tests using FP specifiers in prints
Sebastian Huber
Thu Mar 8 07:52:34 UTC 2018
On 09/02/18 13:21, Sebastian Huber wrote:
> On 09/02/18 08:58, Sebastian Huber wrote:
>> On 08/02/18 16:45, Joel Sherrill wrote:
>>> sp19 and tm26 are not in that list. What about them?
>> They should be fixed now.
> The sp19 fails now on SPARC:
> *** BEGIN OF TEST SP 19 ***
> *** TEST VERSION: 5.0.0.dc8fd0152928649ac83632a712d96c0dbeca05ae
> *** TEST STATE: EXPECTED-PASS
> *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
> 703532cb04c6990fb21e97cb7347a16e9df11108, Newlib 3.0.0)
> FP1 - integer base = (0x6000)
> FP1 - float base = (NA)
> TA1 - integer base = (0x1000)
> TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
> CPU 0: breakpoint 1 hit
> 0x4000bc98: 94102000 mov 0, %o2 <_Terminate+4>
> CPU 1: Power down mode
> CPU 2: Power down mode
> CPU 3: Power down mode
> grmon2> bt
> %pc %sp
> #0 0x4000bc98 0x40025b68 <_Terminate+0x4>
> #1 0x4000bce8 0x40025bd0 <_Internal_error+0x8>
> #2 0x40005cf8 0x40025c30 <bsp_spurious_handler+0x24>
> #3 0x4001f848 0x40025c98
> #4 0x400172d8 0x40031ba0 <_vfprintf_r+0x2e8>
> #5 0x400198d8 0x40031e28 <__sbprintf+0x70>
> #6 0x40017280 0x40032308 <_vfprintf_r+0x290>
> #7 0x40014880 0x400324e0 <rtems_vprintf+0x28>
> #8 0x40013e44 0x40032540 <rtems_test_printf+0x2c>
> #9 0x40004688 0x400325a8 <Task_1+0x1ec>
> #10 0x4000f7a0 0x400326b8 <_Thread_Entry_adaptor_numeric+0x8>
> #11 0x4000f870 0x40032718 <_Thread_Handler+0x60>
> #12 0x4000f810 0x40032778 <_Thread_Handler+0>
> I don't know how to fix this. The Task_1 is created with/without
> RTEMS_FLOATING_POINT. Changing everything to RTEMS_FLOATING_POINT may
> change the test objectives.
I fixed it like this:
https://git.rtems.org/rtems/commit/?id=828049cb47d974fcc816a5bd8868fdaf670201a3
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
