[PATCH v3] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Jun 6 12:25:16 UTC 2018
On 6 June 2018 at 17:48, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jun 6, 2018, 1:16 AM Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On Wed, 6 Jun 2018, 01:52 Joel Sherrill, <joel at rtems.org> wrote:
>>> On Tue, Jun 5, 2018, 7:22 PM Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 6 June 2018 at 03:57, Joel Sherrill <joel at rtems.org> wrote:
>>>>> I think everything is pushed. Is there any patch outstanding?
>>>>> Thank you.
>>>> No outstanding patch, everything on my side is squashed into it. :)
>>> So we can (finally) switch to the RTEMS.org repos to as the baseline?
>> That's everything! Started summer 2014 and now it's all merged, it's
>> great to see. Well done Vijay.
> Thank you! Thanks to all the mentors for all the support and guidance. :)
> Agreed! Now to finish this GSoC's goals and define the near term things to
> work on.
> I have started filing the tickets.
P.S: It's great to be a part of such a wonderful community. :)
>>> On Mon, Jun 4, 2018 at 3:44 PM, Vijay Kumar Banerjee <
>>>>>> Add support in tester to run covoar and generate an html report to
>>>>>> display
>>>>>> the summary of the coverage reports generated from covoar.
>>>>>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>  .gitignore                                    |   1 +
>>>>>>  tester/rt/coverage.py                         | 385
>>>>>>  tester/rt/test.py                             |  34 ++-
>>>>>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>>>  6 files changed, 450 insertions(+), 13 deletions(-)
>>>>>>  create mode 100644 tester/rt/coverage.py
>>>>>>  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> diff --git a/.gitignore b/.gitignore
>>>>>> index 6ab3709..93cb5d2 100644
>>>>>> --- a/.gitignore
>>>>>> +++ b/.gitignore
>>>>>> @@ -9,3 +9,4 @@ waf3-*
>>>>>>  .lock-waf*
>>>>>>  build
>>>>>>  VERSION*
>>>>>> +*symbols.ini
>>>>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>> new file mode 100644
>>>>>> index 0000000..54933d5
>>>>>> --- /dev/null
>>>>>> +++ b/tester/rt/coverage.py
>>>>>> @@ -0,0 +1,385 @@
>>>>>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>>>>>> +# All rights reserved.
>>>>>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>> +# Redistribution and use in source and binary forms, with or without
>>>>>> +# modification, are permitted provided that the following conditions
>>>>>> are met:
>>>>>> +# 1. Redistributions of source code must retain the above copyright
>>>>>> notice,
>>>>>> +# this list of conditions and the following disclaimer.
>>>>>> +# 2. Redistributions in binary form must reproduce the above
>>>>>> copyright notice,
>>>>>> +# this list of conditions and the following disclaimer in the
>>>>>> documentation
>>>>>> +# and/or other materials provided with the distribution.
