error while building leon3 with gcov flags
Thu Jun 7 19:39:39 UTC 2018
Bringing in Krzysztof. Hoping he can get us on the right track here.
I don't think you can run GcovData.cc independent of a covoar run.
If you can figure out how to write a unit test that would be helpful.
On Thu, Jun 7, 2018 at 2:29 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Hello,
> I was looking into the code in GcovData.cc to see how it works
> and what it's doing, too me it looked like very messed up, I couldn't
> understand (yet) what it's trying to do.
> Is there some way I can manually run it for one file?
> Is there any place where I can read how it was intended to work?
> Or something like a flow diagram?
> -- vijay
> On 7 June 2018 at 02:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On Thu, 7 Jun 2018, 02:39 Joel Sherrill, <joel at rtems.org> wrote:
>>> On Wed, Jun 6, 2018, 3:56 PM Vijay Kumar Banerjee <
>>>> On 7 June 2018 at 01:48, Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Wed, Jun 6, 2018, 2:07 PM Vijay Kumar Banerjee <
>>>>>> On 6 June 2018 at 20:49, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> I can't duplicate this. My configure command was:
>>>>>>> ../rtems/configure --target=sparc-rtems5 --enable-rtemsbsp=leon3
>>>>>>> --prefix=/home/joel/rtems-work/tools/5 \
>>>>>>>    --disable-networking --enable-posix --disable-smp
>>>>>>> --disable-multiprocessing \
>>>>>>>    --enable-tests --enable-cxx --enable-maintainer-mode
>>>>>>> What was yours?
>>>>>>> I didn't have --enable-cxx and --enable-maintainer-more.
>>>>>> I made some tries and somehow it's perfectly working now.
>>>>>> I am trying to find out now how covoar generates the reports.
>>>>>> I made a file with a list of all gcno in score/ and run with -g
>>>>>> argument
>>>>>> now I'mg seeing the following error while running covoar
>>>>>> Generating Gcov reports...
>>>>>> Processing file: libscore_a-allocatormutex.gcno
>>>>>> Unable to open libscore_a-allocatormutex.gcno
>>>>>> Processing file: libscore_a-apimutexisowner.gcno
>>>>>> Unable to open libscore_a-apimutexisowner.gcno
>>>>>> Processing file: libscore_a-apimutexlock.gcno
>>>>>> Unable to open libscore_a-apimutexlock.gcno
>>>>>> Processing file: libscore_a-apimutexunlock.gcno
>>>>>> Unable to open libscore_a-apimutexunlock.gcno
>>>>>> Processing file: libscore_a-chain.gcno
>>>>>> Unable to open libscore_a-chain.gcno
>>>>>> Processing file: libscore_a-chainnodecount.gcno
>>>>> I suspect this is another instance of the path issues inside the build
>>>>> tree you and Cillian fixed earlier.
>>>>> correcting the path worked.
>>> Submit a patch for this. It needs fixing to get 5onyour next issue.
>> It just needed the absolute path to be fed.
>> here's what I did.
>> I manually 'find' all the gcno files under score.
>> wrote it all in a file separated by newlines.
>> fed that file as an argument to covoar.
>> and that brought me here.
>> So when we write script, these are the
>> things that will be done by the script.
>> Once everything strats running manually,
>> we can proceed to write scripts.
>>>> Now I'm getting this error.
>>>> Processing file: sparc-rtems5/c/leon3/cpukit/sc
>>>> ore/src/libscore_a-kern_tc.gcno
>>>> ERROR: Unable to read string from gcov file
>>>> ERROR: Unable to read string length from gcov file
>>>> ERROR: Unable to read Function starting line number
>>>> Segmentation fault (core dumped)
>>> Welcome to GSoC! You are now in new territory. :)
>> So here the real work begins!
>>> Dig in and see what went wrong. Be aware.that GCC file formats may (or
>>> may not) be subject to.changing over time and this could just be bitrot.
>> I got started with it.
>>> Gcov-dump is installed with the compiler.
>>> You should check it we have a .h file describing the file and it is out
>>> of date.
>> I'll look into it.
>>> Also I think we now should bring the gsov maintainer in.
>> The covoar's gcov support needs to be reworked.
>> We can get the help of the expert here.
>>> Good job!
>> Thanks. :)
>>>>>>> On Wed, Jun 6, 2018 at 9:40 AM, Vijay Kumar Banerjee <
>>>>>>>> Hello,
>>>>>>>> I have added the following changes in the
>>>>>>>> bsps/sparc/leon3/config/leon3.cfg
>>>>>>>> CFLAGS_OPTIMIZE_V = -Os -g
>>>>>>>> CFLAGS_OPTIMIZE_V += -ftest-coverage
>>>>>>>> While trying to build with these flags, I got a bunch of
>>>>>>>> the following errors:
>>>>>>>> {standard input}: Assembler messages:
>>>>>>>> {standard input}:6510: Error: can't resolve `.data._SPARC_Counter'
>>>>>>>> {.data._SPARC_Counter section} - `.LLtext0' {.text section}
>>>>>>>> {standard input}:6511: Error: can't resolve `.data._SPARC_Counter'
>>>>>>>> after the `make install` I do get a lot of .gcno files, and no
>>>>>>>> executables.
>>>>>>>> -- vijay
>>>>>>>> _______________________________________________
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180607/715c1eaf/attachment-0002.html>
