[PATCH 06/19] nios2/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:19:54 UTC 2018
Updates #3327.
 cpukit/score/cpu/nios2/headers.am                  |  1 -
 cpukit/score/cpu/nios2/include/rtems/score/cpu.h   |  5 ++-
 cpukit/score/cpu/nios2/include/rtems/score/types.h | 46 ----------------------
 3 files changed, 4 insertions(+), 48 deletions(-)
 delete mode 100644 cpukit/score/cpu/nios2/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/nios2/headers.am b/cpukit/score/cpu/nios2/headers.am
index 8cf15f1..b5ca789 100644
--- a/cpukit/score/cpu/nios2/headers.am
+++ b/cpukit/score/cpu/nios2/headers.am
@@ -17,4 +17,3 @@ include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
 include_rtems_score_HEADERS += include/rtems/score/nios2-count-zeros.h
 include_rtems_score_HEADERS += include/rtems/score/nios2-utility.h
 include_rtems_score_HEADERS += include/rtems/score/nios2.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index a3f2f03..c7fdb92 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -24,7 +24,7 @@
 extern "C" {
 #endif
-#include <rtems/score/types.h>
+#include <rtems/score/basedefs.h>
 #include <rtems/score/nios2.h>
 #define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
@@ -363,6 +363,9 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
   return second - first;
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
 #endif /* ASM */
 #ifdef __cplusplus
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/types.h b/cpukit/score/cpu/nios2/include/rtems/score/types.h
deleted file mode 100644
index 23cf394..0000000
--- a/cpukit/score/cpu/nios2/include/rtems/score/types.h
+++ /dev/null
@@ -1,46 +0,0 @@
- * @file
- * @brief Altera Nios II CPU Type Definitions
- * This include file contains type definitions pertaining to the
- * Altera Nios II processor family.
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-typedef void nios2_isr;
-typedef void ( *nios2_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
