>>>>> @@ -257,6 +260,7 @@ def run(command_path = None):
>>>>>              exe_filter = default_exefilter
>>>>>          opts.log_info()
>>>>>          log.output('Host: ' + host.label(mode = 'all'))
>>>>> +        executables = find_executables(opts.params(), exe_filter)
>>>>>          debug_trace = opts.find_arg('--debug-trace')
>>>>>          if debug_trace:
>>>>>              if len(debug_trace) != 1:
>>>>> @@ -279,6 +283,15 @@ def run(command_path = None):
>>>>>              raise error.general('RTEMS BSP not provided or an invalid
>>>>> option')
>>>>>          bsp = config.load(bsp[1], opts)
>>>>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>>> +        coverage_enabled = opts.find_arg('--coverage')
>>>>> +        if coverage_enabled:
>>>>> +            if len(coverage_enabled) == 2:
>>>>> +                coverage_runner = coverage.coverage_run(opts.defaults,
>>>>> +                                                coverage_enabled[1],
>>>>> +                                                executables)
>>>>> +            else:
>>>>> +                coverage_runner =
>>>>> coverage.coverage_run(opts.defaults, 0,
>>>>> +                                                        executables)
>>>>>          report_mode = opts.find_arg('--report-mode')
>>>>>          if report_mode:
>>>>>              if report_mode[1] != 'failures' and \
>>>>> @@ -288,7 +301,6 @@ def run(command_path = None):
>>>>>              report_mode = report_mode[1]
>>>>>          else:
>>>>>              report_mode = 'failures'
>>>>> -        executables = find_executables(opts.params(), exe_filter)
>>>>>          if len(executables) == 0:
>>>>>              raise error.general('no executables supplied')
>>>>>          start_time = datetime.datetime.now()
>>>>> @@ -365,6 +377,8 @@ def run(command_path = None):
>>>>>                      reports.failures(),
>>>>>                      'Log', '===', ''] + output.get()
>>>>>              mail.send(to_addr, subject, os.linesep.join(body))
>>>>> +            coverage_runner.run()
>>>>>      except error.general as gerr:
>>>>>          print(gerr)
>>>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> index 6b5e7e6..2f89117 100644
>>>>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> @@ -31,9 +31,10 @@
>>>>>  # The Leon 3 QEMU BSP
>>>>> -[leon3-qemu]
>>>>> +[leon3-qemu-cov]
>>>>>  bsp               = leon3-qemu
>>>>>  arch              = sparc
>>>>> +target            = sparc-rtems5
>>>>>  tester            = %{_rtscripts}/qemu.cfg
>>>>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> index 0000000..a2ec7bc
>>>>> --- /dev/null
>>>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> @@ -0,0 +1,36 @@
>>>>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>> are met:
>>>>> notice,
>>>>> copyright notice,
>>>>> documentation
>>>>> "AS IS"
>>>>> TO, THE
>>>>> PURPOSE
>>>>> CONTRIBUTORS BE
>>>>> BUSINESS
>>>>> WHETHER IN
>>>>> OTHERWISE)
>>>>> OF THE
>>>>> +[symbol-sets]
>>>>> +sets = score,rtems
>>>>> +[libraries]
>>>>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>>>> qemu.cfg
>>>>> index bfcd2f5..52a3752 100644
>>>>> --- a/tester/rtems/testing/qemu.cfg
>>>>> +++ b/tester/rtems/testing/qemu.cfg
>>>>> @@ -51,8 +51,8 @@
>>>>>  # Qemu common option patterns.
>>>>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>> -nographic
>>>>> -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>> -nographic
>>>>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>> -nographic
>>>>> +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>> -nographic
>>>>>  %define qemu_opts_no_net -net none
>>>>> 2.14.3
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180606/efdbcda8/attachment-0002.html>