>>>>>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>> CONTRIBUTORS 'AS IS'
>>>>>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>>> TO, THE
>>>>>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>>>> PURPOSE
>>>>>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>> CONTRIBUTORS BE
>>>>>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>>> OF
>>>>>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>> BUSINESS
>>>>>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>> WHETHER IN
>>>>>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>> OTHERWISE)
>>>>>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>> ADVISED OF THE
>>>>>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>> +from rtemstoolkit import error
>>>>>> +from rtemstoolkit import path
>>>>>> +from rtemstoolkit import log
>>>>>> +from rtemstoolkit import execute
>>>>>> +from rtemstoolkit import macros
>>>>>> +from datetime import datetime
>>>>>> +from . import options
>>>>>> +import shutil
>>>>>> +import os
>>>>>> +try:
>>>>>> +    import configparser
>>>>>> +except:
>>>>>> +    import ConfigParser as configparser
>>>>>> +class summary:
>>>>>> +    def __init__(self, p_summary_dir):
>>>>>> +        self.summary_file_path = path.join(p_summary_dir,
>>>>>> 'summary.txt')
>>>>>> +        self.index_file_path = path.join(p_summary_dir, 'index.html')
>>>>>> +        self.bytes_analyzed = 0
>>>>>> +        self.bytes_not_executed = 0
>>>>>> +        self.percentage_executed = 0.0
>>>>>> +        self.percentage_not_executed = 100.0
>>>>>> +        self.ranges_uncovered = 0
>>>>>> +        self.branches_uncovered = 0
>>>>>> +        self.branches_total = 0
>>>>>> +        self.branches_always_taken = 0
>>>>>> +        self.branches_never_taken = 0
>>>>>> +        self.percentage_branches_covered = 0.0
>>>>>> +        self.is_failure = False
>>>>>> +    def parse(self):
>>>>>> +        if(not path.exists(self.summary_file_path)):
>>>>>> +            log.notice('summary file %s does not exist!' %
>>>>>> +            self.is_failure = True
>>>>>> +            return
>>>>>> +        with open(self.summary_file_path,'r') as summary_file:
>>>>>> +           self.bytes_analyzed = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.bytes_not_executed = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.percentage_executed = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.percentage_not_executed = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.ranges_uncovered = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.branches_total = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.branches_uncovered = self._get_next_with_colon(
>>>>>> summary_file)
>>>>>> +           self.branches_always_taken = self._get_next_without_colon(
>>>>>> summary_file)
>>>>>> +           self.branches_never_taken = self._get_next_without_colon(
>>>>>> summary_file)
>>>>>> +        if len(self.branches_uncovered) > 0 and
>>>>>> len(self.branches_total) > 0:
>>>>>> +            self.percentage_branches_covered = \
>>>>>> +            1 - (float(self.branches_uncovered) /
>>>>>> float(self.branches_total))
>>>>>> +        else:
>>>>>> +        return
>>>>>> +    def _get_next_with_colon(self, summary_file):
>>>>>> +        line = summary_file.readline()
>>>>>> +        if ':' in line:
>>>>>> +            return line.split(':')[1].strip()
>>>>>> +        else:
>>>>>> +            return ''
>>>>>> +    def _get_next_without_colon(self, summary_file):
>>>>>> +        return line.strip().split(' ')[0]
>>>>>> +class report_gen_html:
>>>>>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir, bsp):
>>>>>> +        self.symbol_sets_list = ['score']
>>>>>> +        self.build_dir = build_dir
>>>>>> +        self.partial_reports_files = list(["index.html",
>>>>>> "summary.txt"])
>>>>>> +        self.number_of_columns = 1
