[PATCH] c-user: Simplify clustered scheduler configuration
Thu Mar 8 07:06:43 UTC 2018
Close #3325.
 c-user/configuring_a_system.rst | 71 +++++++++++++++++++++--------------------
 1 file changed, 36 insertions(+), 35 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 58b381c..c335eaf 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -3614,11 +3614,11 @@ DESCRIPTION:
     scheduling algorithm. If ``CONFIGURE_SCHEDULER_USER`` is defined then the
     following additional macros must be defined:
-    - ``CONFIGURE_SCHEDULER_CONTEXT`` must be defined to a static definition of
-      the scheduler context of the user scheduler.
+    - ``CONFIGURE_SCHEDULER`` must be defined to a static definition of
+      the scheduler data structures of the user scheduler.
-    - ``CONFIGURE_SCHEDULER_CONTROLS`` must be defined to a scheduler control
-      initializer for the user scheduler.
+    - ``CONFIGURE_SCHEDULER_TABLE_ENTRIES`` must be defined to a scheduler
+      table entry initializer for the user scheduler.
     - ``CONFIGURE_SCHEDULER_USER_PER_THREAD`` must be defined to the type of
       the per-thread information of the user scheduler.
@@ -3646,7 +3646,7 @@ and thus avoid expensive cache synchronization traffic.
 We have clustered scheduling in case the set of processors of a system is
 partitioned into non-empty pairwise-disjoint subsets.  These subsets are called
 clusters.  Clusters with a cardinality of one are partitions.  Each cluster is
-owned by exactly one scheduler instance.
+owned by exactly one scheduler.
 A clustered scheduler configuration is optional.  By default, up to 32
 processors are managed by the :ref:`EDF SMP Scheduler <SchedulerSMPEDF>`.  In
@@ -3681,44 +3681,45 @@ macros.
 Configuration Step 2 - Schedulers
-Each scheduler needs a context to store state information at run-time.  Use the
-following macros to create scheduler contexts
+Each scheduler needs some data structures.  Use the following macros to create
+the scheduler data structures for a particular scheduler identified in the
+configuration by ``name``.
-- ``RTEMS_SCHEDULER_CONTEXT_EDF_SMP(name, max_cpu_count)``,
+- ``RTEMS_SCHEDULER_EDF_SMP(name, max_cpu_count)``,
-- ``RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP(name, prio_count)``,
+- ``RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP(name, prio_count)``,
-- ``RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP(name, prio_count)``, and
+- ``RTEMS_SCHEDULER_PRIORITY_SMP(name, prio_count)``, and
-- ``RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(name)``.
+- ``RTEMS_SCHEDULER_SIMPLE_SMP(name)``.
-The ``name`` parameter is used as part of a designator for a global variable,
-so the usual C/C++ designator rules apply.  This ``name`` is not the scheduler
-object name.  Additional parameters are scheduler-specific.
+The ``name`` parameter is used as part of a designator for scheduler-specific
+data structures, so the usual C/C++ designator rules apply.  This ``name`` is
+not the scheduler object name.  Additional parameters are scheduler-specific.
 .. _ConfigurationSchedulerTable:
 Configuration Step 3 - Scheduler Table
-The schedulers are registered in the system via the scheduler table.
-To create the scheduler table define ``CONFIGURE_SCHEDULER_CONTROLS`` to a list
-of the following scheduler control initializers
+The schedulers are registered in the system via the scheduler table.  To
+populate the scheduler table define ``CONFIGURE_SCHEDULER_TABLE_ENTRIES`` to a
+list of the following scheduler table entry initializers
-- ``RTEMS_SCHEDULER_CONTROL_EDF_SMP(name, obj_name)``,
+- ``RTEMS_SCHEDULER_TABLE_EDF_SMP(name, obj_name)``,
-- ``RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP(name, obj_name)``,
+- ``RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP(name, obj_name)``,
-- ``RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(name, obj_name)``, and
+- ``RTEMS_SCHEDULER_TABLE_PRIORITY_SMP(name, obj_name)``, and
-- ``RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(name, obj_name)``.
+- ``RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(name, obj_name)``.
 The ``name`` parameter must correspond to the parameter defining the scheduler
-context.  The ``obj_name`` determines the scheduler object name and can be used
-in :ref:`rtems_scheduler_ident() <rtems_scheduler_ident>` to get the scheduler
-object identifier.  The scheduler index is defined by the index of the
-scheduler table.  It is a configuration error to add a scheduler multiple times
-to the scheduler table.
+data structures of configuration step 2.  The ``obj_name`` determines the
+scheduler object name and can be used in :ref:`rtems_scheduler_ident()
+<rtems_scheduler_ident>` to get the scheduler object identifier.  The scheduler
+index is defined by the index of the scheduler table.  It is a configuration
+error to add a scheduler multiple times to the scheduler table.
 Configuration Step 4 - Processor to Scheduler Assignment
@@ -3731,7 +3732,7 @@ processor assignment to a scheduler can be optional or mandatory.  The boot
 processor must have a scheduler assigned.  In case the system needs more
 mandatory processors than available then a fatal run-time error will occur.  To
 specify the scheduler assignments define
-``CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS`` to a list of
+``CONFIGURE_SCHEDULER_ASSIGNMENTS`` to a list of
 - ``RTEMS_SCHEDULER_ASSIGN(scheduler_index, attr)`` and
@@ -3786,22 +3787,22 @@ that the two systems cannot interfere in an undesirable way.
     #include <rtems/scheduler.h>
     /* Configuration Step 2 - Schedulers */
-    RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP(io, CONFIGURE_MAXIMUM_PRIORITY + 1);
-    RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP(work, CONFIGURE_MAXIMUM_PRIORITY + 1);
+    RTEMS_SCHEDULER_PRIORITY_SMP(io, CONFIGURE_MAXIMUM_PRIORITY + 1);
+    RTEMS_SCHEDULER_PRIORITY_SMP(work, CONFIGURE_MAXIMUM_PRIORITY + 1);
     /* Configuration Step 3 - Scheduler Table */
-    #define CONFIGURE_SCHEDULER_CONTROLS \\
-      RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( \
+    #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \\
+      RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( \
         io, \
          rtems_build_name('I', 'O', ' ', ' ') \
         work, \
         rtems_build_name('W', 'O', 'R', 'K') \
     /* Configuration Step 4 - Processor to Scheduler Assignment */
-    #define CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS \
+    #define CONFIGURE_SCHEDULER_ASSIGNMENTS \
       RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
       RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER, \
       RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
@@ -3814,7 +3815,7 @@ that the two systems cannot interfere in an undesirable way.
 Configuration Errors
-In case one of the scheduler indices in ``CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS``
+In case one of the scheduler indices in ``CONFIGURE_SCHEDULER_ASSIGNMENTS``
 is invalid a link-time error will occur with an undefined reference to
 ``RTEMS_SCHEDULER_INVALID_INDEX``.
@@ -3832,7 +3833,7 @@ or a lack of processors on the system.  The fatal source is
 - ``SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED`` - the start of a mandatory
   processor failed during system initialization.  The system may not have this
   processor at all or it could be a problem with a boot loader for example.
-  Check the ``CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS`` definition.
+  Check the ``CONFIGURE_SCHEDULER_ASSIGNMENTS`` definition.
 - ``SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR`` - it is not allowed
   to start multitasking on a processor with no scheduler assigned.
2.12.3
