[PATCH 10/19] m32c/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:19:58 UTC 2018
Updates #3327.
 cpukit/score/cpu/m32c/headers.am                  |  1 -
 cpukit/score/cpu/m32c/include/rtems/score/cpu.h   |  5 ++-
 cpukit/score/cpu/m32c/include/rtems/score/types.h | 49 -----------------------
 3 files changed, 4 insertions(+), 51 deletions(-)
 delete mode 100644 cpukit/score/cpu/m32c/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/m32c/headers.am b/cpukit/score/cpu/m32c/headers.am
index f67d070..3b2a7a7 100644
--- a/cpukit/score/cpu/m32c/headers.am
+++ b/cpukit/score/cpu/m32c/headers.am
@@ -14,4 +14,3 @@ include_rtems_score_HEADERS += include/rtems/score/cpu_asm.h
 include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
 include_rtems_score_HEADERS += include/rtems/score/m32c.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
diff --git a/cpukit/score/cpu/m32c/include/rtems/score/cpu.h b/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
index af1c341..ec0e71c 100644
--- a/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/include/rtems/score/cpu.h
@@ -37,7 +37,7 @@
 extern "C" {
 #endif
-#include <rtems/score/types.h>
+#include <rtems/score/basedefs.h>
 #include <rtems/score/m32c.h>
 /* conditional compilation parameters */
@@ -978,6 +978,9 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
   return second - first;
+/** Type that can store a 32-bit integer or a pointer. */
+typedef unsigned long CPU_Uint32ptr;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/cpu/m32c/include/rtems/score/types.h b/cpukit/score/cpu/m32c/include/rtems/score/types.h
deleted file mode 100644
index 99d8297..0000000
--- a/cpukit/score/cpu/m32c/include/rtems/score/types.h
+++ /dev/null
@@ -1,49 +0,0 @@
- * @file
- * @brief M32C CPU Type Definitions
- * This include file contains type definitions pertaining to the Intel
- * m32c processor family.
- *  COPYRIGHT (c) 1989-2006.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef unsigned long CPU_Uint32ptr;
-/** This defines the return type for an ISR entry point. */
-typedef void m32c_isr;
-/** This defines the prototype for an ISR entry point. */
-typedef m32c_isr ( *m32c_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