>>>>>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>> +        self.bsp = bsp
>>>>>> +    def _find_partial_reports(self):
>>>>>> +        partial_reports = {}
>>>>>> +        for symbol_set in self.symbol_sets_list:
>>>>>> +            set_summary = summary(path.join(self.build_dir,
>>>>>> +                                  self.bsp + "-coverage",
>>>>>> +                                  symbol_set))
>>>>>> +            set_summary.parse()
>>>>>> +            partial_reports[symbol_set] = set_summary
>>>>>> +        return partial_reports
>>>>>> +    def _prepare_head_section(self):
>>>>>> +        head_section = '''
>>>>>> +        <head>
>>>>>> +        <title>RTEMS coverage report</title>
>>>>>> +        <style type="text/css">
>>>>>> +            progress[value] {
>>>>>> +              -webkit-appearance: none;
>>>>>> +               appearance: none;
>>>>>> +              width: 150px;
>>>>>> +              height: 15px;
>>>>>> +        </style>
>>>>>> +        </head>'''
>>>>>> +        return head_section
>>>>>> +    def _prepare_index_content(self, partial_reports):
>>>>>> +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>>>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>>> +        table = "<table>"
>>>>>> +        table += self._header_row()
>>>>>> +        for symbol_set in partial_reports:
>>>>>> +            table += self._row(symbol_set,
>>>>>> partial_reports[symbol_set])
>>>>>> +        table += "</table> </br>"
>>>>>> +        timestamp = "Analysis performed on " + datetime.now().ctime()
>>>>>> +        return "<body>\n" + header + table + timestamp + "\n</body>"
>>>>>> +    def _row(self, symbol_set, summary):
>>>>>> +        row = "<tr>"
>>>>>> +        row += "<td>" + symbol_set + "</td>"
>>>>>> +        if summary.is_failure:
>>>>>> +            row += ' <td colspan="' + str(self.number_of_columns-1) \
>>>>>> +            + '" style="background-color:red">FAILURE</td>'
>>>>>> +        else:
>>>>>> +            row += " <td>" + self._link(summary.index_file_path,"Index")
>>>>>> +            + "</td>"
>>>>>> +            row += " <td>" + self._link(summary.summary_file_path,"Summary")
>>>>>> +            + "</td>"
>>>>>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>>> +            row += " <td>" + summary.bytes_not_executed + "</td>"
>>>>>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
>>>>>> +            row += " <td>" + summary.percentage_executed + "%</td>"
>>>>>> +            row += " <td>" + summary.percentage_not_executed +
>>>>>> "%</td>"
>>>>>> +            row += ' <td><progress value="' +
>>>>>> summary.percentage_executed \
>>>>>> +            + '" max="100"></progress></td>'
>>>>>> +            row += " <td>" + summary.branches_uncovered + "</td>"
>>>>>> +            row += " <td>" + summary.branches_total + "</td>"
>>>>>> +            row += " <td> {:.3%} </td>".format(summary.
>>>>>> percentage_branches_covered)
>>>>>> +            row += ' <td><progress value="{:.3}"
>>>>>> max="100"></progress></td>'.format(100*summary.percentage_
>>>>>> branches_covered)
>>>>>> +            row += "</tr>\n"
>>>>>> +        return row
>>>>>> +    def _header_row(self):
>>>>>> +        row = "<tr>"
>>>>>> +        row += "<th> Symbols set name </th>"
>>>>>> +        row += "<th> Index file </th>"
>>>>>> +        row += "<th> Summary file </th>"
>>>>>> +        row += "<th> Bytes analyzed </th>"
>>>>>> +        row += "<th> Bytes not executed </th>"
>>>>>> +        row += "<th> Uncovered ranges </th>"
>>>>>> +        row += "<th> Percentage covered </th>"
>>>>>> +        row += "<th> Percentage uncovered </th>"
>>>>>> +        row += "<th> Instruction coverage </th>"
>>>>>> +        row += "<th> Branches uncovered </th>"
>>>>>> +        row += "<th> Branches total </th>"
>>>>>> +        row += "<th> Branches covered percentage </th>"
>>>>>> +        row += "<th> Branches coverage </th>"
