want to contribute to project
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu Mar 1 10:08:46 UTC 2018
On 1 March 2018 at 09:10, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> hello,
> while trying to figure out the starting point, I came across this project
> form GSoC 2017 by C.P. O'Donell
> https://summerofcode.withgoogle.com/archive/2017/
> projects/4925375616385024/
> Is this the project that has previous works on the project I'm wanting to
> take (#2920) ? If not , please help me find the right one.
Hi Vijay,
Yes that's the one, let me know if you have any questions about it. When I
checked last month coverage is not working with the RTEMS Tester because
the configuration files for the bsps in rtems-tools/tester/rtems have been
converted from .mc to .ini So the old .mc files I mention need to be
converted before it will work again.
This is what I wrote as the final documentation, it should help you
reproduce what I had working last summer.
https://devel.rtems.org/wiki/GSoC/2017/coveragetools
Try this branch in github for the starting point:
https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
Good luck with the project,
Cillian.
> Also, please guide me with reading references and some small tickets
> related to the project .
> Thank you ,
> Vijay k.
> On 26 February 2018 at 21:54, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Thank you for giving me a detailed introduction to the project objectives
>> and mentors.
>> I am interested in # 2920: "Improve Coverage analysis toolkit".
>> Please guide me with the resources to get started with the project and
>> get a deep understanding.
>> Thank you
>> Vijay
>> On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org> wrote:
>>> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
>>> christian.mauderer at embedded-brains.de> wrote:
>>> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
>>> > Hello,
>>> > As told by Joel, I sent the screenshots of my working hello world to
>>> his
>>> > personal email and have also included my name in the GSoC tracking
>>> page .
>>> > + Make Eclipse Target Interaction work with RTEMS
>>> > (https://www.eclipse.org/tcf/)
>>> > + Improvements to our coverage reporting. GCOV validation and covoar
>>> > reporting improvements
>>> > + wifi integration improvements
>>> > + aarch64 port
>>> > + x86_64 port / non-legacy PC BSP
>>> > - This project is large so we would need to work with whoever wants
>>> > to tackle it
>>> > to find the best subset for GSoC.
>>> > Based on this list I went through the OpenProjects page
>>> > and came across the following Tickets .,
>>> > #2920 ,#3222,#2927 and the link to eclipse tcf .
>>> > out of them , I find these interesting
>>> > 1. "Improve coverage Analysis Toolset " (#2920);
>>> This area is mine. The ticket mat or may not be a great description of
>>> the goals. There are probably three things that need to be done.
>>> + Integrate ran recipes for Couverture variant of qemu. This might be a
>>> very small task. Last year's student just didn't get this integrated and
>>> was waiting for some patches to be merged on their side.
>>> + Verify the gcov output from covoar is correct and the gcov (and
>>> similar tools) matches the coverage reports it generates. We have someone
>>> from the GCC community to help mentor here.
>>> + Covoar generates HTML and text output directly. There is a desire for
>>> it to generate something equally useful that is processed by existing tools
>>> to generate reports. One possible option for this output could be Sphinx
>>> like our regular documentation. Or it could be a data-centric format
>>> processed by other tools. The current HTML allows filtering and sorting so
>>> not losing information and ease of use is important. This probably will end
>>> up simplifying C++ and adding Python.
>>> > 2. "libbsd:WiFi support needs rc.conf integration " (#3222)
>>> Christian's project to mentor.
>>> > also I came across # 3302 :" Build system conversion of BSP
>>> Config(.cfg)
>>> > files to pkg-config(.pc) files"
>>> > (I have some knowledge of Python, but not proficient in it, I can learn
>>> > it better if it's required )
>>> > which I find interesting
>>> This one is Chris Johns project to mentor. It is an important and
>>> logically the next step in replacing our build system with the Python based
>>> waf. If you get through this one before the summer is out, then working on
>>> waf would probably make sense.
>>> Did I miss one?
>>> Hello Vijay,
>>> all of the projects would be good ones.
>>> The #2920 and #3302 are more connected to the host tools. They should be
>>> doable with few or no real hardware. But you should ask the two
>>> potential mentors about that.
>>> For the #3222 you would need some board supported by the libbsd (like
>>> Beagle Bone Black) and I would suggest a JTAG debugger (some OpenOCD
>>> based or similar).
>>> > Am I following the right tickets? If not please help me find the right
>>> ones.
>>> The tickets are the right ones.
>>> > Out of these , which one do you recommend me to take ?
>>> I would recommend to take a more detailed look at the tickets and start
>>> to ask some questions about it on the mailing list with CC to the
>>> (potential) mentors.
>>> Maybe you could also try to find some small tickets related to similar
>>> topics and just try to work on these. That could help you find out what
>>> you want to do.
>>> > My experience with C/C++ : I am proficient in C++11 with STL . Also
>>> > proficient in C language .
>>> > My experience with opensource : This is the first open source project
>>> > I'm taking up .
>>> It's no problem if it's your first Open Source project. That's the point
>>> of GSoC: To collect first Open Source experience.
>>> Best regards
>>> Christian Mauderer
>>> > Thank you ,
>>> > Vijay K.
>>> embedded brains GmbH
>>> Herr Christian Mauderer
>>> Dornierstr. 4
>>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>>> D-82178 Puchheim
>>> Germany
>>> email: christian.mauderer at embedded-brains.de
>>> Phone: +49-89-18 94 741 - 18
>>> Fax: +49-89-18 94 741 - 08
>>> PGP: Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180301/89fbe684/attachment-0002.html>
