[PATCH 14/19] arm/include/rtems/score/types.h: Eliminate this file
Fri Mar 9 22:20:02 UTC 2018
Updates #3327.
 cpukit/score/cpu/arm/headers.am                  |  1 -
 cpukit/score/cpu/arm/include/rtems/score/cpu.h   |  5 ++-
 cpukit/score/cpu/arm/include/rtems/score/types.h | 51 ------------------------
 3 files changed, 4 insertions(+), 53 deletions(-)
 delete mode 100644 cpukit/score/cpu/arm/include/rtems/score/types.h
diff --git a/cpukit/score/cpu/arm/headers.am b/cpukit/score/cpu/arm/headers.am
index 61a055f..6325328 100644
--- a/cpukit/score/cpu/arm/headers.am
+++ b/cpukit/score/cpu/arm/headers.am
@@ -21,4 +21,3 @@ include_rtems_score_HEADERS += include/rtems/score/cpu.h
 include_rtems_score_HEADERS += include/rtems/score/cpu_asm.h
 include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
-include_rtems_score_HEADERS += include/rtems/score/types.h
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index 05e236c..15e3ac7 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -29,7 +29,7 @@
 #ifndef _RTEMS_SCORE_CPU_H
 #define _RTEMS_SCORE_CPU_H
-#include <rtems/score/types.h>
+#include <rtems/score/basedefs.h>
 #include <rtems/score/arm.h>
 #if defined(ARM_MULTILIB_ARCH_V4)
@@ -693,6 +693,9 @@ void _ARM_Exception_default( CPU_Exception_frame *frame );
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/types.h b/cpukit/score/cpu/arm/include/rtems/score/types.h
deleted file mode 100644
index 37a56df..0000000
--- a/cpukit/score/cpu/arm/include/rtems/score/types.h
+++ /dev/null
@@ -1,51 +0,0 @@
- * @file
- * @brief ARM Architecture Types API
- *  This include file contains type definitions pertaining to the
- *  arm processor family.
- *  COPYRIGHT (c) 2000 Canon Research Centre France SA.
- *  Emmanuel Raguet, mailto:raguet at crf.canon.fr
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @addtogroup ScoreCPU
- *  This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
-#endif
1.8.3.1