>>>>>> +        row += "</tr>\n"
>>>>>> +        self.number_of_columns = row.count('<th>')
>>>>>> +        return row
>>>>>> +    def _link(self, address, text):
>>>>>> +        return '<a href="' + address + '">' + text + '</a>'
>>>>>> +    def _create_index_file(self, head_section, content):
>>>>>> +        with open(path.join(self.build_dir,
>>>>>> +                            self.bsp + "-report.html"),'w') as f:
>>>>>> +            f.write(head_section)
>>>>>> +            f.write(content)
>>>>>> +    def generate(self):
>>>>>> +        partial_reports = self._find_partial_reports()
>>>>>> +        head_section = self._prepare_head_section()
>>>>>> +        index_content = self._prepare_index_content(partial_reports)
>>>>>> +        self._create_index_file(head_section,index_content)
>>>>>> +    def add_covoar_src_path(self):
>>>>>> +        table_js_path = path.join(self.covoar_src_path, 'table.js')
>>>>>> +        covoar_css_path = path.join(self.covoar_src_path,
>>>>>> 'covoar.css')
>>>>>> +            symbol_set_dir = path.join(self.build_dir,
>>>>>> +                                       self.bsp + '-coverage',
>>>>>> symbol_set)
>>>>>> +            html_files = os.listdir(symbol_set_dir)
>>>>>> +            for html_file in html_files:
>>>>>> +                html_file = path.join(symbol_set_dir, html_file)
>>>>>> +                if path.exists(html_file) and 'html' in html_file:
>>>>>> +                    with open(html_file, 'r') as f:
>>>>>> +                        file_data = f.read()
>>>>>> +                    file_data = file_data.replace('table.js',
>>>>>> table_js_path)
>>>>>> +                    file_data = file_data.replace('covoar.css',
>>>>>> +                                                  covoar_css_path)
>>>>>> +                    with open(html_file, 'w') as f:
>>>>>> +                        f.write(file_data)
>>>>>> +class build_path_generator(object):
>>>>>> +    Generates the build path from the path to executables
>>>>>> +    def __init__(self, executables, target):
>>>>>> +        self.executables = executables
>>>>>> +        self.target = target
>>>>>> +    def run(self):
>>>>>> +        build_path = '/'
>>>>>> +        Path = self.executables[0].split('/')
>>>>>> +        for P in Path:
>>>>>> +            if P == self.target:
>>>>>> +                break;
>>>>>> +            else:
>>>>>> +                build_path = path.join(build_path, P)
>>>>>> +        return build_path
>>>>>> +class symbol_parser(object):
>>>>>> +    Parse the symbol sets ini and create custom ini file for covoar
>>>>>> +    def __init__(self, symbol_config_path,
>>>>>> +                 symbol_select_path, coverage_arg, build_dir):
>>>>>> +        self.symbol_select_file = symbol_select_path
>>>>>> +        self.symbol_file = symbol_config_path
>>>>>> +        self.symbol_sets = {}
>>>>>> +        self.cov_arg = coverage_arg
>>>>>> +        self.ssets = []
>>>>>> +    def parse(self):
>>>>>> +        config = configparser.ConfigParser()
>>>>>> +        try:
>>>>>> +            config.read(self.symbol_file)
>>>>>> +            if self.cov_arg:
>>>>>> +                self.ssets = self.cov_arg.split(',')
>>>>>> +            else:
>>>>>> +                self.ssets = config.get('symbol-sets',
>>>>>> 'sets').split(',')
>>>>>> +                self.ssets = [ sset.encode('utf-8') for sset in
>>>>>> self.ssets]
>>>>>> +            for sset in self.ssets:
>>>>>> +                lib = path.join(self.build_dir,
>>>>>> +                                config.get('libraries', sset))
>>>>>> +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>>>> +        except:
>>>>>> +            raise error.general('Symbol set parsing failed')
>>>>>> +    def _write_ini(self):
>>>>>> +        try:
>>>>>> +            sets = ', '.join(self.symbol_sets.keys())
>>>>>> +            config.add_section('symbol-sets')
