error while building leon3 with gcov flags
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Jun 7 19:43:34 UTC 2018
On Fri, 8 Jun 2018, 01:09 Joel Sherrill, <joel at rtems.org> wrote:
> Bringing in Krzysztof. Hoping he can get us on the right track here.
> I don't think you can run GcovData.cc independent of a covoar run.
Understood.
> If you can figure out how to write a unit test that would be helpful.
Will try to do that if possible.
> On Thu, Jun 7, 2018 at 2:29 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hello,
>> I was looking into the code in GcovData.cc to see how it works
>> and what it's doing, too me it looked like very messed up, I couldn't
>> understand (yet) what it's trying to do.
>> Is there some way I can manually run it for one file?
>> Is there any place where I can read how it was intended to work?
>> Or something like a flow diagram?
>> -- vijay
>> On 7 June 2018 at 02:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> On Thu, 7 Jun 2018, 02:39 Joel Sherrill, <joel at rtems.org> wrote:
>>>> On Wed, Jun 6, 2018, 3:56 PM Vijay Kumar Banerjee <
>>>>> On 7 June 2018 at 01:48, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Wed, Jun 6, 2018, 2:07 PM Vijay Kumar Banerjee <
>>>>>>> On 6 June 2018 at 20:49, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>> I can't duplicate this. My configure command was:
>>>>>>>> ../rtems/configure --target=sparc-rtems5 --enable-rtemsbsp=leon3
>>>>>>>> --prefix=/home/joel/rtems-work/tools/5 \
>>>>>>>>    --disable-networking --enable-posix --disable-smp
>>>>>>>> --disable-multiprocessing \
>>>>>>>>    --enable-tests --enable-cxx --enable-maintainer-mode
>>>>>>>> What was yours?
>>>>>>>> I didn't have --enable-cxx and --enable-maintainer-more.
>>>>>>> I made some tries and somehow it's perfectly working now.
>>>>>>> I am trying to find out now how covoar generates the reports.
>>>>>>> I made a file with a list of all gcno in score/ and run with -g
>>>>>>> argument
>>>>>>> now I'mg seeing the following error while running covoar
>>>>>>> Generating Gcov reports...
>>>>>>> Processing file: libscore_a-allocatormutex.gcno
>>>>>>> Unable to open libscore_a-allocatormutex.gcno
>>>>>>> Processing file: libscore_a-apimutexisowner.gcno
>>>>>>> Unable to open libscore_a-apimutexisowner.gcno
>>>>>>> Processing file: libscore_a-apimutexlock.gcno
>>>>>>> Unable to open libscore_a-apimutexlock.gcno
>>>>>>> Processing file: libscore_a-apimutexunlock.gcno
>>>>>>> Unable to open libscore_a-apimutexunlock.gcno
>>>>>>> Processing file: libscore_a-chain.gcno
>>>>>>> Unable to open libscore_a-chain.gcno
>>>>>>> Processing file: libscore_a-chainnodecount.gcno
>>>>>> I suspect this is another instance of the path issues inside the
>>>>>> build tree you and Cillian fixed earlier.
>>>>>> correcting the path worked.
>>>> Submit a patch for this. It needs fixing to get 5onyour next issue.
>>> It just needed the absolute path to be fed.
>>> here's what I did.
>>> I manually 'find' all the gcno files under score.
>>> wrote it all in a file separated by newlines.
>>> fed that file as an argument to covoar.
>>> and that brought me here.
>>> So when we write script, these are the
>>> things that will be done by the script.
>>> Once everything strats running manually,
>>> we can proceed to write scripts.
>>>>> Now I'm getting this error.
>>>>> Processing file:
>>>>> sparc-rtems5/c/leon3/cpukit/score/src/libscore_a-kern_tc.gcno
>>>>> ERROR: Unable to read string from gcov file
>>>>> ERROR: Unable to read string length from gcov file
>>>>> ERROR: Unable to read Function starting line number
>>>>> Segmentation fault (core dumped)
>>>> Welcome to GSoC! You are now in new territory. :)
>>> So here the real work begins!
>>>> Dig in and see what went wrong. Be aware.that GCC file formats may (or
>>>> may not) be subject to.changing over time and this could just be bitrot.
>>> I got started with it.
>>>> Gcov-dump is installed with the compiler.
>>>> You should check it we have a .h file describing the file and it is out
>>>> of date.
>>> I'll look into it.
>>>> Also I think we now should bring the gsov maintainer in.
>>> The covoar's gcov support needs to be reworked.
>>> We can get the help of the expert here.
>>>> Good job!
>>> Thanks. :)
>>>>>>>> On Wed, Jun 6, 2018 at 9:40 AM, Vijay Kumar Banerjee <
>>>>>>>>> Hello,
>>>>>>>>> I have added the following changes in the
>>>>>>>>> bsps/sparc/leon3/config/leon3.cfg
>>>>>>>>> CFLAGS_OPTIMIZE_V = -Os -g
>>>>>>>>> CFLAGS_OPTIMIZE_V += -ftest-coverage
>>>>>>>>> While trying to build with these flags, I got a bunch of
>>>>>>>>> the following errors:
>>>>>>>>> {standard input}: Assembler messages:
>>>>>>>>> {standard input}:6510: Error: can't resolve `.data._SPARC_Counter'
>>>>>>>>> {.data._SPARC_Counter section} - `.LLtext0' {.text section}
>>>>>>>>> {standard input}:6511: Error: can't resolve `.data._SPARC_Counter'
>>>>>>>>> after the `make install` I do get a lot of .gcno files, and no
>>>>>>>>> executables.
>>>>>>>>> -- vijay
>>>>>>>>> _______________________________________________
>>>>>>>>> devel mailing list
>>>>>>>>> devel at rtems.org
>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180608/20bbfa2b/attachment-0002.html>
