[PATCH] bootstrap: Use printf instead of echo -e for POSIX shells
Joel Sherrill
joel at rtems.org
Fri Mar 9 19:27:47 UTC 2018
Awesome! Good catch! I have pushed the patch and closed the ticket.
I should have spotted it but if you make the last line of your git message
something like:
Closes #NNN.
Updates #NNN.
where NNN is the ticket number, the git hook for Trac will automatically
update the ticket.
On Fri, Mar 9, 2018 at 11:00 AM, Amaan Cheval <amaan.cheval at gmail.com>
wrote:
> On Fri, Mar 9, 2018 at 9:47 PM Joel Sherrill <joel at rtems.org> wrote:
> > Can you file a ticket for this? It seems like something which should be
> > considered for release branches.
> Sure. Here it is:
> https://devel.rtems.org/ticket/3328
> Note, however, that the use of "echo -e" was introduced in 2afb22b,
> to remove the make preinstall step[1], so it isn't in any of the current
> releases as far as I can tell, only on master.
> [1] https://devel.rtems.org/ticket/3254#comment:78
> > What shell(s)/host(s) did this show up on?
> I use zsh on Ubuntu 16.04 LTS (4.4.0-78-generic x86_64 GNU/Linux),
> but since #!/bin/sh is specified in bootstrap, my use of zsh (which does
> support -e) is negated by my built-in sh.
> The "-e" option may or may not be present even on sh or bash, apparently:
> https://unix.stackexchange.com/questions/88307/escape-
> sequences-with-echo-e-in-different-shells#comment131955_88310
> > Thanks.
> > --joel
> > On Fri, Mar 9, 2018 at 9:55 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
> >> On POSIX compliant shells, echo does not have the -e option.
> >> This causes the "-e" to be echoed as well, causing potential buggy
> >> build processes.
> >> Example shell session:
> >> -> % sh
> >> $ echo -e "foo bar"
> >> -e foo bar
> >> According to POSIX, "\$" should be fine regardless due to the use of
> >> double-quotes[1]. However, since printf is recommended over echo anyway,
> >> we replace "echo -e" with printf where required.
> >> [1]
> http://pubs.opengroup.org/onlinepubs/009695399/
> utilities/xcu_chap02.html#tag_02_02_03
> >> bootstrap | 4 ++--
> >> 1 file changed, 2 insertions(+), 2 deletions(-)
> >> diff --git a/bootstrap b/bootstrap
> >> index eb6d4fc8f3..b94fa244ce 100755
> >> --- a/bootstrap
> >> +++ b/bootstrap
> >> @@ -152,7 +152,7 @@ headers)
> >> if test x$d != x. ; then
> >> am_dir=`echo $dir | sed 's%[/-]%_%g'`
> >> am_dir="_$am_dir"
> >> - echo -e "\ninclude${am_dir}dir = \$(includedir)/$dir" >>
> "$tmp"
> >> + printf "\ninclude${am_dir}dir = \$(includedir)/$dir\n" >>
> "$tmp"
> >> else
> >> am_dir=""
> >> echo "" >> "$tmp"
> >> @@ -161,7 +161,7 @@ headers)
> >> fi
> >> echo "include${am_dir}_HEADERS += $inc$j" >> "$tmp"
> >> if test $j = bsp.h ; then
> >> - echo -e "include_HEADERS += include/bspopts.h" >> "$tmp"
> >> + echo "include_HEADERS += include/bspopts.h" >> "$tmp"
> >> fi
> >> done
> >> done
> >> 2.13.0
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180309/ec459a34/attachment.html>
