RFC: Remove score/cpu/.../types.h
Thu Mar 8 07:09:07 UTC 2018
On 07/03/18 20:06, Joel Sherrill wrote:
> The discussion over adding paravirt.h and tinkering at that level
> made me realize that the score/cpu/.../types.h files are very small.
> They only have the CPU_Uint32ptr type plus sometimes some
> odd things like blackfin_isr_entry (unused).
> If CPU_Uint32ptr is moved to cpu.h, then the other contents have
> to be evaluated on a per file basis. But on first review, most of the
> files would be easy to eliminate. In some cases, another typedef
> would move to cpu.h.
> Thoughts/comments?
Yes, we should get rid of this file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
