[PATCH 05/19] epiphany/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:19:53 UTC 2018
Updates #3327.
 cpukit/score/cpu/epiphany/headers.am               |  1 -
 .../score/cpu/epiphany/include/rtems/score/cpu.h   |  5 +-
 .../score/cpu/epiphany/include/rtems/score/types.h | 67 ----------------------
 3 files changed, 4 insertions(+), 69 deletions(-)
 delete mode 100644 cpukit/score/cpu/epiphany/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/epiphany/headers.am b/cpukit/score/cpu/epiphany/headers.am
index 125a88d..c175bd2 100644
--- a/cpukit/score/cpu/epiphany/headers.am
+++ b/cpukit/score/cpu/epiphany/headers.am
@@ -12,4 +12,3 @@ include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
 include_rtems_score_HEADERS += include/rtems/score/epiphany-utility.h
 include_rtems_score_HEADERS += include/rtems/score/epiphany.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
index 34ac8ae..8979381 100644
--- a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
@@ -39,8 +39,8 @@
 extern "C" {
 #endif
+#include <rtems/score/basedefs.h>
 #include <rtems/score/epiphany.h> /* pick up machine definitions */
-#include <rtems/score/types.h>
 #ifndef ASM
 #include <rtems/bspIo.h>
 #include <stdint.h>
@@ -864,6 +864,9 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
   return second - first;
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
 #endif /* ASM */
 #ifdef __cplusplus
diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/types.h b/cpukit/score/cpu/epiphany/include/rtems/score/types.h
deleted file mode 100644
index 24c8955..0000000
--- a/cpukit/score/cpu/epiphany/include/rtems/score/types.h
+++ /dev/null
@@ -1,67 +0,0 @@
- * @file
- * @brief Epiphany Architecture Types API
- * Copyright (c) 2015 University of York.
- * Hesham ALMatary <hmka501 at york.ac.uk>
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- #ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @addtogroup ScoreCPU
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-typedef void epiphany_isr;
-typedef void ( *epiphany_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
