[PATCH] bootstrap: Use printf instead of echo -e for POSIX shells
Amaan Cheval amaan.cheval at gmail.com
Fri Mar 9 21:37:49 UTC 2018
Cheers!
I'll keep that in mind next time. :)
On Sat, Mar 10, 2018 at 12:57 AM Joel Sherrill <joel at rtems.org> wrote:
> Awesome! Good catch! I have pushed the patch and closed the ticket.
> I should have spotted it but if you make the last line of your git message
> something like:
> Closes #NNN.
> Updates #NNN.
> where NNN is the ticket number, the git hook for Trac will automatically
> update the ticket.
> On Fri, Mar 9, 2018 at 11:00 AM, Amaan Cheval <amaan.cheval at gmail.com>
wrote:
>> On Fri, Mar 9, 2018 at 9:47 PM Joel Sherrill <joel at rtems.org> wrote:
>> > Can you file a ticket for this? It seems like something which should be
>> > considered for release branches.
>> Sure. Here it is:
>> https://devel.rtems.org/ticket/3328
>> Note, however, that the use of "echo -e" was introduced in 2afb22b,
>> to remove the make preinstall step[1], so it isn't in any of the current
>> releases as far as I can tell, only on master.
>> [1] https://devel.rtems.org/ticket/3254#comment:78
>> > What shell(s)/host(s) did this show up on?
>> I use zsh on Ubuntu 16.04 LTS (4.4.0-78-generic x86_64 GNU/Linux),
>> but since #!/bin/sh is specified in bootstrap, my use of zsh (which does
>> support -e) is negated by my built-in sh.
>> The "-e" option may or may not be present even on sh or bash, apparently:
https://unix.stackexchange.com/questions/88307/escape-sequences-with-echo-e-in-different-shells#comment131955_88310
>> > Thanks.
>> > --joel
>> > On Fri, Mar 9, 2018 at 9:55 AM, Amaan Cheval <amaan.cheval at gmail.com>
>> wrote:
>> >> On POSIX compliant shells, echo does not have the -e option.
>> >> This causes the "-e" to be echoed as well, causing potential buggy
>> >> build processes.
>> >> Example shell session:
>> >> -> % sh
>> >> $ echo -e "foo bar"
>> >> -e foo bar
>> >> According to POSIX, "\$" should be fine regardless due to the use of
>> >> double-quotes[1]. However, since printf is recommended over echo
anyway,
>> >> we replace "echo -e" with printf where required.
>> >> [1]
http://pubs.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_02_03
>> >>   bootstrap | 4 ++--
>> >>   1 file changed, 2 insertions(+), 2 deletions(-)
>> >> diff --git a/bootstrap b/bootstrap
>> >> index eb6d4fc8f3..b94fa244ce 100755
>> >> --- a/bootstrap
>> >> +++ b/bootstrap
>> >> @@ -152,7 +152,7 @@ headers)
>> >>             if test x$d != x. ; then
>> >>               am_dir=`echo $dir | sed 's%[/-]%_%g'`
>> >>               am_dir="_$am_dir"
>> >> -            echo -e "\ninclude${am_dir}dir = \$(includedir)/$dir" >>
>> "$tmp"
>> >> +            printf "\ninclude${am_dir}dir = \$(includedir)/$dir\n" >>
>> "$tmp"
>> >>             else
>> >>               am_dir=""
>> >>               echo "" >> "$tmp"
>> >> @@ -161,7 +161,7 @@ headers)
>> >>           fi
>> >>           echo "include${am_dir}_HEADERS += $inc$j" >> "$tmp"
>> >>           if test $j = bsp.h ; then
>> >> -          echo -e "include_HEADERS += include/bspopts.h" >> "$tmp"
>> >> +          echo "include_HEADERS += include/bspopts.h" >> "$tmp"
>> >>           fi
>> >>         done
>> >>       done
>> >> 2.13.0
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
