[PATCH 11/19] or1k/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:19:59 UTC 2018
Updates #3327.
 cpukit/score/cpu/or1k/headers.am                  |  1 -
 cpukit/score/cpu/or1k/include/rtems/score/cpu.h   |  5 ++-
 cpukit/score/cpu/or1k/include/rtems/score/types.h | 53 -----------------------
 3 files changed, 4 insertions(+), 55 deletions(-)
 delete mode 100644 cpukit/score/cpu/or1k/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/or1k/headers.am b/cpukit/score/cpu/or1k/headers.am
index 1ddc654..172e23c 100644
--- a/cpukit/score/cpu/or1k/headers.am
+++ b/cpukit/score/cpu/or1k/headers.am
@@ -12,4 +12,3 @@ include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
 include_rtems_score_HEADERS += include/rtems/score/or1k-utility.h
 include_rtems_score_HEADERS += include/rtems/score/or1k.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index 6daca10f..648a7a6 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -30,7 +30,7 @@ extern "C" {
 #include <rtems/score/or1k.h>            /* pick up machine definitions */
 #include <rtems/score/or1k-utility.h>
-#include <rtems/score/types.h>
+#include <rtems/score/basedefs.h>
 #ifndef ASM
 #include <rtems/bspIo.h>
 #include <stdint.h>
@@ -863,6 +863,9 @@ CPU_Counter_ticks _CPU_Counter_difference(
   CPU_Counter_ticks first
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
 #endif /* ASM */
 #ifdef __cplusplus
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/types.h b/cpukit/score/cpu/or1k/include/rtems/score/types.h
deleted file mode 100644
index 09790fe..0000000
--- a/cpukit/score/cpu/or1k/include/rtems/score/types.h
+++ /dev/null
@@ -1,53 +0,0 @@
- * @file
- * @brief OR1K Architecture Types API
- *  This include file contains type definitions pertaining to the
- *  arm processor family.
- *  COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
- #ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @addtogroup ScoreCPU
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-typedef void or1k_isr;
-typedef void ( *or1k_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
