[PATCH 13/19] v850/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:20:01 UTC 2018
Updates #3327.
 cpukit/score/cpu/v850/headers.am                  |  1 -
 cpukit/score/cpu/v850/include/rtems/score/cpu.h   |  5 ++-
 cpukit/score/cpu/v850/include/rtems/score/types.h | 43 -----------------------
 3 files changed, 4 insertions(+), 45 deletions(-)
 delete mode 100644 cpukit/score/cpu/v850/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/v850/headers.am b/cpukit/score/cpu/v850/headers.am
index ea94e64..47ca503 100644
--- a/cpukit/score/cpu/v850/headers.am
+++ b/cpukit/score/cpu/v850/headers.am
@@ -14,5 +14,4 @@ include_rtems_score_HEADERS += include/rtems/score/cpu.h
 include_rtems_score_HEADERS += include/rtems/score/cpu_asm.h
 include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
 include_rtems_score_HEADERS += include/rtems/score/v850.h
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index d3cdf05..620d228 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
@@ -23,7 +23,7 @@
 extern "C" {
 #endif
-#include <rtems/score/types.h>
+#include <rtems/score/basedefs.h>
 #include <rtems/score/v850.h>
 /* conditional compilation parameters */
@@ -944,6 +944,9 @@ static inline CPU_Counter_ticks _CPU_Counter_difference(
   return second - first;
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/cpu/v850/include/rtems/score/types.h b/cpukit/score/cpu/v850/include/rtems/score/types.h
deleted file mode 100644
index bfec49d..0000000
--- a/cpukit/score/cpu/v850/include/rtems/score/types.h
+++ /dev/null
@@ -1,43 +0,0 @@
- * @file
- * @brief V850 CPU Type Definitions
- * This include file contains type definitions pertaining to the
- * v850 processor family.
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
