[PATCH] CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER
Tue Mar 6 07:15:10 UTC 2018
Hi,
Looks good.
Should the documentation make mention of why would you select one of these
console drivers?
On 6/3/18 6:08 pm, Sebastian Huber wrote:
> Update #3320.
>  c-user/configuring_a_system.rst | 97 +++++++++++++++++++++++++++++++++++------
>  1 file changed, 84 insertions(+), 13 deletions(-)
> diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
> index 52d667a..6b7f487 100644
> --- a/c-user/configuring_a_system.rst
> +++ b/c-user/configuring_a_system.rst
> @@ -3854,15 +3854,22 @@ DESCRIPTION:
>      application wishes to include the Console Device Driver.
>  NOTES:
> -    This device driver is responsible for providing standard input and output
> -    using */dev/console*.
> +    This device driver is responsible for providing the :file:`/dev/console`
> +    device file.  This device is used to initialize the standard input, output,
> +    and error file descriptors.
>      BSPs should be constructed in a manner that allows ``printk()`` to work
>      properly without the need for the console driver to be configured.
> -    The ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` configuration option is
> -    mutually exclusive with the
> -    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` configuration option.
> +    The
> +    * ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``,
> +    * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``, and
> +    * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
> +    configuration options are mutually exclusive.
>  .. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> @@ -3888,16 +3895,80 @@ DESCRIPTION:
>      application wishes to include the Simple Console Device Driver.
>  NOTES:
> +    This device driver reads via ``getchark()``.
> +    This device driver writes via ``rtems_putc()``.
> +    The Termios framework is not used.  There is no support to change device
> +    settings, e.g. baud, stop bits, parity, etc.
> +    The
> +.. index:: CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
> +.. _CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER:
> +CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
> +CONSTANT:
> +    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
> +DATA TYPE:
> +    Boolean feature macro.
> +RANGE:
> +    Defined or undefined.
> +DEFAULT VALUE:
> +    This is not defined by default.
> +DESCRIPTION:
> +    ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER`` is defined if
> +    the application wishes to include the Simple Task Console Device Driver.
> +NOTES:
> +    This device driver writes into a write buffer.  The count of characters
> +    written into the write buffer is returned.  It might be less than the
> +    requested count, in case the write buffer is full.  The write is
> +    non-blocking and may be called from interrupt context.  A dedicated task
> +    reads from the write buffer and outputs the characters via
> +    ``rtems_putc()``.  This task runs with the least important priority.  The
> +    write buffer size is 2047 characters and it is not configurable.
> +    Use ``fsync(STDOUT_FILENO)`` or ``fdatasync(STDOUT_FILENO)`` to drain the
> +    write buffer.
> +    The
> -    This device driver writes via ``rtems_putc()`` and reads via
> -    ``getchark()``.  The Termios framework is not used.  There is no support to
> -    change device settings, e.g. baud, stop bits, parity, etc.
> -    The ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER`` configuration
> -    option is mutually exclusive with the
> -    ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` configuration option.
>  .. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