>>>>>> +            config.set('symbol-sets', 'sets', sets)
>>>>>> +            for key in self.symbol_sets.keys():
>>>>>> +                config.add_section(key)
>>>>>> +                config.set(key, 'libraries', self.symbol_sets[key])
>>>>>> +            with open(self.symbol_select_file, 'w') as conf:
>>>>>> +                config.write(conf)
>>>>>> +        except:
>>>>>> +            raise error.general('write failed')
>>>>>> +    def run(self):
>>>>>> +        self.parse()
>>>>>> +        self._write_ini()
>>>>>> +class covoar(object):
>>>>>> +    Covoar runner
>>>>>> +    def __init__(self, base_result_dir, config_dir, executables,
>>>>>> explanations_txt):
>>>>>> +        self.base_result_dir = base_result_dir
>>>>>> +        self.config_dir = config_dir
>>>>>> +        self.executables = ' '.join(executables)
>>>>>> +        self.explanations_txt = explanations_txt
>>>>>> +        self.project_name = 'RTEMS-5'
>>>>>> +    def run(self, set_name, symbol_file):
>>>>>> +        covoar_result_dir = path.join(self.base_result_dir,
>>>>>> set_name)
>>>>>> +        if (not path.exists(covoar_result_dir)):
>>>>>> +            path.mkdir(covoar_result_dir)
>>>>>> +        if (not path.exists(symbol_file)):
>>>>>> +            raise error.general('symbol set file: coverage %s was
>>>>>> not created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>> +        command = ('covoar -S ' + symbol_file
>>>>>> +                  + ' -O ' + covoar_result_dir
>>>>>> +                  + ' -E ' + self.explanations_txt
>>>>>> +                  + ' -p ' + self.project_name + ' ' +
>>>>>> self.executables)
>>>>>> +        log.notice('Running covoar for %s' % (set_name))
>>>>>> +        print( 'covoar results directory:\n' + covoar_result_dir )
>>>>>> +        executor = execute.execute(verbose = True, output =
>>>>>> self.output_handler)
>>>>>> +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>>>> +        if (exit_code[0] != 0):
>>>>>> +            raise error.general('covoar failure exit code: %d' %
>>>>>> (exit_code[0]))
>>>>>> +        log.notice('Coverage run for %s finished successfully.' %
>>>>>> (set_name))
>>>>>> +        log.notice('-----------------------------------------------'
>>>>>> +    def output_handler(self, text):
>>>>>> +        log.notice('%s' % (text))
>>>>>> +class coverage_run(object):
>>>>>> +    Coverage analysis support for rtems-test
>>>>>> +    def __init__(self, p_macros, coverage_arg, executables):
>>>>>> +        Constructor
>>>>>> +        self.macros = p_macros
>>>>>> +        self.build_dir = self.macros['_cwd']
>>>>>> +        self.explanations_txt = self.macros.expand(self.
>>>>>> macros['cov_explanations'])
>>>>>> +        self.test_dir = path.join(self.build_dir, self.macros['bsp']
>>>>>> + '-coverage')
>>>>>> +        if (not path.exists(self.test_dir)):
>>>>>> +            path.mkdir(self.test_dir)
>>>>>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>> +        self.rtscripts = self.macros.expand(self.
>>>>>> macros['_rtscripts'])
>>>>>> +        self.coverage_config_path = path.join(self.rtscripts,
>>>>>> 'coverage')
>>>>>> +        self.symbol_config_path = path.join(self.coverage_
>>>>>> config_path,
>>>>>> +                                            'symbol-sets.ini')
>>>>>> +        self.symbol_select_path = path.join(self.coverage_
>>>>>> config_path,
>>>>>> +                                            self.macros['bsp'] +
>>>>>> '-symbols.ini')
>>>>>> +        self.symbol_sets = []
>>>>>> +        self.no_clean = int(self.macros['_no_clean'])
>>>>>> +        self.report_format = self.macros['cov_report_format']
>>>>>> +        self.coverage_arg = coverage_arg
>>>>>> +        self.target = self.macros['target']
>>>>>> +    def run(self):
>>>>>> +        try:
>>>>>> +            if self.executables is None:
>>>>>> +                raise error.general('no test executables provided.')
