want to contribute to project
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Mar 1 09:10:23 UTC 2018
hello,
while trying to figure out the starting point, I came across this project
form GSoC 2017 by C.P. O'Donell
https://summerofcode.withgoogle.com/archive/2017/projects/4925375616385024/
Is this the project that has previous works on the project I'm wanting to
take (#2920) ? If not , please help me find the right one.
Also, please guide me with reading references and some small tickets
related to the project .
Thank you ,
Vijay k.
On 26 February 2018 at 21:54, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
> wrote:
> Thank you for giving me a detailed introduction to the project objectives
> and mentors.
>  I am interested in # 2920: "Improve Coverage analysis toolkit".
> Please guide me with the resources to get started with the project and get
> a deep understanding.
> Thank you
> Vijay
> On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org> wrote:
>> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
>> christian.mauderer at embedded-brains.de> wrote:
>> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
>> > Hello,
>> > As told by Joel, I sent the screenshots of my working hello world to his
>> > personal email and have also included my name in the GSoC tracking page
>> > + Make Eclipse Target Interaction work with RTEMS
>> > (https://www.eclipse.org/tcf/)
>> > + Improvements to our coverage reporting. GCOV validation and covoar
>> > reporting improvements
>> > + wifi integration improvements
>> > + aarch64 port
>> > + x86_64 port / non-legacy PC BSP
>> >    - This project is large so we would need to work with whoever wants
>> > to tackle it
>> >      to find the best subset for GSoC.
>> > Based on this list I went through the OpenProjects page
>> > and came across the following Tickets .,
>> > #2920 ,#3222,#2927 and the link to eclipse tcf .
>> > out of them , I find these interesting
>> > 1.  "Improve coverage Analysis Toolset " (#2920);
>> This area is mine. The ticket mat or may not be a great description of
>> the goals. There are probably three things that need to be done.
>> + Integrate ran recipes for Couverture variant of qemu. This might be a
>> very small task. Last year's student just didn't get this integrated and
>> was waiting for some patches to be merged on their side.
>> + Verify the gcov output from covoar is correct and the gcov (and similar
>> tools) matches the coverage reports it generates. We have someone from the
>> GCC community to help mentor here.
>> + Covoar generates HTML and text output directly. There is a desire for
>> it to generate something equally useful that is processed by existing tools
>> to generate reports. One possible option for this output could be Sphinx
>> like our regular documentation. Or it could be a data-centric format
>> processed by other tools. The current HTML allows filtering and sorting so
>> not losing information and ease of use is important. This probably will end
>> up simplifying C++ and adding Python.
>> > 2.  "libbsd:WiFi support needs rc.conf integration " (#3222)
>> Christian's project to mentor.
>> > also I came across # 3302 :" Build system conversion of BSP Config(.cfg)
>> > files to pkg-config(.pc) files"
>> > (I have some knowledge of Python, but not proficient in it, I can learn
>> > it better if it's required )
>> > which I find interesting
>> This one is Chris Johns project to mentor. It is an important and
>> logically the next step in replacing our build system with the Python based
>> waf. If you get through this one before the summer is out, then working on
>> waf would probably make sense.
>> Did I miss one?
>> Hello Vijay,
>> all of the projects would be good ones.
>> The #2920 and #3302 are more connected to the host tools. They should be
>> doable with few or no real hardware. But you should ask the two
>> potential mentors about that.
>> For the #3222 you would need some board supported by the libbsd (like
>> Beagle Bone Black) and I would suggest a JTAG debugger (some OpenOCD
>> based or similar).
>> > Am I following the right tickets? If not please help me find the right
>> ones.
>> The tickets are the right ones.
>> > Out of these , which one do you recommend me to take ?
>> I would recommend to take a more detailed look at the tickets and start
>> to ask some questions about it on the mailing list with CC to the
>> (potential) mentors.
>> Maybe you could also try to find some small tickets related to similar
>> topics and just try to work on these. That could help you find out what
>> you want to do.
>> > My experience with C/C++ : I am proficient in C++11 with STL . Also
>> > proficient in C language .
>> > My experience with opensource : This is the first open source project
>> > I'm taking up .
>> It's no problem if it's your first Open Source project. That's the point
>> of GSoC: To collect first Open Source experience.
>> Best regards
>> Christian Mauderer
>> > Thank you ,
>> > Vijay K.
>> embedded brains GmbH
>> Herr Christian Mauderer
>> Dornierstr. 4
>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax:   +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180301/b45a7dea/attachment-0001.html>