>>>>>> +            build_dir = build_path_generator(self.executables,
>>>>>> self.target).run()
>>>>>> +            parser = symbol_parser(self.symbol_config_path,
>>>>>> +                                   self.symbol_select_path,
>>>>>> +                                   self.coverage_arg,
>>>>>> +                                   build_dir)
>>>>>> +            parser.run()
>>>>>> +            covoar_runner = covoar(self.test_dir,
>>>>>> +                                   self.executables,
>>>>>> self.explanations_txt)
>>>>>> +            covoar_runner.run('score', self.symbol_select_path)
>>>>>> +            self._generate_reports();
>>>>>> +            self._summarize();
>>>>>> +        finally:
>>>>>> +            self._cleanup();
>>>>>> +    def _generate_reports(self):
>>>>>> +        log.notice('Generating reports')
>>>>>> +        if self.report_format == 'html':
>>>>>> +            report = report_gen_html(self.symbol_sets,
>>>>>> +                                     self.build_dir,
>>>>>> +                                     self.rtdir,
>>>>>> +                                     self.macros['bsp'])
>>>>>> +            report.generate()
>>>>>> +            report.add_covoar_src_path()
>>>>>> +    def _cleanup(self):
>>>>>> +        if not self.no_clean:
>>>>>> +            log.notice('***Cleaning tempfiles***')
>>>>>> +            for exe in self.executables:
>>>>>> +                trace_file = exe + '.cov'
>>>>>> +                if path.exists(trace_file):
>>>>>> +                    os.remove(trace_file)
>>>>>> +            os.remove(self.symbol_select_path)
>>>>>> +    def _summarize(self):
>>>>>> +        log.notice('Coverage analysis finished. You can find results
>>>>>> in %s' % (self.build_dir))
>>>>>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>> index f4d9b5c..0e744cd 100644
>>>>>> --- a/tester/rt/test.py
>>>>>> +++ b/tester/rt/test.py
>>>>>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>  from rtemstoolkit import reraise
>>>>>>  from rtemstoolkit import stacktraces
>>>>>>  from rtemstoolkit import version
>>>>>> +from rtemstoolkit import check
>>>>>>  from . import bsps
>>>>>>  from . import config
>>>>>>  from . import console
>>>>>>  from . import report
>>>>>> +from . import coverage
>>>>>>  class log_capture(object):
>>>>>>      def __init__(self):
>>>>>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>      def run(self):
>>>>>>          self.thread = threading.Thread(target = self.runner,
>>>>>> -                                       name = 'test[%s]' %
>>>>>> path.basename(self.executable))
>>>>>> +                            name = 'test[%s]' %
>>>>>>          self.thread.start()
>>>>>>      def is_alive(self):
>>>>>> @@ -221,15 +223,16 @@ def run(command_path = None):
>>>>>>      opts = None
>>>>>>      default_exefilter = '*.exe'
>>>>>>      try:
>>>>>> -        optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>>>>> -                    '--rtems-bsp':   'The RTEMS BSP to run the test
>>>>>> on',
>>>>>> -                    '--user-config': 'Path to your local user
>>>>>> configuration INI file',
>>>>>> -                    '--report-mode': 'Reporting modes, failures
>>>>>> (default),all,none',
>>>>>> -                    '--list-bsps':   'List the supported BSPs',
>>>>>> -                    '--debug-trace': 'Debug trace based on specific
>>>>>> flags',
>>>>>> -                    '--filter':      'Glob that executables must
>>>>>> match to run (default: ' +
>>>>>> +        optargs = { '--rtems-tools':    'The path to the RTEMS
>>>>>> tools',
>>>>>> +                    '--rtems-bsp':      'The RTEMS BSP to run the
>>>>>> test on',
>>>>>> +                    '--user-config':    'Path to your local user
>>>>>> +                    '--report-mode':    'Reporting modes, failures
>>>>>> +                    '--list-bsps':      'List the supported BSPs',
>>>>>> +                    '--debug-trace':    'Debug trace based on
>>>>>> specific flags',
>>>>>> +                    '--filter':         'Glob that executables must
>>>>>>                                default_exefilter + ')',
>>>>>> -                    '--stacktrace':  'Dump a stack trace on a user
>>>>>> termination (^C)' }
>>>>>> +                    '--stacktrace':     'Dump a stack trace on a
>>>>>> user termination (^C)',
>>>>>> +                    '--coverage':       'Perform coverage analysis
>>>>>> of test executables.'}
>>>>>>          mailer.append_options(optargs)
>>>>>>          opts = options.load(sys.argv,
>>>>>>                              optargs = optargs,
>>>>>> @@ -257,6 +260,7 @@ def run(command_path = None):
>>>>>>              exe_filter = default_exefilter
>>>>>>          opts.log_info()
>>>>>>          log.output('Host: ' + host.label(mode = 'all'))
>>>>>> +        executables = find_executables(opts.params(), exe_filter)
>>>>>>          debug_trace = opts.find_arg('--debug-trace')
>>>>>>          if debug_trace:
>>>>>>              if len(debug_trace) != 1:
>>>>>> @@ -279,6 +283,15 @@ def run(command_path = None):
>>>>>>              raise error.general('RTEMS BSP not provided or an
>>>>>> invalid option')
>>>>>>          bsp = config.load(bsp[1], opts)
>>>>>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>>>> +        coverage_enabled = opts.find_arg('--coverage')
>>>>>> +        if coverage_enabled:
>>>>>> +            if len(coverage_enabled) == 2:
>>>>>> +                coverage_runner = coverage.coverage_run(opts.
>>>>>> defaults,
>>>>>> +                                                coverage_enabled[1],
>>>>>> +                                                executables)
>>>>>> +            else:
>>>>>> +                coverage_runner = coverage.coverage_run(opts.defaults,
>>>>>> 0,
>>>>>> +                                                        executables)
>>>>>>          report_mode = opts.find_arg('--report-mode')
>>>>>>          if report_mode:
>>>>>>              if report_mode[1] != 'failures' and \
>>>>>> @@ -288,7 +301,6 @@ def run(command_path = None):
>>>>>>              report_mode = report_mode[1]
>>>>>>          else:
>>>>>>              report_mode = 'failures'
>>>>>> -        executables = find_executables(opts.params(), exe_filter)
>>>>>>          if len(executables) == 0:
>>>>>>              raise error.general('no executables supplied')
>>>>>>          start_time = datetime.datetime.now()
>>>>>> @@ -365,6 +377,8 @@ def run(command_path = None):
>>>>>>                      reports.failures(),
>>>>>>                      'Log', '===', ''] + output.get()
>>>>>>              mail.send(to_addr, subject, os.linesep.join(body))
>>>>>> +            coverage_runner.run()
>>>>>>      except error.general as gerr:
>>>>>>          print(gerr)
>>>>>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> index 6b5e7e6..2f89117 100644
>>>>>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> @@ -31,9 +31,10 @@
>>>>>>  # The Leon 3 QEMU BSP
>>>>>> -[leon3-qemu]
>>>>>> +[leon3-qemu-cov]
>>>>>>  bsp               = leon3-qemu
>>>>>>  arch              = sparc
>>>>>> +target            = sparc-rtems5
>>>>>>  tester            = %{_rtscripts}/qemu.cfg
>>>>>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> index 0000000..a2ec7bc
>>>>>> --- /dev/null
>>>>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> @@ -0,0 +1,36 @@
>>>>>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>> are met:
>>>>>> notice,
>>>>>> copyright notice,
>>>>>> documentation
>>>>>> CONTRIBUTORS "AS IS"
>>>>>> TO, THE
>>>>>> PURPOSE
>>>>>> CONTRIBUTORS BE
>>>>>> OF
>>>>>> BUSINESS
>>>>>> WHETHER IN
>>>>>> OTHERWISE)
>>>>>> ADVISED OF THE
>>>>>> +[symbol-sets]
>>>>>> +sets = score,rtems
>>>>>> +[libraries]
>>>>>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>>>>> qemu.cfg
>>>>>> index bfcd2f5..52a3752 100644
>>>>>> --- a/tester/rtems/testing/qemu.cfg
>>>>>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>> @@ -51,8 +51,8 @@
>>>>>>  # Qemu common option patterns.
>>>>>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>> -nographic
>>>>>> -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>>> -nographic
>>>>>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>> -nographic
>>>>>> +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>>> -nographic
>>>>>>  %define qemu_opts_no_net -net none
>>>>>> 2.14.3
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180606/c2ea9dbe/attachment-0002.html>
